tourist Posted July 22, 2008 Share Posted July 22, 2008 I want to use this image as a Icon. So I saved it as an .ico. Then I tried to use it as an icon and a windows pop up says that "compass.ico contains no icons". I am confused. Can someone help? Quote Make a Paint Brush Make a Cue Stick Make a Rope Link to comment Share on other sites More sharing options...
BoltBait Posted July 22, 2008 Share Posted July 22, 2008 Paint.NET does not support creation of icon files. Did you use an icon filetype plugin to make the image into an icon file? Quote Download: BoltBait's Plugin Pack | CodeLab | and a Computer Dominos Game Link to comment Share on other sites More sharing options...
tourist Posted July 22, 2008 Author Share Posted July 22, 2008 Paint.NET does not support creation of icon files.Did you use an icon filetype plugin to make the image into an icon file? Yes I did. I followed your link and found out that I can open icon files in Paint.NET, but I am unable to create an icon file from scratch. Thank you. :idea: What if I open an existing .ico file and delete everything within it, replacing it with the above image and save that? Will that work? :arrow: Now I am even more confused. I looked in a folder on my computer and came across some icons that I created a while back using Paint.NET (:? ...from sratch. Quote Make a Paint Brush Make a Cue Stick Make a Rope Link to comment Share on other sites More sharing options...
