Need help installing Paint.NET
Click here for reference.
I've been having trouble installing Paint.NET ever since we upgraded our family computer to Windows 8. .NET Framework is the latest version and seems to be working properly. The installer looks to be doing what it's doing at first, but after that second-to-last image a blank window pops up and then immediately closes up to the point that I can't screencap fast enough. There seems to be a compatibility issue with it, and I don't know how to fix this other than downgrading to Windows 7 again.
Any suggestions on what to do?
also pls forgive me if this is in the wrong section
Hi and welcome Zycharia :D
You may need to install .NET separately prior to installing paint.net.
Link: https://www.microsoft.com/en-us/download/details.aspx?id=49982
Reboot your PC afterwards & then try installing paint.net. If it doesn't install, try using this diagnostic tool http://forums.getpaint.net/index.php?/topic/107908-1603-error-diagnostic-tool/
? Worked fine when I posted it and again just now. Look for the red button below the Win 10 Upgrade ad.
