Delebot Posted October 11, 2016 Share Posted October 11, 2016 I run a 2-monitor layout, and with the newest update (4.0.12), every time I maximize paint.net on the non-primary monitor, the status bar and half of the toolbars don't show. Here's what it looks like: and I was wondering if anyone else with multi-display setups also had a similar problem with this version. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 11, 2016 Share Posted October 11, 2016 What are the resolutions of your two monitors? Also, can you click the gear icon, diagnostics tab, copy to clipboard button... then come here and paste the info. Thanks. That may help. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Delebot Posted October 12, 2016 Author Share Posted October 12, 2016 Here's the pastebin to my diagnostics: http://pastebin.com/YHY715cM Both monitors are 1920x1080 Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 12, 2016 Share Posted October 12, 2016 Are you running any kind of Windows Management software, like Mirillis Action or Window Blinds? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Delebot Posted October 12, 2016 Author Share Posted October 12, 2016 No, and it hasn't been like this until the most recent pdn update. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 12, 2016 Share Posted October 12, 2016 Thanks for the additional info. I'm afraid you'll just have to wait for a response from Rick on this one. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 13, 2016 Share Posted October 13, 2016 No idea. Nothing should've changed with respect to this. I haven't had any other reports of stuff like this. Can you interact with the menus? How well does that work? Also, I no longer do any testing on Windows 8 or 8.1. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Delebot Posted October 13, 2016 Author Share Posted October 13, 2016 The part that's "cut out" doesn't even count as the paint.net window, if I right click on that part, it shows the desktop's context menu (if nothing else is behind the paint.net window) Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 13, 2016 Share Posted October 13, 2016 Can you see if any this behavior changes when you're in Windows Safe Mode? We need to rule out any 3rd-party software that could be interfering. Can you confirm that the issue goes away if you switch back to paint.net v4.0.10 or v4.0.11? (Switching back is not the solution; this is just for troubleshooting purposes) Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 13, 2016 Share Posted October 13, 2016 Are you using any software to manage the multi-monitor setup? Like ATI HydraVision? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
