Smudge
On 7/4/2008 at 12:44 AM, pyrochild said:
My parents would disown me if they knew I worship fish...
Given what my parents are worshipping these days...I could go pescetarian (that's a religion, right?) Do these godfish talk to you? You know, like an imaginary friend that lives in an imaginary place/state/woteva, and claims all kinds of imaginary things? Have a tome of knowledge and method that has been translated by fascists over and over for two thousand years or more? Stay safe and be subversive!
I am having a problem. I have a screen resolution of 3456x2160.  My image is 4080x3072. pint.net ver is 5.02. I just downloaded and installed pyrochild.plugins.installer.2020-11-21. I have 3 layers. I am working on the second layer.
Image 1
The smudge frame does not contain the entire layer. I cannot scroll or see the controls clearly.
@ColoradoPaul  the Smudge window opens full screen.  Minimize it using the middle button in the upper right-hand corner.  At the top of the window there is Zoom Out and Zoom In.  This should help you 'find' the spot you want to smudge.
I like having Smudge, but I don't get it to work very well, I can't adjust the lightness, length, or shape of the Smudge. Is there something else needed to get it to work?  Well I'd like to have the same kind of effect a rolled bit of soft material has for a chalk or pencil drawing.  I'd like to be able to do a long narrow line as well as a broad light fade.
Perhaps you can take a look at a tutorial for smudge found here.
Also, see the 2nd part of this tutorial here.
Hope you find them helpful :)
  • 2 months later...
Here is a new build of Smudge with the following changes:
  • Added support for loading ABR files
  • A few changes that should fix some of the high DPI issues
  • Optimized the brush loading code
  • Removed the dependency on BinaryFormatter
Download replaced by the build at: https://forums.getpaint.net/topic/10634-smudge/?do=findComment&comment=612876
Source Code: https://github.com/0xC0000054/pdn-smudge
  • Like 3
  • Upvote 3
  • Hooray 2
19 minutes ago, Lemonade said:
What does Abort button do? I can't figure out, when I press Abort, smudge/brush is disabled. After that, all I can do is choose OK or Cancel buttons.
It stops the current rendering operation, that feature was added in Smudge version 2.0:
On 12/25/2008 at 8:57 PM, pyrochild said:
-Added an Abort function to interrupt the currently rendering smudge
  • Thanks 1
  • 2 months later...
59 minutes ago, sogun said:
Paint.net 5.0+  required, I assume. As I can no longer find it in the Effects-->tools menu in PDN 4.3.
If you have the older version in 4.3, it should still work. You must have moved it.  But, we can't give it back to you, as you would have to upgrade to the latest version in order to use 5.0+
If you're on an older version of the app then you must install the latest update. Otherwise we cannot and will not help you with anything.
Download: Smudge_41Beta.zip
I downloaded it and it keeps crashing.  Yes, I have everything updated to the newest version.
Please post the Diagnostics:
Application                                          paint.net 5.0.9 (Stable 5.9.8621.1636)
Build Date                                           Wednesday, August 9, 2023
Install type                                         Appx
    Name                                             dotPDNLLC.paint.net
    Publisher ID                                     h55e3w7q8jbva
Language:                                            en-US
DPI                                                  96 (1.00x scale)
UI/Canvas GPU                                        True
Rendering GPU                                        🚀 Performance (NVIDIA GeForce GTX 1650)
Remote session                                       False
Animations                                           True
Translucent windows                                  True
Windows Ink                                          True
OS                                                   Windows 11 Home x64 (10.0.22621.0)
Runtime                                              .NET 7.0.10 x64
Physical Memory                                      8,101 MB (2,372 MB free)
Virtual Memory                                       133,948,280 MB free
Paging File                                          17,081 MB (6,799 MB free)
CPU                                                  Intel(R) Core(TM) i5-10400 CPU @ 2.90GHz
    Speed                                            ~2904 MHz
    Cores / Threads                                  6 / 12
    Features                                         SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2
Video Card                                           NVIDIA GeForce GTX 1650
    Hardware Acceleration                            Supported
    Dedicated Video RAM                              3,962 MB
    Dedicated System RAM                             0 MB
    Shared System RAM                                4,050 MB
    Vendor ID                                        0x10DE
    Device ID                                        0x1F82
    Subsystem ID                                     0xA548174B
    Revision                                         161
    LUID                                             0x0000CCED
    Flags                                            AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                              PixelBoundary
    Compute Preemption                               DispatchBoundary
    Outputs                                          1
    Feature Level                                    Level_12_1
    Features                                         Doubles, ComputeShadersEtc
    DXGI Formats                                     A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float
    Buffer Precisions                                UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32
    Maximum Bitmap Size                              16384
Video Card                                           Microsoft Basic Render Driver
    Hardware Acceleration                            N/A
    Dedicated Video RAM                              0 MB
    Vendor ID                                        0x1414
    Device ID                                        0x008C
    Subsystem ID                                     0x00000000
    Revision                                         0
    LUID                                             0x0000D822
    Flags                                            Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                              InstructionBoundary
    Compute Preemption                               InstructionBoundary
