henx125 Posted October 20, 2016 Share Posted October 20, 2016 (edited) Almost every time I open paint.net, on a blank canvas or a loaded image, the client is extremely laggy to the point where any alterations to the canvas itself need about a second before they actually appear. This includes whenever I move my cursor around - the crosshair does not lag at all but the dot under it where the brush is does. Regardless of this fact, I went to go try and sketch something out hoping that I might be able to just get used to the delay and was doing ok until the client suddenly crashed and in the log mentioned an out of memory exception. Here is the log for refrence: http://pastebin.com/264BDvRr And my diagnostics paste: http://pastebin.com/XR3Hz3qY I should mention that after this first crash I restarted paint.net and found that I did not lag at all when using the brush on the default blank canvas however as soon as I loaded a 900x600 jpg the lag came back both in that image and in the blank canvas even after the loaded image was closed. I'm not sure exactly when this problem first started, maybe it was when I switched over to win10 (fresh install) or maybe it was when I downloaded an update for paint or my drivers but it's really irritating as it renders me unable to use the program in any real capacity. I know that on the exact same system I used to use paint.net extensively in the past and never have had any issues. I would not expect there to be any issues with memory - system, video, or otherwise - so maybe the it's simply an option that I missed? I've tried and gotten the same results with hardware accelerated rendering on and off, a fresh install did not seem to work and the problem occurs regardless of if there is an image loaded or not. Any help with this would be much appreciated. Solution found: EVGA PrecisionX running in the background somehow caused an issue for paint.net - as long as it's not running while paint is there is no lag or crash. Edited October 20, 2016 by henx125 Quote Link to comment Share on other sites More sharing options...
Zagna Posted October 20, 2016 Share Posted October 20, 2016 Quote C:\Program Files (x86)\EVGA\PrecisionX 16\PXSHW10_x64.dll, version=5.3.11 This is just a guess... but it could be overlay messing up somehow. Try without Precision X running just to make sure it's not that? 2 Quote Link to comment Share on other sites More sharing options...
henx125 Posted October 20, 2016 Author Share Posted October 20, 2016 Yup, that was exactly what it was. Can't believe I didn't even think of that, but honestly why should it have even affected it... Anyway, thanks a ton. Always useful to have another pair of eyes look at a problem Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 20, 2016 Share Posted October 20, 2016 Nice catch Zagna! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
