JerryD Posted February 12, 2016 Share Posted February 12, 2016 Paint.net forum, I downloaded Paint.net 4.0.0 and this is my first time using a paint program. In my session I have opened 2 pdf files. One contains a simple drawing and the other is just a solid color. My goal is to use one as a background and then make it transparent. They are shown as 2 different layers and I labeled one Foreground and the other Background. I have successfully erased the white pixels around the drawing and now I want to merge the 2 layers together. When I click on "Layers" the Merge option is grayed out. What am I doing wrong?Jerry D. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted February 12, 2016 Share Posted February 12, 2016 Perhaps you are looking for Image > Flatten. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
JerryD Posted February 12, 2016 Author Share Posted February 12, 2016 Bolt Bait, Thanks for the reply. I don't know what Image Flatten but it's also grayed out. I'll go read about it. Jerry D. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted February 12, 2016 Share Posted February 12, 2016 If the Image > Flatten menu item is grayed out, your image only has 1 layer. I'm thinking that you actually opened both pictures into different images. Can you show us a screenshot of your ENTIRE paint.net window? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
JerryD Posted February 12, 2016 Author Share Posted February 12, 2016 I tried to attach a screen shot but got a message saying I couldn't use that kind of file in this forum? Jerry D. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted February 12, 2016 Share Posted February 12, 2016 Try uploading as JPG or PNG. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
JerryD Posted February 12, 2016 Author Share Posted February 12, 2016 Here a PNG. Hope it worked. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted February 12, 2016 Share Posted February 12, 2016 Try this: :LeftArrowBlue: (click) Remember, when saving your final output, save as PDN format to retain layer information. Then, save as PNG to save a web safe version that retains transparency. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
JerryD Posted February 12, 2016 Author Share Posted February 12, 2016 Thanks, that worked. There isn't any help button on Paint.net. Is there a manual somewhere? Jerry D. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted February 12, 2016 Share Posted February 12, 2016 The paint.net manual can be viewed by pressing F1 from inside of paint.net. That will take you here: http://www.getpaint.net/doc/latest/index.html Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
MJW Posted February 12, 2016 Share Posted February 12, 2016 Or use the little blue question-mark icon in the upper-right corner if, like me, you haven't memorized all the keyboard shortcuts. Quote Link to comment Share on other sites More sharing options...
