~ WelshBlue ~ Sunk ~ 17/10/2020
@lynxster4 ... @Seerose ... @Pixey
Huge thanks Ladies ... means a lot having your continued support.
Sadly lacking in inspiration to make things from scratch in PDN so I'm going through the tutorials I used to get the hang of PhotoShop to see how they translate in PDN
Another one ... only the background is PDN ... the splash and chilli are stock.  Grid Warp and TR's Dodge and Burn used (or is that crash and burn ...)
  • Like 3
... Blue 'Til I Die ...
My Gallery
Link to post
Inspiration can be frustrating, I know...?
Nice new piece, Welshy....though I'll pass on tasting that!  ?
Link to post
Shame.  I've got 2 plants full of cayennes that I've got to give a lot of the fruits away
Thanks @lynxster4 ... looking at it again maybe I should have gone for a plainer background ?
... Inspiration ... I've sort of got an idea I want to put into practice, but struggling to get the perspective and textures right - so keep scrapping it for a week or so, plus a text one playing around in my head but can't find the right font.  Worse problems to have in life I guess
My Gallery
Link to post
@Seerose ... Thank you very much.  I personally prefer the second background - seems to blend nicer for my eyes.
On 9/3/2018 at 7:16 PM, lynxster4 said:
....now it looks good enough to eat!
... better than the ones in my garden.  I picked one and took a bite ... my tongue felt like the manipped' chilli looked ?
My Gallery
Link to post
That's really cool @welshblue     Seamless blending between the two.
Great job!  ?
Link to post
I second what @Seerose said.  It is very dreamlike and the colors are fabulous, especially the purple soft puffs <3 Perfect seamless transitioning :)
Link to post
@lynxster4 ... @Seerose ... @Pixey ... thank you kindly ladies.  For some reason no other colour seemed to work.  I seem to do my best thinking at silly o'clock when everywhere is dark and quiet.
@TrevorOutlaw ... thanks.  Like I said in your gallery - getting into photo manips is down to you.  Would love to have layer masks but hey ho.
That sig is pretty sweet.  Right background choice to make it pop.
@xod ... thanks for the Rep
Aristotle Meets MJW - As in the whole is greater than the sum of the parts.  All Object Rounder and blurs except for the cogs and 2 bits of  hexagrid
Just randomness that came to me when I was upgrading the brakes and suspension on my sons car.  Pretty sad uh
  • Like 4
My Gallery
Link to post
Wow, I love that @welshblue    <3    Does it run?  Does it fly?
The detail is superb!  Kudos to you.   Seems like you spent a lot of time on this.  ?
Link to post
Wowzers!  That's an amazing result <3 .  Did you make it 'piecemeal' or did you first have the whole image greyed out before using MJW's rounder?  I'm still practicing with his plugin and have found it's really difficult to make something part-by-part, as the colors don't always match.
Link to post
@lynxster4 ... big thanks.  Nah unfortunately I forgot to add a fuel tank ?  I'm not sure how long - about 10 hours ... and about 2 of them were spent searching for layers.
About 120 layers and not one of them labelled.  I will learn one day ... but then I haven't yet
@Pixey ... big thanks.  All individual pieces but only about 6 different shapes which I played with to alter them.  Eg Blend modes/ adding white and or black lines on a new layer and blurring them.  See below for a bit more info' .  A tip I've learnt is if you want to keep the same colourings make a note of the settings to maintain colouring/ shades
@MJW ... big thanks.  I was just lucky that the initial settings I used worked out with Blend Modes and the look I wanted.  Then layers of lines and blurs.   Spme sharpen+ on the textures too
I've tried to emulate it to show what I did, but unfortunately I didn't think of making notes/ screenshot of the settings and no way to save them ahem ahem (cough ...  this cough is gonna kill me ...  cough ?)
Approx'  Initial Settings
Then Duplicated the layer and set the Blend Mode to Multiply - approx 90 opacity
In this example the 2 layers were merged and then duplicated with Blend Mode again to get a matt black.  Line on a New Layer
Shapes used in the image.  Notice the difference rotating 90 degrees does
Interesting things if you rotate by 45 degrees
any questions anyone give me a shout
Edited by welshblue
  • Like 2
My Gallery
Link to post
That's awesome @welshblue.   Yes, I discovered the differences when you rotate when I was playing with my 'Porcelain' text.
On thicker objects, the results are more pleasing and totally different.  (did I explain that right?)   ?
Link to post
Thank you @Seerose ... it didn't take so long, a lot of copying layers and re-using them.  About 10 hours over the space of a week.
Not so much a Master but lucky things work out ?
I got the inspiration for this from tidying out a cupboard in my son's room and came across a load of old video games and the first Xbox and had a bit of a blast on  Halo.   Apologies to any Halo purists it's not 100% correct but I made a few changes due to  ... my limitations and messing up   Artistic licence ...
I worked from This Sketch and looked at a few things online.  Approximately 30 hours, 8 files and about 350 layers all in.
Plugins used ... Texture Object Rounder, Diagonal Lines, Transparency, Bevel Selection, Planetoid.   The rest is Gradients/ and or line tool, with Gaussian Blur and Motion Blur.
Not entirely happy with it but fed up now - it's doing my head in ... I've over-worked it
Example of what using Object Rounder will do
  • Like 4
  • Upvote 3
My Gallery
Link to post
Wow!  That's an amazing rendition and looks so realistic @welshblue.  That plugin is totally amazing.  I need to practice more with it, when I get time ?.  I don't think you overworked it at all.  It's perfect :star:
Link to post
image.png.58777365a6d97fdcaa074d64f389338b.pngimage.png.399ff1d385f751784f1e32af2a0a3a2d.png
The lineart version overlaid on yours, showing differences and making suggestions... I'm assuming the lineart version is the only correct way to model this gun; that's where suggestions like "shouldn't be curved" and "trigger should be longer" are coming from. I have no idea if the lineart version is correct or desirable.
Doing my best to provide constructive criticism. This my was masterpiece in 2009, so I wouldn't have room to be snobby anyway image.png.59f5fe70e925d2acda1541ef33fddf4b.png  :)
Edited by Joshua Lamusga
Link to post
That's one mean-looking weapon @welshblue    Looks perfect to me!  Well-done!  :star:
Link to post
  • welshblue changed the title to ~ WelshBlue ~ Sunk ~ 17/10/2020
