Mike Ryan Posted December 30, 2008 Share Posted December 30, 2008 Sometimes I feel as though this would be better as a layer blending mode, but still is very useful. Thanks again, Pyrochild Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted December 30, 2008 Share Posted December 30, 2008 Blending modes are fairly simple calculations that are based on a comparison of pixels at a specific position. This is a very different concept. Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
pyrochild Posted December 30, 2008 Author Share Posted December 30, 2008 Sometimes I feel as though this would be better as a layer blending mode I don't understand what you mean. Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Simon Brown Posted December 30, 2008 Share Posted December 30, 2008 If the user has two layers: the origional layer and the source layer, instead of having to save the source layer and run your plugin they would be able to simply change the blend mode of the source layer to act as that on the layers below. Quote Link to comment Share on other sites More sharing options...
pyrochild Posted December 30, 2008 Author Share Posted December 30, 2008 In that case, barkbark00 is right. That's not what blend modes are designed for. The blend-mode architecture would have to be completely redesigned, and performance would likely be hideous. Blend modes compare a single pixel with the pixel at the same coordinates on the layer below. One simple, quick calculation per pixel. Color Match has to scan the entire source image before any changes can be applied to the destination canvas. Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Mike Ryan Posted December 31, 2008 Share Posted December 31, 2008 Didn't realise the discussion I had created :oops: I wasn't suggesting doing it, I said it would be better as a blending mode, I know it isn't feasibly possible. Just talking Quote Link to comment Share on other sites More sharing options...
pyrochild Posted December 31, 2008 Author Share Posted December 31, 2008 I think you mean it would be better as an Adjustment Layer, not a blend mode. And yes, it would be neat as an adjustment layer. Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
pyrochild Posted November 8, 2009 Author Share Posted November 8, 2009 Updated for compatibility with Paint.NET v3.5. The only change, actually, was the version number, since Paint.NET now blocks version 1.0. Go figure. Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
SonicPikachu25 Posted February 11, 2010 Share Posted February 11, 2010 Not sure if this counts as necroposting but..I downloaded Colormatch. I tried it. Clicked the 'Browse' and got a crashlog for an "unhandled error". I read all the replys on this topic and downloaded the pyrochild.effects.common.dll (again ). Tried again. Did not work. Downloaded the effect (again). Did not work. Downloaded Pyrochild pack (again ) and tried. Guess what? Didn't work. (And BTW, I know how to install plugins :wink: ) Sent the crashlog every time. Are there any other known problems than the missing pyrochild.etc.dll? EDIT: Tried again once more and now it worked.. :shock: I should complain about things more often Thanks nonetheless I had the same problem,but I recently figured out that you don't have to click 'Browse' as long as the picture's in the clipboard.GREAT PLUG-IN Pyrochild! Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 15, 2010 Share Posted February 15, 2010 There was a change in v3.5.3 that causes Browse to crash. Now, of course this is in code that isn't "for plugin use" but the fix is easy enough ... v3.5.4 will fix this without needing a new version of this plugin. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
DiYanira Posted February 15, 2010 Share Posted February 15, 2010 Not sure if this counts as necroposting but..I downloaded Colormatch. I tried it. Clicked the 'Browse' and got a crashlog for an "unhandled error". I read all the replys on this topic and downloaded the pyrochild.effects.common.dll (again ). Tried again. Did not work. Downloaded the effect (again). Did not work. Downloaded Pyrochild pack (again ) and tried. Guess what? Didn't work. (And BTW, I know how to install plugins :wink: ) Sent the crashlog every time. Are there any other known problems than the missing pyrochild.etc.dll? The same thing happened to me since the last update of paint.net. it happens all the time. Any help is wellcome. Quote Link to comment Share on other sites More sharing options...
pyrochild Posted February 15, 2010 Author Share Posted February 15, 2010 Oops, I never noticed. Didn't see the bug report either, apparently. For now, use the workaround of copying the source image into the clipboard and using that instead of browsing for it. Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
DiYanira Posted February 15, 2010 Share Posted February 15, 2010 Thanks, the copy and paste, does the trick. Quote Link to comment Share on other sites More sharing options...
