Help with large images
I'm having trouble with the lag in large images. For instance if I load up a 7000 by 7000 pixel blank canvas and try drawing a curve, a lag will occur and my curve will end up a straight line. Is there a way to make it, like, queue my actions?
With the Line/Curve Tool, curves always are drawn as straight lines initially. Are you saying the curves stays straight when you move the nubs around?
For performance, the only thing you can really do is to get better hardware. I'm sorry to say your low-power (7.5W) dual core Celeron processor is not going to give you good performance when working with large canvases.
