Ego Eram Reputo Posted October 29, 2016 Share Posted October 29, 2016 I'm not sure how to create a custom load dialog using indirectUI. Anyone got any pointers or code snippets? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 29, 2016 Share Posted October 29, 2016 A load dialog? As in a dialog to select and open a file? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 29, 2016 Author Share Posted October 29, 2016 I'm opening a 3D model. I'd like to be able to scale and rotate it before committing it to the canvas. Something like the *.ico dialog which appears after you select a file. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
null54 Posted October 29, 2016 Share Posted October 29, 2016 1 hour ago, Ego Eram Reputo said: I'm opening a 3D model. I'd like to be able to scale and rotate it before committing it to the canvas. Something like the *.ico dialog which appears after you select a file. You would have to create a custom dialog in Windows Forms. Note that according to this thread showing a load dialog in a FileType plugin is not officially supported. On 7/17/2013 at 5:07 PM, Rick Brewster said: Cancelling a load operation isn't supported because showing UI for loading a file isn't supported. What you're doing is by definition a hack, so asking why it doesn't work very well is kind of silly. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 29, 2016 Author Share Posted October 29, 2016 ^ Thank you. Perhaps I'm better to make this a regular plugin and forgo the filetype. Shame, I had it loading files nicely. Making it a regular Effect would solve a number of issues for me though. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