etaye Posted November 19, 2020 Share Posted November 19, 2020 THIS IS THE ERROR CODE I GOT PLEASE HELP! This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem. Application version: paint.net 4.2.14 (Final 4.214.7601.39231) Time of crash: 11/19/2020 12:44:29 AM Application uptime: 00:00:56.7089990 Application state: Running Working set: 236,280 KiB Handles and threads: 1210 handles, 41 threads, 162 gdi, 231 user Install type: Classic Application directory: C:\Program Files\paint.net Current directory: C:\Program Files\paint.net Install directory: C:\Program Files\paint.net OS Version: Windows 10 Home 10.0.19041.0 x64 (0x65) .NET version: CLR 4.0.30319.42000 x64 Processor: "AMD A4-5000 APU with Radeon(TM) HD Graphics " @ ~1497MHz (4C/4T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX) Physical memory: 5580 MB Video card: AMD Radeon HD 8330 (v:1002, d:9832, r:0), Microsoft Basic Render Driver (v:1414, d:8C, r:0) Hardware acceleration: True (default: True) Pointers: none UI animations: True UI DPI: 96 dpi (1.00x scale) UI theme: VisualStyleClass=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Dark, ThemeFileName=Aero.msstyles Updates: True, 11/19/2020 (journal: ShouldCheckForUpdate, CheckedForUpdate) Locale: pdnr.c: en-US, hklm: en-US, hkcu: en-US, cc: en-US, cuic: en-US Flags: Exception details: System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values. Parameter name: source.Size=3,1, newSize=240,80, but the new size must be smaller at PaintDotNet.Rendering.ResizeSuperSamplingRendererBgra..ctor(IRenderer`1 source, Int32 newWidth, Int32 newHeight) in D:\src\pdn\src\Core\Rendering\ResizeSuperSamplingRendererBgra.cs:line 30 at PaintDotNet.Rendering.RendererBgraExtensions.ResizeSuperSampling(IRenderer`1 source, Int32 newWidth, Int32 newHeight) in D:\src\pdn\src\Core\Rendering\RendererBgraExtensions.cs:line 139 at PaintDotNet.Rendering.RendererBgraExtensions.ResizeSuperSampling(IRenderer`1 source, SizeInt32 newSize) in D:\src\pdn\src\Core\Rendering\RendererBgraExtensions.cs:line 126 at PaintDotNet.Surface.FitSurface(ResamplingAlgorithm algorithm, Surface source, Rectangle dstRoi, Boolean useMultiCore) in D:\src\pdn\src\Core\Surface.cs:line 1617 at pyrochild.effects.colormatch.ConfigDialog.loadImage(Surface image) at pyrochild.effects.colormatch.ConfigDialog.<picThumb_MouseClick>b__0(Object s, EventArgs ea) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Managed assemblies: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll PaintDotNet, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.exe PaintDotNet.Core, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Core.dll PaintDotNet.Base, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Base.dll WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_64\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll PaintDotNet.SystemLayer, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.dll PaintDotNet.Framework, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Framework.dll PaintDotNet.Resources, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Resources.dll PaintDotNet.Effects, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Effects.dll PaintDotNet.Data, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Data.dll PaintDotNet.SystemLayer.Native.x64, Version=4.214.7601.39231, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll System.Runtime.CompilerServices.Unsafe, Version=4.0.6.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Program Files\paint.net\System.Runtime.CompilerServices.Unsafe.dll System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll DdsFileTypePlus, Version=1.10.7.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll WebPFileType, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Bundled\WebPFileType\WebPFileType.dll AvifFileType, Version=1.1.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Bundled\AvifFileType\AvifFileType.dll System.Collections.Immutable, Version=1.2.5.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Program Files\paint.net\System.Collections.Immutable.dll System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 @ C:\Program Files\paint.net\System.Buffers.dll System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 @ C:\Program Files\paint.net\System.Memory.dll "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AA's_Assistant.dll AlphaBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlphaBlur.dll Alpha_to_0, Version=1.0.4452.22746, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha_to_0.dll Alpha_to_255, Version=1.0.4452.22782, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha_to_255.dll BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BlackandAlpha+.dll CircleText, Version=1.4.4415.32488, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CircleText.dll dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\dpyColorBalance.dll Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Metallize.dll MultiThreshold, Version=1.1.4330.38982, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MultiThreshold.dll Perspective, Version=2.1.4415.36116, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Perspective.dll pxEexpansion, Version=1.0.4437.36287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\pxEexpansion.dll RotateText, Version=1.1.4415.32628, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RotateText.dll RotateTextSUI, Version=1.1.4415.32713, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RotateTextSUI.dll