witness Posted August 4, 2016 Share Posted August 4, 2016 I'm still a newbie here so there is so much I do not know. I took a photo and the faces are not real sharp. Just slightly out of focus. Is there a quick, easy way to help fix this problem with paint.net? Thank you very much! W. Quote Link to comment Share on other sites More sharing options...
Eli Posted August 4, 2016 Share Posted August 4, 2016 Try TR's Dodge and Burn effect. Follow this tutorial: http://forums.getpaint.net/index.php?/topic/28777- Quote Link to comment Share on other sites More sharing options...
Red ochre Posted August 4, 2016 Share Posted August 4, 2016 Hello witness,Try Effects/Photo/Sharpen but the only real fix is to retake the photo, if possible.There is also a plugin called TR's Pixel Sharpener, that may give better results. http://forums.getpaint.net/index.php?showtopic=26783 Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
witness Posted August 4, 2016 Author Share Posted August 4, 2016 Hello witness, There is also a plugin called TR's Pixel Sharpener, that may give better results. http://forums.getpaint.net/index.php?showtopic=26783 Okay. I managed to download and install the plugin. It pops up just like in the picture. But now I don't know how to use it. Sorry to be such a novice. I see two options: "Sharpen Amount" and "Blur Width" But I am lost as to what comes next. Do I take the Sharpen amount higher? Just a bit? Thanks guys! Quote Link to comment Share on other sites More sharing options...
Red ochre Posted August 4, 2016 Share Posted August 4, 2016 Sorry witness, the only way is to experiment with what looks best to you as every image is different. I suggest you duplicate the image so you have the original (blurred version) to compare against.Generally speaking it is better not to 'sharpen' too much as it can emphasize unwanted 'noise'. Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
