MiamiHeat87 Posted January 30, 2016 Share Posted January 30, 2016 (edited) I've used transparent color before in my images, but it's been awhile and I forgot how I did so. Here is an image below: I tried using the Opacity Alpha level, but it just makes parts of my image completely disappear. And that wasn't even the tool I used before. Anyone know how I do this again? And if I can use it with the triangle shape? Edited January 30, 2016 by MiamiHeat87 Quote Link to comment Share on other sites More sharing options...
Pixey Posted January 30, 2016 Share Posted January 30, 2016 Have you tried the Adjustments menu at the top and the Hue/Saturation? Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
MJW Posted January 30, 2016 Share Posted January 30, 2016 Perhaps BoltBait's Adjustments>Transparency. Quote Link to comment Share on other sites More sharing options...
Eli Posted January 30, 2016 Share Posted January 30, 2016 You can also just change the opacity of the layer if you want to see the layer below it. 1 Quote Link to comment Share on other sites More sharing options...
Cc4FuzzyHuggles Posted January 30, 2016 Share Posted January 30, 2016 (edited) 1 Open your image. 2 Add a new layer. 3 Draw your lines, shapes, colors, etc. 4 Open Layer Properties and lower the opacity of the layer. http://www.getpaint.net/doc/latest/LayersWindow.html - Another alternative is you can add a new layer to draw on - Then choose your color, and then in the colors window click "MORE". At the bottom is the "Alpha - Opacity". Don't lower it all the way, play with it till you have what you like. http://www.getpaint.net/doc/latest/ColorsWindow.html You can draw with the paintbrush, line/curve tool, or shapes tool. Edited January 30, 2016 by Cc4FuzzyHuggles Quote *~ Cc4FuzzyHuggles Gallery ~* Link to comment Share on other sites More sharing options...
MiamiHeat87 Posted January 30, 2016 Author Share Posted January 30, 2016 Thanks Huggles. The way you do it is really good. Quote Link to comment Share on other sites More sharing options...
