PFH1987 Posted December 22, 2015 Share Posted December 22, 2015 Hello, I have been using Paint.net for years and love it. I am an electrical engineer and I have recently started using it to do my layouts for the Human Machine Interface (HMI). In order to do this I need to be able to control the sizes of shapes eg. rectangles, circles to specific dimensions. Is there a method or a plugin that allows this? Other then looking at the dimension in the corner and draging until it is correct. Quote Link to comment Share on other sites More sharing options...
Zagna Posted December 22, 2015 Share Posted December 22, 2015 I think a better tool to do this would be either an UML designer or vector drawing. With something like Inkscape, you could create a set of shapes and other objects that you could simply keep duplicating to the drawing area without having to recreate them. They could even be linked so edits to one instance affects all and many other features. 1 Quote Link to comment Share on other sites More sharing options...