    Outputs                                          0
    Maximum Bitmap Size                              8388608
Managed assemblies                                   142
    System.Private.CoreLib                           .\System.Private.CoreLib.dll, Version=7.0.0.0, PublicKeyToken=7cec85d7bea7798e
    paintdotnet                                      .\paintdotnet.dll, Version=5.9.8621.1636
    System.Runtime                                   .\System.Runtime.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Windows.Forms                             .\System.Windows.Forms.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    PaintDotNet.Fundamentals                         .\PaintDotNet.Fundamentals.dll, Version=5.9.8621.1636
    PaintDotNet.ComponentModel                       .\PaintDotNet.ComponentModel.dll, Version=5.9.8621.1636
    System.Diagnostics.Tracing                       .\System.Diagnostics.Tracing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Thread                          .\System.Threading.Thread.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Base                                 .\PaintDotNet.Base.dll, Version=5.9.8621.1636
    System.Collections.Concurrent                    .\System.Collections.Concurrent.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Collections                          .\PaintDotNet.Collections.dll, Version=5.9.8621.1636
    PaintDotNet.Windows                              .\PaintDotNet.Windows.dll, Version=5.9.8621.1636
    TerraFX.Interop.Windows                          .\TerraFX.Interop.Windows.dll, Version=10.0.22621.2, PublicKeyToken=35b01b53313a6f7e
    PaintDotNet.Primitives                           .\PaintDotNet.Primitives.dll, Version=5.9.8621.1636
    PaintDotNet.Runtime                              .\PaintDotNet.Runtime.dll, Version=5.9.8621.1636
    PointerToolkit                                   .\PointerToolkit.dll, Version=1.0.0.0
    System.Threading                                 .\System.Threading.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.SystemLayer                          .\PaintDotNet.SystemLayer.dll, Version=5.9.8621.1636
    System.Diagnostics.Process                       .\System.Diagnostics.Process.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Systrace                             .\PaintDotNet.Systrace.dll, Version=5.9.8621.1636
    System.Private.Uri                               .\System.Private.Uri.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.Primitives                 .\System.ComponentModel.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    WindowsBase                                      .\WindowsBase.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Windows.Forms.Primitives                  .\System.Windows.Forms.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    PresentationFramework                            .\PresentationFramework.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Runtime.InteropServices                   .\System.Runtime.InteropServices.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Drawing.Primitives                        .\System.Drawing.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xaml                                      .\System.Xaml.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    System.ComponentModel                            .\System.ComponentModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.ObjectModel                          .\PaintDotNet.ObjectModel.dll, Version=5.9.8621.1636
    System.Diagnostics.TraceSource                   .\System.Diagnostics.TraceSource.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections                               .\System.Collections.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.CodePages                   .\System.Text.Encoding.CodePages.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Primitives                       .\Microsoft.Win32.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Core                                 .\PaintDotNet.Core.dll, Version=5.9.8621.1636
    System.ObjectModel                               .\System.ObjectModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Data                                 .\PaintDotNet.Data.dll, Version=5.9.8621.1636
    PaintDotNet.Framework                            .\PaintDotNet.Framework.dll, Version=5.9.8621.1636
    CommunityToolkit.HighPerformance                 .\CommunityToolkit.HighPerformance.dll, Version=8.2.0.0, PublicKeyToken=4aff67a105548ee2
    System.Configuration.ConfigurationManager        .\System.Configuration.ConfigurationManager.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Collections.Specialized                   .\System.Collections.Specialized.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xml.ReaderWriter                          .\System.Xml.ReaderWriter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Xml                               .\System.Private.Xml.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.Windows.Framework                    .\PaintDotNet.Windows.Framework.dll, Version=5.9.8621.1636
    PaintDotNet.UI                                   .\PaintDotNet.UI.dll, Version=5.9.8621.1636
    System.Net.WebClient                             .\System.Net.WebClient.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.ComponentModel.EventBasedAsync            .\System.ComponentModel.EventBasedAsync.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Memory                                    .\System.Memory.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Text.Encoding.Extensions                  .\System.Text.Encoding.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Drawing.Common                            .\System.Drawing.Common.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Microsoft.Win32.SystemEvents                     .\Microsoft.Win32.SystemEvents.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Collections.Immutable                     .\System.Collections.Immutable.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Resources                            .\PaintDotNet.Resources.dll, Version=5.9.8621.1636
    Microsoft.Win32.Registry                         .\Microsoft.Win32.Registry.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Linq                                      .\System.Linq.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.FileVersionInfo               .\System.Diagnostics.FileVersionInfo.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    ComputeSharp.D2D1                                .\ComputeSharp.D2D1.dll, Version=2.0.3.0