Rotate_Zoom+, Version=1.11.5237.17779, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Rotate_Zoom+.dll SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpeechBubble.dll SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpiralText.dll TextPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Textplus.dll WaveText, Version=1.2.4415.32811, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WaveText.dll WaveTextSUI, Version=1.2.4415.33440, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WaveTextSUI.dll Alpha2Gray, Version=4.5.6832.21862, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Alpha2Gray.dll BandWPlus, Version=1.1.6909.27136, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\BandWPlus.dll OutlinedGradientText, Version=1.1.6826.41783, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\BBOutlinedGradientText.dll "Borders N' Shapes", Version=4.0.4642.26476, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Borders N' Shapes.dll Burninate, Version=4.5.6827.39185, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Burninate.dll Calendar, Version=4.6.6909.25747, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Calendar.dll Color Match, Version=4.0.4642.26532, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Color Match.dll ColorBalance, Version=4.5.6832.41698, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\ColorBalance.dll Curves+, Version=4.0.6119.31044, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Curves+.dll Dimensions, Version=1.3.6826.38472, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Dimensions.dll Dream, Version=4.5.6832.41729, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Dream.dll FillFromClipboard, Version=4.6.6909.25430, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\FillFromClipboard.dll FillFromFile, Version=4.6.6909.24920, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\FillFromFile.dll Film, Version=4.0.4642.26607, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Film.dll Flip, Version=4.5.6832.41809, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Flip.dll FloydSteinbergDithering, Version=4.5.6828.38953, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\FloydSteinbergDithering.dll GaussianBlurPlus, Version=4.2.5691.27401, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\GaussianBlurPlus.dll Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Gradient Bars.dll Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Gradient Blocks.dll Gradient Grid, Version=4.0.6436.36068, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Gradient Grid.dll Gradient Mapping, Version=4.0.6547.33963, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Gradient Mapping.dll Gray2Alpha, Version=4.5.6826.36897, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Gray2Alpha.dll Grid Warp, Version=4.0.6544.34496, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Grid Warp.dll GridCheckerboard, Version=4.5.6828.36789, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\GridCheckerboard.dll HSVGradients, Version=4.5.6832.41864, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\HSVGradients.dll HueSatPlus, Version=4.5.6832.41926, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\HueSatPlus.dll Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Jitter.dll Landscape, Version=4.5.6826.38591, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Landscape.dll LevelHorizon, Version=4.5.6826.37471, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\LevelHorizon.dll Liquify, Version=4.0.5873.25113, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Liquify.dll MemeMaker, Version=4.5.6828.38061, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\MemeMaker.dll ObjectTools, Version=4.5.6832.42044, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\ObjectTools.dll OilPaintingPlus, Version=4.5.6832.21777, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\OilPaintingPlus.dll Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\OldFeather.dll Outline Object, Version=4.0.4642.26954, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Outline Object.dll PasteAlpha, Version=4.5.6826.36532, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\PasteAlpha.dll Pastel, Version=4.5.6832.42132, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Pastel.dll PhotoAdjustments, Version=4.5.6826.37237, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\PhotoAdjustments.dll Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Pixelate+.dll Polygon, Version=4.5.6828.38648, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Polygon.dll Random Effect, Version=4.0.4642.26928, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Random Effect.dll Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Random Shape Fill.dll RemoveDust, Version=4.5.6826.37862, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\RemoveDust.dll ScriptLab, Version=4.0.6107.18914, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\ScriptLab.dll SeamCarving, Version=4.5.6838.35770, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\SeamCarving.dll SelectionTools, Version=4.5.6832.22117, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\SelectionTools.dll Smudge, Version=4.0.5873.25097, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Smudge.dll Splatter, Version=4.0.5873.25083, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Splatter.dll Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Stitch.dll