TreyH Posted October 16, 2016 Share Posted October 16, 2016 I have a Nikon D3300 and I have been trying to get a RAW plug in to work but they either malfunction or compromise image quality. It could be user error but I followed the guide to installing plug ins. I can provide a RAW photo and the JPEG counter part if you would like to give it a try. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 16, 2016 Share Posted October 16, 2016 Hi TreyH - welcome to the forum Have you tried this plugin? It's the latest one released and *should* do the job. Installation instructions are in the first post along with the downloadable ZIP. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
TreyH Posted October 16, 2016 Author Share Posted October 16, 2016 39 minutes ago, Ego Eram Reputo said: Hi TreyH - welcome to the forum Have you tried this plugin? It's the latest one released and *should* do the job. Installation instructions are in the first post along with the downloadable ZIP. It does work but unfortunately it appears my bit output is too high so my image comes out dark. Appreciate the the welcome and help! Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 17, 2016 Share Posted October 17, 2016 Hey TreyH, Which colorspace did you specify when loading the RAW file? Or did you try all of them? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
TreyH Posted October 17, 2016 Author Share Posted October 17, 2016 37 minutes ago, toe_head2001 said: Hey TreyH, Which colorspace did you specify when loading the RAW file? Or did you try all of them? I use sRGB Quote Link to comment Share on other sites More sharing options...