    System.Security.Principal.Windows                .\System.Security.Principal.Windows.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Claims                           .\System.Security.Claims.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.TypeConverter              .\System.ComponentModel.TypeConverter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationCore                                 .\PresentationCore.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    DirectWriteForwarder                             .\DirectWriteForwarder.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    PaintDotNet.Windows.Core                         .\PaintDotNet.Windows.Core.dll, Version=5.9.8621.1636
    System.Runtime.Extensions                        .\System.Runtime.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.Debug                         .\System.Diagnostics.Debug.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.VisualC          .\System.Runtime.CompilerServices.VisualC.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.NonGeneric                    .\System.Collections.NonGeneric.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Accessibility                                    .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35
    PaintDotNet.PropertySystem                       .\PaintDotNet.PropertySystem.dll, Version=5.9.8621.1636
    PaintDotNet.Effects.Core                         .\PaintDotNet.Effects.Core.dll, Version=5.9.8621.1636
    System.IO.Packaging                              .\System.IO.Packaging.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    UIAutomationTypes                                .\UIAutomationTypes.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Numerics.Vectors                          .\System.Numerics.Vectors.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PointerToolkit.TerraFX.Interop.Windows           .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.22621.2
    Crc32.NET                                        .\Crc32.NET.dll, Version=1.0.0.0, PublicKeyToken=dc0b95cf99bf4e99
    System.Security.Cryptography                     .\System.Security.Cryptography.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Tasks.Parallel                  .\System.Threading.Tasks.Parallel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects.Gpu                          .\PaintDotNet.Effects.Gpu.dll, Version=5.9.8621.1636
    System.Threading.ThreadPool                      .\System.Threading.ThreadPool.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Loader                            .\System.Runtime.Loader.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    WebPFileType                                     .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.19.0
    AvifFileType                                     .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.25.0
    DdsFileTypePlus                                  .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.12.2.0
    PaintDotNet.Effects                              .\PaintDotNet.Effects.dll, Version=5.9.8621.1636
    System.Reflection.Metadata                       .\System.Reflection.Metadata.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.MemoryMappedFiles                      .\System.IO.MemoryMappedFiles.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Mono.Cecil                                       .\Mono.Cecil.dll, Version=0.11.5.0, PublicKeyToken=50cebf1cceb9d05e
    netstandard                                      .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.Effects.Legacy                       .\PaintDotNet.Effects.Legacy.dll, Version=5.9.8621.1636
    System.Reflection.MetadataLoadContext            .\System.Reflection.MetadataLoadContext.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    BBChart                                          C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\BBChart.dll, Version=1.1.0.0
    System.Windows.Forms.DataVisualization           C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\System.Windows.Forms.DataVisualization.dll, Version=1.0.0.0, PublicKeyToken=31bf3856ad364e35
    Calendar                                         C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Calendar.dll, Version=6.0.8478.32276
    Polygon                                          C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Polygon.dll, Version=4.5.6828.38648
    HSVGradients                                     C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\HSVGradients.dll, Version=4.5.6832.41864
    BandWPlus                                        C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\BandWPlus.dll, Version=6.0.8407.21940
    Burninate                                        C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Burninate.dll, Version=6.0.8407.22069
    BBOutlinedGradientText                           C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\BBOutlinedGradientText.dll, Version=6.0.8426.37652
    CombinedAdjustments                              C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\CombinedAdjustments.dll, Version=6.0.8407.22130
    VignettePlus                                     C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\VignettePlus.dll, Version=6.0.8407.22549
    Alpha2Gray                                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Alpha2Gray.dll, Version=6.0.8407.21872
    ApplyMask                                        C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\ApplyMask.dll, Version=6.0.8609.2294
    ColorBalance                                     C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\ColorBalance.dll, Version=6.0.8407.22111
    mscorlib                                         .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System                                           .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Drawing                                   .\System.Drawing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Resources.Extensions                      .\System.Resources.Extensions.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Transparency                                     C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Transparency.dll, Version=6.0.8407.22532
    CreativeTextPro                                  C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\CreativeTextPro.dll, Version=6.0.8407.22165
    ComplementaryColors                              C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\ComplementaryColors.dll, Version=6.0.8407.23961
    Dream                                            C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Dream.dll, Version=6.0.8414.36727
