preeber Posted April 23, 2016 Share Posted April 23, 2016 When I open Alpha displacement the menu is all messed up. Does anyone know how to fix it? Link to comment Share on other sites More sharing options...
Red ochre Posted April 23, 2016 Share Posted April 23, 2016 That's a great plugin! - you could try my 'Clip Displace' based on the same idea but Pdn 4.0.9 compatible.http://forums.getpaint.net/index.php?/topic/32416-clipdisplace-smoothing-update-31122015/ If not you could P.M the author, but they haven't been around for while? Have you tried setting your resolution to 100%? Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
Cc4FuzzyHuggles Posted April 23, 2016 Share Posted April 23, 2016 Have you changed your display setting at all? I know when I put my display to 125% or higher, some plugin User Interfaces become odd looking. I use windows 7, but I think other windows versions have the same feature. *~ Cc4FuzzyHuggles Gallery ~* Link to comment Share on other sites More sharing options...
preeber Posted April 23, 2016 Author Share Posted April 23, 2016 Yes I did try changing both resolution from 1920x1080 to 1280x720. I also tried changing my magnification to 100% from 150%. They didn't have any affect. Link to comment Share on other sites More sharing options...
BoltBait Posted April 23, 2016 Share Posted April 23, 2016 http://forums.getpaint.net/index.php?/topic/9349-plugin-problems-read-this Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
