dmesa99 Posted January 5, 2017 Share Posted January 5, 2017 (edited) hello I keep having a problem opening a file i would attach but it will not let me file is only 17.2 mb and will not open i get error System.OverflowException: Overflow error. at System.Drawing.Image.FromStream(Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData) at PaintDotNet.Data.JpegFileType.OnLoad(Stream input) in D:\src\pdn\src\PaintDotNet\Data\JpegFileType.cs:line 78 at PaintDotNet.FileType.Load(Stream input) in D:\src\pdn\src\Data\FileType.cs:line 496 at PaintDotNet.Functional.Func.Eval[T1,TRet](Func`2 f, T1 arg1) in D:\src\pdn\src\Base\Functional\Func.cs:line 158 Edited January 5, 2017 by dmesa99 Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 5, 2017 Share Posted January 5, 2017 Does your jpeg image open in other programs. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
dmesa99 Posted January 5, 2017 Author Share Posted January 5, 2017 does open in windows 10 photos but thats it Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 5, 2017 Share Posted January 5, 2017 Well then... 1) Open the image in the Windows 10 Photos program 2) Select the 'Copy' menu item in the Photos program. 3) Paste the image into paint.net. 4) Save As... 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
dmesa99 Posted January 5, 2017 Author Share Posted January 5, 2017 tried that and it fails when i open with paint.net Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 5, 2017 Share Posted January 5, 2017 Do you need the file in full resolution? Or, would screen resolution work? 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
dmesa99 Posted January 5, 2017 Author Share Posted January 5, 2017 will wide screen lower quality?? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 5, 2017 Share Posted January 5, 2017 23 minutes ago, dmesa99 said: will wide screen lower quality?? Assuming your screen resolution is lower than the image's resolution, yes, it would be lower quality, or at least less detailed. Here's another option to try: 1) Open the image in the Photos program 2) Click on 'edit' 3) Click on 'Sauna' filter, and then click on the 'Original' filter 4) Click on 'Save a copy', and create the new image file 5) Try to open the new copy in paint.net Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
dmesa99 Posted January 5, 2017 Author Share Posted January 5, 2017 Just now, toe_head2001 said: Assuming your screen resolution is lower than the image's resolution, yes, it would be lower quality, or at least less detailed. Here's another option to try: 1) Open the image in the Photos program 2) Click on 'edit' 3) Click on 'Sauna' filter, and then click on the 'Original' filter 4) Click on 'Save a copy', and create the new image file 5) Try to open the new copy in paint.net I wish i could but it will not let me edit either Quote Link to comment Share on other sites More sharing options...
dmesa99 Posted January 5, 2017 Author Share Posted January 5, 2017 it will not let me edit because it say it needs to be smaller then 60mp so where should i go now? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 5, 2017 Share Posted January 5, 2017 Open in viewer and press PrtSc key. Open paint.net and Edit > Paste into new image. Crop to specific image. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
dmesa99 Posted January 5, 2017 Author Share Posted January 5, 2017 3 minutes ago, BoltBait said: Open in viewer and press PrtSc key. Open paint.net and Edit > Paste into new image. Crop to specific image. Thank you soo much that worked Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 5, 2017 Share Posted January 5, 2017 Of course, this limits you to your screen resolution, so don't expect the same quality as the original image. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