Temperature, Version=4.5.6832.41128, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Temperature.dll Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Trail.dll Transparency, Version=4.5.6832.41213, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Transparency.dll Twist, Version=4.0.5873.25056, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\Twist.dll VignettePlus, Version=4.5.6826.39332, Culture=neutral, PublicKeyToken=null @ C:\Users\Owner\Documents\paint.net App Files\Effects\VignettePlus.dll Interop.WIA, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Interop.WIA.dll Native modules: C:\Program Files\paint.net\PaintDotNet.exe, version=4.214.7601.39231 C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\KERNEL32.dll, version=10.0.19041.329 (WinBuild.160101.0800) C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.388 (WinBuild.160101.0800) C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.8.4180.0 built by: NET48REL1LAST_B C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.8.4250.0 built by: NET48REL1LAST_C C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\win32u.dll, version=10.0.19041.630 (WinBuild.160101.0800) C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.572 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\VCRUNTIME140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\ucrtbase_clr0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\psapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\52ce2de93895cec3507794c893974551\mscorlib.ni.dll, version=4.8.4250.0 built by: NET48REL1LAST_C C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\combase.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\Program Files (x86)\Razer\Razer Cortex\x64\k_fps64.dll, version=3.0.14.7 C:\Program Files (x86)\Razer\Razer Cortex\x64\d3dx10_43.dll, version=9.29.952.3111 C:\Program Files (x86)\Razer\Razer Cortex\x64\EasyHook64.dll, version=2.7.6270.0 C:\Program Files (x86)\Razer\Razer Cortex\x64\D3DCOMPILER_43.dll, version=9.29.952.3111 C:\Program Files (x86)\Razer\Razer Cortex\x64\d3dx9_43.dll, version=9.29.952.3111 C:\WINDOWS\SYSTEM32\OPENGL32.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\dbghelp.dll, version=10.0.19041.488 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\GLU32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\bed865b5a7c329e06f8d4f1be9009e05\System.ni.dll, version=4.8.4200.0 built by: NET48REL1LAST_C C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\8ddf3ec2af8179fd914eb931e0df0ccb\System.Core.ni.dll, version=4.8.4270.0 built by: NET48REL1LAST_C C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\e4036df55a675cb51d3ff2089ddd87c8\WindowsBase.ni.dll, version=4.8.4270.0 built by: NET48REL1LAST_C C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\b7cd29e6d9511037c3b4c948348f87f0\System.Drawing.ni.dll, version=4.8.4084.0 built by: NET48REL1 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\808e03398604dd0b3ce92f7418229cc2\PresentationCore.ni.dll, version=4.8.4270.0 built by: NET48REL1LAST_C C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\13619a0ae7a2cd86b853b0bb98d2c45f\PresentationFramework.ni.dll, version=4.8.4270.0 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\86c0a7a7d1e1dc2e1e40014ab910cf7d\PaintDotNet.Base.ni.dll, version=4.214.7601.39231 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\630315125a5d3ca463ccb782604057fd\System.Windows.Forms.ni.dll, version=4.8.4270.0 built by: NET48REL1LAST_C C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\510cfe67b9c1d12327b4f00d05734e69\PaintDotNet.SystemLayer.ni.dll, version=4.214.7601.39231 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\a52984abd1e3fbab1fd94053aa53d7be\PaintDotNet.Core.ni.dll, version=4.214.7601.39231 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\10ae1e90ca2fede3f4067a709b1878a7\PaintDotNet.Resources.ni.dll, version=4.214.7601.39231 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\1a2c9e92909b5e3f5920fdae875fa92c\PaintDotNet.Framework.ni.dll, version=4.214.7601.39231 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\bc88e64e0aca19297a90230b4b20cfe5\PaintDotNet.Data.ni.dll, version=4.214.7601.39231 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\b93b811493593b426778d3b7a21030ad\PaintDotNet.Effects.ni.dll, version=4.214.7601.39231 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\8c3def6736839f60cfc91e72b0ae4d23\PaintDotNet.ni.exe, version=4.214.7601.39231 C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.8.4270.0 built by: NET48REL1LAST_C C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\MSVCP140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.8.4270.0 built by: NET48REL1LAST_C C:\WINDOWS\System32\shell32.dll, version=10.0.19041.329 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\Program Files\paint.net\Native\X64\vcruntime140.dll, version=14.27.29016.0 built by: vcwrkspc C:\Program Files\paint.net\Native\X64\vcruntime140_1.dll, version=14.27.29016.0 built by: vcwrkspc C:\Program Files\paint.net\Native\X64\msvcp140.dll, version=14.27.29016.0 built by: vcwrkspc C:\Program Files\paint.net\Native\X64\msvcp140_1.dll, version=14.27.29016.0 built by: vcwrkspc C:\Program Files\paint.net\Native\X64\msvcp140_2.dll, version=14.27.29016.0 built by: vcwrkspc C:\Program Files\paint.net\Native\X64\msvcp140_codecvt_ids.dll, version=14.27.29016.0 built by: vcwrkspc C:\Program Files\paint.net\Native\X64\vcomp140.dll, version=14.27.29016.0 built by: vcwrkspc