Frozen_byte Posted May 30, 2008 Share Posted May 30, 2008 Hey there, I have a problem to recolor different colors to the same one. So heres an Example: I have a Picture with #A7FF00 and a Picture with #02FFFF. Now I search for a way to colorize both colors to #FBB863! please help me! Quote Link to comment Share on other sites More sharing options...
LFC4EVER Posted May 30, 2008 Share Posted May 30, 2008 Could you post an example image? If not, then you could try making the image black and white (Ctrl+Shift+G) then on a new layer, fill it with a darker colour than you want the end image to look like, then set the blend mode to overlay. Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
BoltBait Posted May 30, 2008 Share Posted May 30, 2008 Open one of your images. Set your primary color to #FBB863. Select the magic wand tool. Set the tolerance to 0. Shift-Click on a pixel of color #A7FF00 in your image. Press the backspace key. Open your other image and repeat this process for a pixel of color #02FFFF. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Frozen_byte Posted May 31, 2008 Author Share Posted May 31, 2008 naah, Sorry forgot to say, thats not only one color to swich.. I'll post my example: These are my source images. And I want to try to recolor both to: How do i do that? If I use BB's way, I won't get the arrow orange, too. If I use LFC4EVER way, its all the same color, but I do not want this. I need something like "Hue / Saturation", I think. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 31, 2008 Share Posted May 31, 2008 Oh! Well, what you need is the Conditional Hue/Saturation plugin. viewtopic.php?f=16&t=1102 It may seem a little tricky at first, but once you get the hang of it, amazing things can be done. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Frozen_byte Posted May 31, 2008 Author Share Posted May 31, 2008 Uhm, I won't get exactly the same color: Settings: Quote Link to comment Share on other sites More sharing options...
MiguelPereira Posted May 31, 2008 Share Posted May 31, 2008 Increase the saturation value and adjust the hue to that color. Quote [The stock on my sig is a photo I took not a render from Splatter] [My deviantART][My Gallery][My Space] Link to comment Share on other sites More sharing options...