    Dimensions                                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Dimensions.dll, Version=1.3.6826.38472
    FillFromClipboard                                C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\FillFromClipboard.dll, Version=6.0.8407.22397
    FillFromFile                                     C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\FillFromFile.dll, Version=6.0.8407.22418
    EdgeDetectClassic                                C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\EdgeDetectClassic.dll, Version=1.0.8424.19432
    Flip                                             C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Flip.dll, Version=4.6.7358.36953
    GaussianBlurPlus                                 C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401
    FloydSteinbergDithering                          C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\FloydSteinbergDithering.dll, Version=5.2.8174.39918
    Gray2Alpha                                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Gray2Alpha.dll, Version=6.0.8407.22439
    GridCheckerboard                                 C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\GridCheckerboard.dll, Version=5.2.8141.24786
    HueSatPlus                                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\HueSatPlus.dll, Version=5.2.8174.40274
    Landscape                                        C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Landscape.dll, Version=5.2.8174.40347
    LevelHorizon                                     C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\LevelHorizon.dll, Version=6.0.8407.22459
    MemeMaker                                        C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\MemeMaker.dll, Version=6.0.8407.22476
    ObjectTools                                      C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\ObjectTools.dll, Version=6.0.8482.2565
    OilPaintingPlus                                  C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\OilPaintingPlus.dll, Version=5.2.8141.27893
    Pastel                                           C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Pastel.dll, Version=5.2.8174.40506
    PasteAlpha                                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\PasteAlpha.dll, Version=5.2.8174.40450
    PhotoAdjustments                                 C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\PhotoAdjustments.dll, Version=6.0.8416.38377
    RemoveDust                                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\RemoveDust.dll, Version=6.0.8407.22513
    SeamCarving                                      C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\SeamCarving.dll, Version=5.2.8176.39366
    SharpenClassic                                   C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\SharpenClassic.dll, Version=1.0.8420.39106
    SelectionTools                                   C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\SelectionTools.dll, Version=6.0.8412.38725
    Smudge                                           C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Smudge.dll, Version=4.1.8581.29577
    System.Runtime.Serialization.Formatters          .\System.Runtime.Serialization.Formatters.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.RegularExpressions                   .\System.Text.RegularExpressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Intrinsics                        .\System.Runtime.Intrinsics.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PhotoSauce.MagicScaler                           .\PhotoSauce.MagicScaler.dll, Version=0.13.2.0, PublicKeyToken=fc6b9b7b06809481
    ComputeSharp.Core                                .\ComputeSharp.Core.dll, Version=2.0.3.0
    Newtonsoft.Json                                  .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed
    System.Linq.Expressions                          .\System.Linq.Expressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.Compression                            .\System.IO.Compression.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
Native modules                                       235
    paintdotnet.exe                                  .\paintdotnet.exe, version=5.9.8621.1636
    ntdll.dll                                        C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.22621.1485 (WinBuild.160101.0800)
    KERNEL32.DLL                                     C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.22621.1928 (WinBuild.160101.0800)
    KERNELBASE.dll                                   C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    SHELL32.dll                                      C:\WINDOWS\System32\SHELL32.dll, version=10.0.22621.2215 (WinBuild.160101.0800)
    msvcp_win.dll                                    C:\WINDOWS\System32\msvcp_win.dll, version=10.0.22621.608 (WinBuild.160101.0800)
    ucrtbase.dll                                     C:\WINDOWS\System32\ucrtbase.dll, version=10.0.22621.608 (WinBuild.160101.0800)
    USER32.dll                                       C:\WINDOWS\System32\USER32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    win32u.dll                                       C:\WINDOWS\System32\win32u.dll, version=10.0.22621.2283 (WinBuild.160101.0800)
    GDI32.dll                                        C:\WINDOWS\System32\GDI32.dll, version=10.0.22621.2215 (WinBuild.160101.0800)
    gdi32full.dll                                    C:\WINDOWS\System32\gdi32full.dll, version=10.0.22621.2215 (WinBuild.160101.0800)
    ole32.dll                                        C:\WINDOWS\System32\ole32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    combase.dll                                      C:\WINDOWS\System32\combase.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    RPCRT4.dll                                       C:\WINDOWS\System32\RPCRT4.dll, version=10.0.22621.1344 (WinBuild.160101.0800)
    OLEAUT32.dll                                     C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.22621.1992 (WinBuild.160101.0800)
    SHLWAPI.dll                                      C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    msvcrt.dll                                       C:\WINDOWS\System32\msvcrt.dll, version=7.0.22621.608 (WinBuild.160101.0800)
    VCRUNTIME140_1.dll                               .\VCRUNTIME140_1.dll, version=14.38.32919.0
    VCRUNTIME140.dll                                 .\VCRUNTIME140.dll, version=14.38.32919.0
