opentype fonts
My WhichSymbol+ plugin will allow you to see some of them (perhaps not all). There is a link to it in my signature.
That sort of font is really only worthwhile in massively expensive, professional-level typesetting and publishing platforms, which isn't quite what Paint.NET is trying to be.  Adobe InDesign might give you better results, but even that is questionable.
Long story short, the site may not be lying to you, you might just not have all the tech required to really see everything fully.
Or it could be lying to you.  :-)
Charmap might be of assistance here http://windows.microsoft.com/en-nz/windows/using-special-characters-character-map-faq#1TC=windows-7
Use it to find your special characters then copy them into the text tool in paint.net.
Thanks for the replies. I checked out the character map for the font and it showed a few more than whichsymbol. Should it show all the available characters within a font? Because that would be a way to get those fancy characters into paint dot net without having to use those massively expensive, professional-level typesetting and publishing platforms!
It will probably show you all of the available characters, but as far as I know not all of the available variants or ligatures.  But I could be wrong.  Still, if you find what you need in character map, go for it!
Lobster two does have hundreds of glyphs. Actually there is a set of 357 of them. This same set is reproduced in each of the styles regular, bold, italic and bold+italic.
CharMap should show them all. I suspect you were expecting 357x4=1428 glyphs?
Here's the full set
Lobster Two Regular | 357 Glyphs
Lobster Two Italic | 357 Glyphs
Lobster Two Bold | 357 Glyphs
Lobster Two Bold Italic | 357 Glyphs
