Problem reinstalling PDN
During the 4.0.10 update, paint.net seemed to have mysteriously uninstalled itself afterward. All that was left were my Effects and FileTypes folders.
I tried installing the latest version, and at first it seemed to be working, albeit slowly. But then it got to here:
It's been stuck here for almost 13 hours.
 The strange thing is, it isn't frozen. I've gotten no errors/notifications, Task Manager says it's fine, I can switch to and from the window, and the progress bar still has that little "moving light"
Does anyone know what's going on?
Steam Profile: http://steamcommunity.com/id/glitchmaster225/
“If at first you don't succeed, then skydiving definitely isn't for you.”
Steven Wright
13 hours seems too long. I'd kill the process. There is obviously something amiss.
  • 2 months later...
I was able to get it working. I installed it on a separate PC and copied it over. So it seems that my problem was the installer itself.
Steven Wright
