jackhigh24 Posted August 27, 2016 Share Posted August 27, 2016 hi all, iv drawn an image in white on a transparent background that was filled with zero alpha white, iv saved it and can reload it back up and the transparent background is maintained as zero white alpha, now i want to resize it smaller but when ever i do the transparent white background turns to transparent black, i need to keep it transparent white, how do i do that, same goes for if you copy paste it its turn to a black transparent to. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 27, 2016 Share Posted August 27, 2016 Are you saving the image as a jpg? These don't support transparency, so they usually substitute solid white or black. Save it as a PNG. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
jackhigh24 Posted August 27, 2016 Author Share Posted August 27, 2016 (edited) hi @Ego Eram Reputo thanks for the reply, yes its a png and like i said i can save it and it keeps the white transparent background white 0 alpha, but if i resize the image then use the colour select tool to see what the transparent background colour is then its black 0 alpha, i need it to stay white 0 alpha. Edited August 27, 2016 by jackhigh24 Quote Link to comment Share on other sites More sharing options...