C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\812e8cdc72253190be6b7737000e1c3a\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.214.7601.39231 C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.214.7601.39231 C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.630_none_fae7a41d761b04f0\gdiplus.dll, version=10.0.19041.630 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\d009016debb7fc819e3af2aed519f178\System.Configuration.ni.dll, version=4.8.4190.0 built by: NET48REL1LAST_B C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\668fdf02bf8ce2501c89341d7323b0c5\System.Xml.ni.dll, version=4.8.4084.0 built by: NET48REL1 C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Runtea61dfd5#\313b14292b4006714eefaf0d0824e2d8\System.Runtime.CompilerServices.Unsafe.ni.dll, version=4.700.20.12001 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\dc6604658d7fb44c7e21db7187a5ec9a\System.Xaml.ni.dll, version=4.8.4270.0 built by: NET48REL1LAST_C C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.8.4250.0 built by: NET48REL1LAST_C C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.488_none_ca04af081b815d21\comctl32.dll, version=6.10 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.546 (WinBuild.160101.0800) C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\TextShaping.dll, version= C:\Windows\System32\WinTypes.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Coll4a4f96a7#\564b80b8b1a396cc766f91f56e65f069\System.Collections.Immutable.ni.dll, version=4.700.20.21406 C:\WINDOWS\SYSTEM32\dwmapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.610 (WinBuild.160101.0800) C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.610 C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\UMPDC.dll, version= C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Buffers\dfd707b88be85ab41250d8c490d4bb39\System.Buffers.ni.dll, version=4.6.28619.01 C:\WINDOWS\SYSTEM32\winmm.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Memory\9d5bf43e2d9d748dcb6e1f24190cf513\System.Memory.ni.dll, version=4.6.28619.01 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.8.4084.0 built by: NET48REL1 C:\WINDOWS\SYSTEM32\aticfx64.dll, version=8.17.10.1404 C:\WINDOWS\SYSTEM32\atiuxp64.dll, version=8.14.01.6463 C:\WINDOWS\SYSTEM32\atidxx64.dll, version=8.17.10.0625 C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\winhttp.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\NSI.dll, version=10.0.19041.610 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\rasapi32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\rasman.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\rtutils.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\system32\mswsock.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\DNSAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\WINNSI.DLL, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\Windows\System32\rasadhlp.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\fwpuclnt.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\secur32.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\SSPICLI.DLL, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\system32\schannel.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\mskeyprotect.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\NTASN1.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\ncrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\system32\ncryptsslp.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\crypt32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\MSASN1.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\policymanager.dll, version=10.0.19041.610 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\msvcp110_win.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Interop.WIA\8bcc49b52f2f866b3e44b9bec0fdadb3\Interop.WIA.ni.dll, version=1.0.0.0 C:\WINDOWS\System32\wiaaut.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\wiatrace.dll, version=10.0.19041.450 (WinBuild.160101.0800) C:\Windows\System32\sti.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\edputil.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\SetupApi.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.630 (WinBuild.160101.0800) ------------------------------------------------------------------------------ Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 19, 2020 Share Posted November 19, 2020 This is a bug in @pyrochild's plugin. I have already implemented an internal workaround for the 4.2.15 release of the app, but @pyrochild may be able to suggest another workaround in the meantime. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
pyrochild Posted November 21, 2020 Author Share Posted November 21, 2020 New version of Color Match is available in my pack which should fix the crash when the source image is smaller than the thumbnail 1 Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
NoobFragged Posted February 22, 2021 Share Posted February 22, 2021 I downloaded this plugin (well the whole set) and it's been working for the past couple days. Now suddenly it's going crazy and the matches are absurd and not alike at all. The colors are very saturated and it's not really functioning like it should but there doesn't seem to be any settings to reset. For some reason it won't insert this image into the post but here's a picture of what it's doing.https://ibb.co/d2WC8Ww Quote Link to comment Share on other sites More sharing options...