    IMM32.DLL                                        C:\WINDOWS\System32\IMM32.DLL, version=10.0.22621.1344 (WinBuild.160101.0800)
    shcore.dll                                       C:\WINDOWS\System32\shcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    hostfxr.dll                                      .\hostfxr.dll, version=7,0,1023,36312 @Commit: a6dbb800a47735bde43187350fd3aff4071c7f9c
    ADVAPI32.dll                                     C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    sechost.dll                                      C:\WINDOWS\System32\sechost.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    hostpolicy.dll                                   .\hostpolicy.dll, version=7,0,1023,36312 @Commit: a6dbb800a47735bde43187350fd3aff4071c7f9c
    coreclr.dll                                      .\coreclr.dll, version=7,0,1023,36312 @Commit: a6dbb800a47735bde43187350fd3aff4071c7f9c
    bcryptPrimitives.dll                             C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    System.Private.CoreLib.dll                       .\System.Private.CoreLib.dll, version=7.0.1023.36312
    clrjit.dll                                       .\clrjit.dll, version=7,0,1023,36312 @Commit: a6dbb800a47735bde43187350fd3aff4071c7f9c
    kernel.appcore.dll                               C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    paintdotnet.dll                                  .\paintdotnet.dll, version=5.9.8621.1636
    System.Runtime.dll                               .\System.Runtime.dll, version=7.0.1023.36312
    uxtheme.dll                                      C:\WINDOWS\system32\uxtheme.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Windows.Forms.dll                         .\System.Windows.Forms.dll, version=7.0.1023.36405
    PaintDotNet.Fundamentals.dll                     .\PaintDotNet.Fundamentals.dll, version=5.9.8621.1636
    PaintDotNet.ComponentModel.dll                   .\PaintDotNet.ComponentModel.dll, version=5.9.8621.1636
    System.Diagnostics.Tracing.dll                   .\System.Diagnostics.Tracing.dll, version=7.0.1023.36312
    icu.dll                                          C:\WINDOWS\SYSTEM32\icu.dll, version=68, 2, 0, 10 (WinBuild.160101.0800)
    System.Threading.Thread.dll                      .\System.Threading.Thread.dll, version=7.0.1023.36312
    PaintDotNet.Base.dll                             .\PaintDotNet.Base.dll, version=5.9.8621.1636
    System.Collections.Concurrent.dll                .\System.Collections.Concurrent.dll, version=7.0.1023.36312
    PaintDotNet.Collections.dll                      .\PaintDotNet.Collections.dll, version=5.9.8621.1636
    PaintDotNet.Windows.dll                          .\PaintDotNet.Windows.dll, version=5.9.8621.1636
    TerraFX.Interop.Windows.dll                      .\TerraFX.Interop.Windows.dll, version=10.0.22621.2
    PaintDotNet.Primitives.dll                       .\PaintDotNet.Primitives.dll, version=5.9.8621.1636
    PaintDotNet.Runtime.dll                          .\PaintDotNet.Runtime.dll, version=5.9.8621.1636
    PointerToolkit.dll                               .\PointerToolkit.dll, version=1.0.0.0
    System.Threading.dll                             .\System.Threading.dll, version=7.0.1023.36312
    PaintDotNet.SystemLayer.dll                      .\PaintDotNet.SystemLayer.dll, version=5.9.8621.1636
    System.Diagnostics.Process.dll                   .\System.Diagnostics.Process.dll, version=7.0.1023.36312
    PaintDotNet.Systrace.dll                         .\PaintDotNet.Systrace.dll, version=5.9.8621.1636
    windows.storage.dll                              C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.22621.2070 (WinBuild.160101.0800)
    wintypes.dll                                     C:\WINDOWS\SYSTEM32\wintypes.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    windows.staterepositorycore.dll                  C:\WINDOWS\SYSTEM32\windows.staterepositorycore.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    System.Private.Uri.dll                           .\System.Private.Uri.dll, version=7.0.1023.36312
    BCrypt.dll                                       C:\WINDOWS\SYSTEM32\BCrypt.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.ComponentModel.Primitives.dll             .\System.ComponentModel.Primitives.dll, version=7.0.1023.36312
    WindowsBase.dll                                  .\WindowsBase.dll, version=7.0.1023.36404
    System.Windows.Forms.Primitives.dll              .\System.Windows.Forms.Primitives.dll, version=7.0.1023.36405
    PresentationFramework.dll                        .\PresentationFramework.dll, version=7.0.1023.36404
    System.Runtime.InteropServices.dll               .\System.Runtime.InteropServices.dll, version=7.0.1023.36312
    System.Drawing.Primitives.dll                    .\System.Drawing.Primitives.dll, version=7.0.1023.36312
    System.Xaml.dll                                  .\System.Xaml.dll, version=7.0.1023.36404
    System.ComponentModel.dll                        .\System.ComponentModel.dll, version=7.0.1023.36312
    PaintDotNet.ObjectModel.dll                      .\PaintDotNet.ObjectModel.dll, version=5.9.8621.1636
    System.Diagnostics.TraceSource.dll               .\System.Diagnostics.TraceSource.dll, version=7.0.1023.36312
    System.Collections.dll                           .\System.Collections.dll, version=7.0.1023.36312
    System.Text.Encoding.CodePages.dll               .\System.Text.Encoding.CodePages.dll, version=7.0.1023.36312
    Microsoft.Win32.Primitives.dll                   .\Microsoft.Win32.Primitives.dll, version=7.0.1023.36312
    PaintDotNet.Core.dll                             .\PaintDotNet.Core.dll, version=5.9.8621.1636
    System.ObjectModel.dll                           .\System.ObjectModel.dll, version=7.0.1023.36312
    PaintDotNet.Data.dll                             .\PaintDotNet.Data.dll, version=5.9.8621.1636
    PaintDotNet.Framework.dll                        .\PaintDotNet.Framework.dll, version=5.9.8621.1636
    CommunityToolkit.HighPerformance.dll             .\CommunityToolkit.HighPerformance.dll, version=8.2.1.1
    PresentationNative_cor3.dll                      .\PresentationNative_cor3.dll, version=7,0,23,36204 @Commit: ad072b5e2d0b7f41adc102d487ef2ec23d4289c8
    System.Configuration.ConfigurationManager.dll    .\System.Configuration.ConfigurationManager.dll, version=7.0.1023.36312
    System.Collections.Specialized.dll               .\System.Collections.Specialized.dll, version=7.0.1023.36312
    System.Xml.ReaderWriter.dll                      .\System.Xml.ReaderWriter.dll, version=7.0.1023.36312
    System.Private.Xml.dll                           .\System.Private.Xml.dll, version=7.0.1023.36312
