vdizzle232 Posted May 31, 2008 Share Posted May 31, 2008 Does anyone know How to edit pimples and acne off a head picture in order to make a smooth face?? Quote Link to comment Share on other sites More sharing options...
Mike Ryan Posted May 31, 2008 Share Posted May 31, 2008 There are multiple methods. For instance, if you select the areas of pimples and acne and run the Red Eye effect in the Photo Submenu, that will remove the discolorization. However, other methods of blurring, using a blur brush technique, and others may prove a viable solution. It just comes down to the picture really and where the pimples and acne are placed Quote Link to comment Share on other sites More sharing options...
RyuinfinityPDN Posted May 31, 2008 Share Posted May 31, 2008 Or just use clone stamp. Quote -- Make an Explosion in Space-- Link to comment Share on other sites More sharing options...
BoltBait Posted May 31, 2008 Share Posted May 31, 2008 ...and median blur. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
vdizzle232 Posted June 3, 2008 Author Share Posted June 3, 2008 Thanks for the tips, also sorry im new to this but i tried to use my clone stamp and it isnt workin could someone tell me the right way to use it on the acne problem? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted June 3, 2008 Share Posted June 3, 2008 Pressing F1 when running Paint.NET will bring up the help file. http://www.getpaint.net/doc/latest/en/CloneStamp.html Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Simon Brown Posted June 3, 2008 Share Posted June 3, 2008 Brief instruction: Hold down ctrl while drawing to set the reference point - then draw normally in the destination point. The source point will move as the tool does. Quote Link to comment Share on other sites More sharing options...
