MLGSUMO Posted September 7, 2016 Share Posted September 7, 2016 So i was making a logo for my channel but then the brush tool is pixelated, this is annoying to me because i will be trying to make hair all the time. Is their any fix? Quote Link to comment Share on other sites More sharing options...
Red ochre Posted September 7, 2016 Share Posted September 7, 2016 Have you accidentally turned the anti-aliasing off? http://www.getpaint.net/doc/latest/Paintbrush.html 2 Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
MLGSUMO Posted September 8, 2016 Author Share Posted September 8, 2016 No but it looks like this Quote Link to comment Share on other sites More sharing options...
Red ochre Posted September 9, 2016 Share Posted September 9, 2016 Are you certain you are working on the correct size image? Check the resolution is 96 pixels per inch in the resize dialogue and set the zoom level to 100% - is that the intended size? If it really is intened to be a small image you may do better to work at double the size then reduce the size when you have finished. Or use the pencil tool if you are creating 'pixel art'. Please read through the documentation (press the F1 key while paint.net is open) to learn about the tools. This tutorial is very useful for learning about resolution. http://forums.getpaint.net/index.php?/topic/17049-dpi-and-you-understanding-resolution-for-print-and-web/ Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
MLGSUMO Posted September 9, 2016 Author Share Posted September 9, 2016 Thanks Red orche, that helped it. Quote Link to comment Share on other sites More sharing options...
