Kronos Posted March 7, 2016 Share Posted March 7, 2016 I installed the latest version of Paint.Net.I use Windows 8 It goes through the installation with no problem. But never installs it. There is no "icon" on desktop for paint.net program There are no files made. There are no error codes. As I said, it goes through the installation with no problem. Yet does not show anything was installed. How can I fix this? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 7, 2016 Share Posted March 7, 2016 Hi Kronos - welcome to the forum. First let's find out if you're trying to install the correct thing. There have been instances where the ads on the paint.net website have been misleading. Go here and download the latest version: http://www.getpaint.net/download.html#download then try installing that. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Kronos Posted March 7, 2016 Author Share Posted March 7, 2016 Yes that is the correct thing. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted March 8, 2016 Share Posted March 8, 2016 Can you see files in "C:\Program Files\paint.net\" while the installation is in progress. i.e. Before the installation finishes? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Kronos Posted March 8, 2016 Author Share Posted March 8, 2016 There are no files. It extracts fine, installs fine, but no files or anything comes up. Quote Link to comment Share on other sites More sharing options...
Kronos Posted March 8, 2016 Author Share Posted March 8, 2016 (edited) Something is different now though. It's installing the framework. Has not done that before. O.O Edited: Nothing new.Same thing again.No files still. Edited March 8, 2016 by Kronos Quote Link to comment Share on other sites More sharing options...
Kronos Posted March 8, 2016 Author Share Posted March 8, 2016 Ok, I was messing around with it for a while.Seems to be working fine. Thanks for the help everyone. Quote Link to comment Share on other sites More sharing options...
