jlstx3500 Posted July 6, 2008 Share Posted July 6, 2008 hi i had downloaded a few of boltbaits plugins. since they were easier. and yesterday they worked fine. today when i open my paint.net. they are not on my effects menu any more. but they are still showing in my effects program folder. the only thing i had done since then was add a plug in from another user. but it doesnt show up either.none of myplugins are coming up when i am in paint now. anyone have this problem too?? i am lost without my reflection plugin. hellpp Quote Link to comment Share on other sites More sharing options...
Speed Demon Posted July 6, 2008 Share Posted July 6, 2008 viewtopic.php?f=10&t=23939 Quote Myspace/ My Pictorium Link to comment Share on other sites More sharing options...
jlstx3500 Posted July 6, 2008 Author Share Posted July 6, 2008 thanks but that post just tells you how to install a plugin and open it in more detail.. my problem is i had the plugins in and working yesteday and today though they are still in the program folder no longer show up when i open paint and click on effects. i have even tried deleting the plug in and reinstalling it and it still not in the paint when i open it up. but again thank you for your help Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted July 6, 2008 Share Posted July 6, 2008 thanks but that post just tells you how to install a plugin and open it in more detail.. my problem is i had the plugins in and working yesteday and today though they are still in the program folder no longer show up when i open paint and click on effects. i have even tried deleting the plug in and reinstalling it and it still not in the paint when i open it up. but again thank you for your help The post basically asks you to post problems installing plugins in this thread: viewtopic.php?f=16&t=2023 Welcome to the forums. Quote Link to comment Share on other sites More sharing options...
bEPIK Posted July 7, 2008 Share Posted July 7, 2008 Look in your effects folder again. Is there is a file called "PaintDotNet.Effects.dll" in the "Effects" folder? If there is You might have accidentally copied that file from "DRIVE:\Program Files\Paint.NET". Remove it from the "Effects" folder but do not delete the original in "DRIVE:\Program Files\Paint.NET". Edit: After you've done that restart Paint.Net if you were using it. Quote Water, Wood and Hair Tutorial Link to comment Share on other sites More sharing options...
jlstx3500 Posted July 7, 2008 Author Share Posted July 7, 2008 i will look thanks for the advice sadly that was not the problem. but thank you anyway Quote Link to comment Share on other sites More sharing options...
