how to make a multi color pattern
Hi there.
i wanna to make a cover for s.w.a.t 4 but there is a problem
if you look at the right side of the cover you can see the multiply mixed colores
i want to make a color ( mixed like the right part) for the left side what should i do ? i dont know how to do it  :| .
sorry for mistakes  iam not english :D
Edited by kasra
Hi @kasra.  One suggestion is:
First do this tutorial: http://forums.getpaint.net/index.php?/topic/16075-concrete-texture-tutorial/
1.  Do the concrete tutorial, save the finished image to .png.
2.  Open PDN and import the above image.
      Use the Frosted Glass Plugin and play with the settings, then change the blending Mode to Difference.
3. New layer - Add a light blue Gradient with the 2nd color's opacity at zero.  Change the blending mode to Color Dodge.
4.  Flatten the image and you now have a background to start with.
I hope this is of help.
If you want a simpler solution, try setting you Primary and Secondary colors to gray and white then run Effects > Render > Clouds.
The settings are worth playing with. So are the colors you start with.
Here I set the Primary color to #ABB6CA and the Secondary color to #DDDDDD then ran Clouds :CloudsEffect: with these settings
It's still not 100% perfect, but you should get the idea.