    PaintDotNet.Windows.Framework.dll                .\PaintDotNet.Windows.Framework.dll, version=5.9.8621.1636
    PaintDotNet.UI.dll                               .\PaintDotNet.UI.dll, version=5.9.8621.1636
    System.Net.WebClient.dll                         .\System.Net.WebClient.dll, version=7.0.1023.36312
    System.ComponentModel.EventBasedAsync.dll        .\System.ComponentModel.EventBasedAsync.dll, version=7.0.1023.36312
    System.Memory.dll                                .\System.Memory.dll, version=7.0.1023.36312
    System.Text.Encoding.Extensions.dll              .\System.Text.Encoding.Extensions.dll, version=7.0.1023.36312
    System.Drawing.Common.dll                        .\System.Drawing.Common.dll, version=7.0.1023.36312
    Microsoft.Win32.SystemEvents.dll                 .\Microsoft.Win32.SystemEvents.dll, version=7.0.1023.36312
    System.Collections.Immutable.dll                 .\System.Collections.Immutable.dll, version=7.0.1023.36312
    PaintDotNet.Resources.dll                        .\PaintDotNet.Resources.dll, version=5.9.8621.1636
    Microsoft.Win32.Registry.dll                     .\Microsoft.Win32.Registry.dll, version=7.0.1023.36312
    System.Linq.dll                                  .\System.Linq.dll, version=7.0.1023.36312
    System.Diagnostics.FileVersionInfo.dll           .\System.Diagnostics.FileVersionInfo.dll, version=7.0.1023.36312
    ComputeSharp.D2D1.dll                            .\ComputeSharp.D2D1.dll, version=2.0.3.0
    System.Security.Principal.Windows.dll            .\System.Security.Principal.Windows.dll, version=7.0.1023.36312
    System.Security.Claims.dll                       .\System.Security.Claims.dll, version=7.0.1023.36312
    System.ComponentModel.TypeConverter.dll          .\System.ComponentModel.TypeConverter.dll, version=7.0.1023.36312
    PresentationCore.dll                             .\PresentationCore.dll, version=7.0.1023.36404
    DirectWriteForwarder.dll                         .\DirectWriteForwarder.dll, version=7,0,1023,36404 @Commit: 9a9892f5204f1a1b31ab2c81b025d6e35e0f3693
    PaintDotNet.Windows.Core.dll                     .\PaintDotNet.Windows.Core.dll, version=5.9.8621.1636
    System.Runtime.Extensions.dll                    .\System.Runtime.Extensions.dll, version=7.0.1023.36312
    System.Diagnostics.Debug.dll                     .\System.Diagnostics.Debug.dll, version=7.0.1023.36312
    System.Runtime.CompilerServices.VisualC.dll      .\System.Runtime.CompilerServices.VisualC.dll, version=7.0.1023.36312
    dwrite.dll                                       C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Collections.NonGeneric.dll                .\System.Collections.NonGeneric.dll, version=7.0.1023.36312
    Accessibility.dll                                .\Accessibility.dll, version=7.0.1023.36405
    PaintDotNet.PropertySystem.dll                   .\PaintDotNet.PropertySystem.dll, version=5.9.8621.1636
    PaintDotNet.Effects.Core.dll                     .\PaintDotNet.Effects.Core.dll, version=5.9.8621.1636
    System.IO.Packaging.dll                          .\System.IO.Packaging.dll, version=7.0.1023.36312
    UIAutomationTypes.dll                            .\UIAutomationTypes.dll, version=7.0.1023.36404
    System.Numerics.Vectors.dll                      .\System.Numerics.Vectors.dll, version=7.0.1023.36312
    PointerToolkit.TerraFX.Interop.Windows.dll       .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.22621.2
    Crc32.NET.dll                                    .\Crc32.NET.dll, version=1.2.0.5
    System.Security.Cryptography.dll                 .\System.Security.Cryptography.dll, version=7.0.1023.36312
    System.Threading.Tasks.Parallel.dll              .\System.Threading.Tasks.Parallel.dll, version=7.0.1023.36312
    PaintDotNet.Effects.Gpu.dll                      .\PaintDotNet.Effects.Gpu.dll, version=5.9.8621.1636
    System.Threading.ThreadPool.dll                  .\System.Threading.ThreadPool.dll, version=7.0.1023.36312
    dxgi.DLL                                         C:\WINDOWS\SYSTEM32\dxgi.DLL, version=10.0.22621.2215 (WinBuild.160101.0800)
    MSCTF.dll                                        C:\WINDOWS\System32\MSCTF.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    dxcore.dll                                       C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.22621.1778 (WinBuild.160101.0800)
    directxdatabasehelper.dll                        C:\WINDOWS\SYSTEM32\directxdatabasehelper.dll, version=10.0.22621.2215 (WinBuild.160101.0800)
    profapi.dll                                      C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    version.dll                                      C:\WINDOWS\SYSTEM32\version.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    d3d11.DLL                                        C:\WINDOWS\SYSTEM32\d3d11.DLL, version=10.0.22621.2070 (WinBuild.160101.0800)
    d2d1.DLL                                         C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    nvldumdx.dll                                     C:\WINDOWS\System32\DriverStore\FileRepository\nvae.inf_amd64_fdabed922efb6704\nvldumdx.dll, version=30.0.14.7280
    msasn1.dll                                       C:\WINDOWS\SYSTEM32\msasn1.dll, version=10.0.22621.819 (WinBuild.160101.0800)
    cryptnet.dll                                     C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    CRYPT32.dll                                      C:\WINDOWS\System32\CRYPT32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    drvstore.dll                                     C:\WINDOWS\SYSTEM32\drvstore.dll, version=10.0.22621.2070 (WinBuild.160101.0800)
    devobj.dll                                       C:\WINDOWS\SYSTEM32\devobj.dll, version=10.0.22621.1344 (WinBuild.160101.0800)
    cfgmgr32.dll                                     C:\WINDOWS\SYSTEM32\cfgmgr32.dll, version=10.0.22621.1344 (WinBuild.160101.0800)
    wldp.dll                                         C:\WINDOWS\SYSTEM32\wldp.dll, version=10.0.22621.2070 (WinBuild.160101.0800)
    cryptbase.dll                                    C:\WINDOWS\SYSTEM32\cryptbase.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    gdiplus.dll                                      C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.22621.1778_none_57fe2016ce1542ec\gdiplus.dll, version=10.0.22621.1778 (WinBuild.160101.0800)
    clbcatq.dll                                      C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    WINTRUST.DLL                                     C:\WINDOWS\System32\WINTRUST.DLL, version=10.0.22621.2070 (WinBuild.160101.0800)
