Color Range Test
ReMake
That
Here are two examples of what I mentioned in my previous post. Stencils can also be made with Red ochre's Two Tone Threshold, but the method is different of course. With this plugin I select black as the color, and set the brightness slider to some value around the middle or quite below the middle. It's good to have another plugin to do stencils :)
Example 1:
Jemma_Dallender_Color_Range_Stencil_Comp
Example 2:
Super_Hero_Smiley_Color_Range_Stencil_Co
Wow ! I'm agreeing with you that this plugin has many purposes
  • Upvote 2
Thanks to all who tested this effect.
You are most welcome - it was a pleasure to test :D .
BTW - I just learned that Belarus is one country which does not practice daylight savings time - I wish the rest of the world would comply as I personally hate it =O .
Thank You.
BTW - I just learned that Belarus is one country which does not practice daylight savings time ...
It thanks to Belarusian doctors.
  • 2 years later...
14 hours ago, ReMake said:
I don't understand what you mean.
I followed the steps, but I cant change the color like you did. Is there a video tutorial easy to understand for newbies?
Edited by toe_head2001
Changed casing from ALL CAPS
