Recolor tool + alpha transparency = not working?
Using PDN v3.30 (I know 3.31 is out, but it's 'mostly a servicing release to fix a few important bugs', and by looking at the changelog this issue isn't fixed)
Ok, here goes my problem. Now, I don't know if PDN is supposed to act like this, but the way I see it, it isn't. If you use the recolor tool and the primary color is transparent, after recoloring, the new color will be 100% opaque, even if alpha was set to 5, or whatever. Is this normal?..