    WindowsCodecs.dll                                C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.22621.1635 (WinBuild.160101.0800)
    imagehlp.dll                                     C:\WINDOWS\System32\imagehlp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    UIAnimation.dll                                  C:\WINDOWS\System32\UIAnimation.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    XmlLite.dll                                      C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.22621.608 (WinBuild.160101.0800)
    comctl32.dll                                     C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.22621.2215_none_270d72677387dfc3\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    CRYPTSP.dll                                      C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    rsaenh.dll                                       C:\WINDOWS\system32\rsaenh.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    nvwgf2umx.dll                                    C:\WINDOWS\System32\DriverStore\FileRepository\nvae.inf_amd64_fdabed922efb6704\nvwgf2umx.dll, version=30.0.14.7280
    WINMM.dll                                        C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    nvspcap64.dll                                    C:\WINDOWS\system32\nvspcap64.dll, version=3.20.3.63
    ntmarta.dll                                      C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    TextShaping.dll                                  C:\WINDOWS\SYSTEM32\TextShaping.dll, version=10.0.22621.1635 (WinBuild.160101.0800)
    System.Runtime.Loader.dll                        .\System.Runtime.Loader.dll, version=7.0.1023.36312
    mfplat.dll                                       C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    RTWorkQ.DLL                                      C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    CompPkgSup.DLL                                   C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.22621.2215 (WinBuild.160101.0800)
    Windows.StateRepositoryPS.dll                    C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    WebPFileType.dll                                 .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.19.0
    AvifFileType.dll                                 .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.25.0
    DdsFileTypePlus.dll                              .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.12.2.0
    PaintDotNet.Effects.dll                          .\PaintDotNet.Effects.dll, version=5.9.8621.1636
    System.Reflection.Metadata.dll                   .\System.Reflection.Metadata.dll, version=7.0.1023.36312
    System.IO.MemoryMappedFiles.dll                  .\System.IO.MemoryMappedFiles.dll, version=7.0.1023.36312
    Mono.Cecil.dll                                   .\Mono.Cecil.dll, version=0.11.5.0
    netstandard.dll                                  .\netstandard.dll, version=7.0.1023.36312
    wtsapi32.dll                                     C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WINSTA.dll                                       C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.22621.1635 (WinBuild.160101.0800)
    PaintDotNet.Effects.Legacy.dll                   .\PaintDotNet.Effects.Legacy.dll, version=5.9.8621.1636
    D3D10Warp.dll                                    C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.22621.1194 (WinBuild.160101.0800)
    System.Reflection.MetadataLoadContext.dll        .\System.Reflection.MetadataLoadContext.dll, version=7.0.22.51805
    BBChart.dll                                      C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\BBChart.dll, version=1.1.0.0
    amsi.dll                                         C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    USERENV.dll                                      C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Windows.Forms.DataVisualization.dll       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\System.Windows.Forms.DataVisualization.dll, version=1.0.20.11001
    eamsi.dll                                        C:\Program Files\ESET\ESET Security\eamsi.dll, version=10.36.10.0 BETA
    Calendar.dll                                     C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Calendar.dll, version=6.0.8478.32276
    BandWPlus.dll                                    C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\BandWPlus.dll, version=6.0.8407.21940
    Burninate.dll                                    C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Burninate.dll, version=6.0.8407.22069
    BBOutlinedGradientText.dll                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\BBOutlinedGradientText.dll, version=6.0.8426.37652
    CombinedAdjustments.dll                          C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\CombinedAdjustments.dll, version=6.0.8407.22130
    VignettePlus.dll                                 C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\VignettePlus.dll, version=6.0.8407.22549
    Alpha2Gray.dll                                   C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Alpha2Gray.dll, version=6.0.8407.21872
    ApplyMask.dll                                    C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\ApplyMask.dll, version=6.0.8609.2294
    ColorBalance.dll                                 C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\ColorBalance.dll, version=6.0.8407.22111
    mscorlib.dll                                     .\mscorlib.dll, version=7.0.1023.36312
    System.dll                                       .\System.dll, version=7.0.1023.36312
    System.Drawing.dll                               .\System.Drawing.dll, version=7.0.1023.36405
    System.Resources.Extensions.dll                  .\System.Resources.Extensions.dll, version=7.0.1023.36312
    Transparency.dll                                 C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Transparency.dll, version=6.0.8407.22532
    CreativeTextPro.dll                              C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\CreativeTextPro.dll, version=6.0.8407.22165
    ComplementaryColors.dll                          C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\ComplementaryColors.dll, version=6.0.8407.23961
    Dream.dll                                        C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Dream.dll, version=6.0.8414.36727
    Dimensions.dll                                   C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Dimensions.dll, version=1.3.6826.38472
