xxxxxxxx Posted September 30, 2016 Share Posted September 30, 2016 I wanted to change all the pink squares to the same light blue(0/255/255). I used the recolor tool. Then I clicked one of the pink squares. And this is what I got: Some of the pink squares didnt change (as expected, since I have 23 tolerance). However, the squares that changed color did not change to the correct blue (0/255/255). I used color picker on one of the squares as shown below. The color was 0/255/238. My PDN version is I do not remember seeing this before. So... Is this a bug or designed to be like this? And the most important thing is : How can I change similar colors to one particular color? Can anyone help please? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 30, 2016 Share Posted September 30, 2016 Set Primary as the color you want. Set the secondary color as the color you want to remove. In the toolbar, make sure you're sampling using the secondary see: http://www.getpaint.net/doc/latest/RecolorTool.html Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
