JBagg2010 Posted June 5, 2008 Share Posted June 5, 2008 ok I am a Paint.net novice. I was creating an avatar for someone and I'm using 3 seperate pictures. One is the background with the other two on top of the first. The backgrounds on the other two are white and I need them to be transparent. Quote Link to comment Share on other sites More sharing options...
ZizOiz Posted June 5, 2008 Share Posted June 5, 2008 Welcome to the forums! try these two places: making backgrounds of images transparent & if that doesn't help, the image hospital Quote Click on my signature image for my gallery | hmmmm... Link to comment Share on other sites More sharing options...
Chris Deston Posted June 5, 2008 Share Posted June 5, 2008 Personally i'd cut the two images by hand like in the Cutting Out Images the Easy Way tutorial, then paste them in separate layers where you can move them about and alter them later, changing their opacity if needed. I find that leaves bits of noise around the original stock and end up fiddling with the tolerance over and over This'd also be good practice for when cutting images on busier backgrounds in the future need transparent backgrounds. Quote Striving For Excellence Motivates You; Striving For Perfection Will Demoralise. Link to comment Share on other sites More sharing options...