    FillFromClipboard.dll                            C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\FillFromClipboard.dll, version=6.0.8407.22397
    FillFromFile.dll                                 C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\FillFromFile.dll, version=6.0.8407.22418
    EdgeDetectClassic.dll                            C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\EdgeDetectClassic.dll, version=1.0.8424.19432
    Flip.dll                                         C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Flip.dll, version=4.6.7358.36953
    GaussianBlurPlus.dll                             C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401
    FloydSteinbergDithering.dll                      C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\FloydSteinbergDithering.dll, version=5.2.8174.39918
    Gray2Alpha.dll                                   C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Gray2Alpha.dll, version=6.0.8407.22439
    GridCheckerboard.dll                             C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\GridCheckerboard.dll, version=5.2.8141.24786
    HueSatPlus.dll                                   C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\HueSatPlus.dll, version=5.2.8174.40274
    Landscape.dll                                    C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Landscape.dll, version=5.2.8174.40347
    LevelHorizon.dll                                 C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\LevelHorizon.dll, version=6.0.8407.22459
    MemeMaker.dll                                    C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\MemeMaker.dll, version=6.0.8407.22476
    ObjectTools.dll                                  C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\ObjectTools.dll, version=6.0.8482.2565
    OilPaintingPlus.dll                              C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\OilPaintingPlus.dll, version=5.2.8141.27893
    Pastel.dll                                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Pastel.dll, version=5.2.8174.40506
    PasteAlpha.dll                                   C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\PasteAlpha.dll, version=5.2.8174.40450
    PhotoAdjustments.dll                             C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\PhotoAdjustments.dll, version=6.0.8416.38377
    RemoveDust.dll                                   C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\RemoveDust.dll, version=6.0.8407.22513
    SeamCarving.dll                                  C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\SeamCarving.dll, version=5.2.8176.39366
    SharpenClassic.dll                               C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\SharpenClassic.dll, version=1.0.8420.39106
    SelectionTools.dll                               C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\SelectionTools.dll, version=6.0.8412.38725
    Smudge.dll                                       C:\Users\micki\OneDrive\Documents\paint.net App Files\Effects\Smudge.dll, version=4.1.8581.29577
    UIAutomationCore.dll                             C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.22621.1 (WinBuild.160101.0800)
    dwmapi.DLL                                       C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    dataexchange.dll                                 C:\WINDOWS\system32\dataexchange.dll, version=10.0.22621.2070 (WinBuild.160101.0800)
    twinapi.appcore.dll                              C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    textinputframework.dll                           C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.22621.2215 (WinBuild.160101.0800)
    CoreMessaging.dll                                C:\WINDOWS\SYSTEM32\CoreMessaging.dll, version=10.0.22621.1635 (WinBuild.160101.0800)
    CoreUIComponents.dll                             C:\WINDOWS\SYSTEM32\CoreUIComponents.dll, version=10.0.22621.2215
    powrprof.dll                                     C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    UMPDC.dll                                        C:\WINDOWS\SYSTEM32\UMPDC.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Runtime.Serialization.Formatters.dll      .\System.Runtime.Serialization.Formatters.dll, version=7.0.1023.36312
    System.Text.RegularExpressions.dll               .\System.Text.RegularExpressions.dll, version=7.0.1023.36312
    PaintDotNet.SystemLayer.Native.x64.dll           .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.9.8621.1636
    System.Runtime.Intrinsics.dll                    .\System.Runtime.Intrinsics.dll, version=7.0.1023.36312
    PhotoSauce.MagicScaler.dll                       .\PhotoSauce.MagicScaler.dll, version=0.13.2.0
    explorerframe.dll                                C:\WINDOWS\system32\explorerframe.dll, version=10.0.22621.608 (WinBuild.160101.0800)
    PROPSYS.dll                                      C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.22621.2070 (WinBuild.160101.0800)
    ComputeSharp.Core.dll                            .\ComputeSharp.Core.dll, version=2.0.3.0
    d3dcompiler_47.DLL                               C:\WINDOWS\SYSTEM32\d3dcompiler_47.DLL, version=10.0.22621.608 (WinBuild.160101.0800)
    Cabinet.dll                                      C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800)
    dcomp.dll                                        C:\WINDOWS\SYSTEM32\dcomp.dll, version=10.0.22621.2215 (WinBuild.160101.0800)
    Newtonsoft.Json.dll                              .\Newtonsoft.Json.dll, version=13.0.3.27908
    System.Linq.Expressions.dll                      .\System.Linq.Expressions.dll, version=7.0.1023.36312
    System.IO.Compression.dll                        .\System.IO.Compression.dll, version=7.0.1023.36312
    setupapi.DLL                                     C:\WINDOWS\System32\setupapi.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
It's crashing for me as well. It happens as soon as I click.
Exception details:
System.NullReferenceException: Object reference not set to an instance of an object.
   at pyrochild.effects.smudge.SmudgeRenderer.OnMouseDown(QueuedToolEventArgs le)
   at pyrochild.effects.common.QueuedToolRenderer.Render()
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
--- End of stack trace from previous location ---
I am not able to reproduce that crash.
Here is a new build with a PDB file, which should give me the line numbers for that crash.
Replaced by the version at: https://forums.getpaint.net/topic/10634-smudge/?do=findComment&comment=612879
