misconduct3 Posted June 10, 2008 Share Posted June 10, 2008 P is there anyway to convert this tutorial over to paint.net? i like using the glitter-fills for my siggies and there so many to chosse from! thanx in advance and soprry to be such a pain in the butt:)here is the tutorial i want to convert if possible: i use unfreeze to animate glitter text and so on but i also have animation shop 3 as well.... glitter text tutorial for the newer versions of psp here goes: You will need PSP, Animation Shop(AS) and a glitter fill ( you can google for them) 1. Open the glitter fill in AS 2. Select all 3 frames 3. click on file and choose SAVE FRAMES AS and save them in a folder ( i have a special fold just for open glitters) Then you go to your PSP and open all 3 glitter frames when you do this they will be in your fill colors when you need them no you need to type the text you want filled (open new and then use your text tool to make the text) merge flatten so the text and background are one id needed Make 3 layers of the siggy (copy and paste as new layer twice) now using the magic wand choose the part of the text you want glittered once selected make 2 layers invisable by clicking on the eye make sure you have selected the open eyed layer now select your fill tool and choose your first glitter frame fill in the visable layer of the siggy with the first glitter fill REPEAT THIS STEP BY HIDING THE DONE LAYER AND MAKING THE NEXT VISABLE ( ONLY HAVE ONE VISABLE AT A TIME) 2ND LAYER YOU FILL WITH GLITTER FRAME 2 AND THE 3RD FILL WITH GLITTER FFRAME 3 WHEN ALL 3 LAYERS ARE FILLED WITH THEIR OWN GLITTER FRAME MAKE ALL LAYERS VISABLE AND YOU WILL NEED TO CHOOSE FILE> SAVE AS you will need to save this as a PSP ANIMATION FILE You will then need to open up this PSP ANIMATION FILE in Animation Shop once you have it open in AS Chose VIEW>ANIMATION YOU WILL NO SEE YOU GLITTER ANIMATED NOW YOU NEED TO CHOOSE FILE>SAVE AS and it will take you though a save wizard..... save it at its best quality ( bar all the way up) and then just click next, next next till its saved. Quote Link to comment Share on other sites More sharing options...
brandon.roeder Posted June 10, 2008 Share Posted June 10, 2008 Do you have a picture of what the final product is supposed to look like? Quote My DA|My Gallery|My Website Link to comment Share on other sites More sharing options...
BoltBait Posted June 10, 2008 Share Posted June 10, 2008 Or, can you give us a link to the original tutorial? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
D3z Posted June 11, 2008 Share Posted June 11, 2008 There is a tutorial for some basic glitter here. Is that what you wanted? If not then I agree with the others, a picture would be a great help Quote "Confusion is the welcome mat at the door of creativity." -Michaul Gelb My Gallery Check it out! Link to comment Share on other sites More sharing options...
misconduct3 Posted June 11, 2008 Author Share Posted June 11, 2008 sure here is the the website i got the original tutorial from: http://www.cafemom.com/group/14196/boar ... P_VERSIONS also...here is one of the websites i go to for the glitter-fills http://www.3ec.us/creatingfun/imgs/glitterfills :wink: i hope this helps more than my laast posts....i'm scratching my head like crazy trying to figure a way to convert this to a piant.net tutorial to learn use it....lol:) Quote Link to comment Share on other sites More sharing options...
oma Posted June 12, 2008 Share Posted June 12, 2008 read these tuts. for the first one in your examples you can also use in connection to this glitter tut some of the effect sparkle by Madjik. you will also have to use an outside gif maker read the second link , that explains how to get the motion. viewtopic.php?f=15&t=3070&hilit=glitter viewtopic.php?f=15&t=2492 Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
