Eli Posted December 11, 2016 Author Share Posted December 11, 2016 Thanks for the additions EER. Would it be possible to add in the shapes menu an option to import a png image? and then give it a rotation and the rendered organigram would look like this : Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 11, 2016 Share Posted December 11, 2016 20 hours ago, BoltBait said: EER, this is really well done. I can see some business uses for this. You need to publish this in the plugin forum. Thank you BoltBait. I'll publish asap. I'm still working on a handful of little tweaks. 13 hours ago, Eli said: Would it be possible to add in the shapes menu an option to import a png image? ...give it a rotation and the rendered organigram would look like this : Technically possible. I'm not promising anything because it's a huge amount of extra work. Importing images gets away from the original intent which was to create a simple structural diagram. I'm not even sure I want to go there..... I'm considering adding a checkbox to decouple the shape rotation from the spoke rotation. The reason for this is to keep the shapes orientated the same regardless of the rotation. If using rectangles for example, they would always appear orientated so the long bottom edge is horizontal. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Eli Posted December 12, 2016 Author Share Posted December 12, 2016 22 minutes ago, Ego Eram Reputo said: Technically possible. I'm not promising anything because it's a huge amount of extra work. Importing images gets away from the original intent which was to create a simple structural diagram. I'm not even sure I want to go there..... Do not worry about it EER. The effect is already good as it is... And you are right, I got carried away from the original intent. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 14, 2016 Share Posted December 14, 2016 Organigram has been released! Go get it! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
