freetrial Posted July 23, 2008 Share Posted July 23, 2008 Hi, my computer have problem displaying the right size of the tool/color/history/layers windows. they are always maximized and cover the rest of software interface. They can not be resized. The only choice is to close them. I am using Windows XP SP2 with dual LCD display(1280x1024) supported by a radeon x700 video card. Thanks. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted July 23, 2008 Share Posted July 23, 2008 If the tool windows are really really big, then you most likely have something like ATI HydraVision (or another "multimonitor manager" type program) installed. Historically, that has always been the cause, and disabling or uninstalling these not-very-useful programs always fixes it. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
freetrial Posted July 24, 2008 Author Share Posted July 24, 2008 Thanks for your reply. I uninstalled the hydravision and after reboot, the tool and color windows are back to normal, but not the history and layer window. What should I do next? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted July 24, 2008 Share Posted July 24, 2008 How about... Windows > Reset window locations :?: Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
freetrial Posted July 24, 2008 Author Share Posted July 24, 2008 reset windows-not working Quote Link to comment Share on other sites More sharing options...
BoltBait Posted July 24, 2008 Share Posted July 24, 2008 Can you resize these windows by hand? If not, show us a screenshot. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
freetrial Posted July 25, 2008 Author Share Posted July 25, 2008 problem solved. thanks! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted July 25, 2008 Share Posted July 25, 2008 freetrial, I'm glad it worked out! Rick, I have confirmed that "Windows > Reset window locations" does not also reset the floating window sizes back to default. Shouldn't it also do this? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
bEPIK Posted July 25, 2008 Share Posted July 25, 2008 Perhaps make another button? Example: Window > Return to Default Size Quote Water, Wood and Hair Tutorial Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 25, 2008 Share Posted July 25, 2008 That's why it's called Reset Window Locations. It doesn't change the size. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
