Noswad
Posts
121 -
Joined
Last visited
Days Won
Content Type
Events
Profiles
Forums
Blogs
Gallery
Downloads
Posts posted by Noswad
You could maybe try some Feather or Gaussian blur?
Not just you, but a lot of peoples and same me! I tried a few times, but was not lucky, the phishing programs took over! My protection program informed, that official 'optimum' program is dangerous and deleted it! How I get Paint.net then?
Did you even read the rest of the thread?
Alright. I will make this as clear as possible:
Also, READ THE TEXT! It says:
In the advertisement:
Next to the download link:
Say I wanted to put person A beside person B, but they're in two different pictures? How exactly could I do this and make it look clean?
You could also use google translate.
That's why they call it image EDITOR instead of image BROWSER.
Paint.net doesn't work as an image viewer.
If you want to see your pictures, I suggest going to the folder from the "Start" menu and clicking one of the images, that will open up a program already on the computer that allows you to view your pictures without opening each one.
Use freeform select to select their face, then use adjustments hue/saturation to change it.
That always has worked for me in *MOST* situations.
Make the PAINT.NET DOWNLOAD button stand out; eliminate the possibility of confusion.
I agree with this, make the button for the PDN download huge.
I usually make a new layer, zoom in on the eyes, put a black dot over them, and then set the transparency level of the layer to where it looks best.
He is asking how to cut the turkey out of the background. Hence the link I posted
Oh, I thought he meant he already had the turkey selected.
>Edit >Cut
>Picture of your grandson>Edit>Paste
Oh my goodness it worked! But I didn't think I had anything selected, either way, thanks so much.
Just glad to help.
Try this..
Create a layer for the text
Press Ctrl+D
Try typing text
Hrm. I never noticed that.It's not a bug...it's a feature
I really don't want to see a zoomed version of my picture as the default (window).
Odd: It's a feature!? Err, gimme a sec...
Lol just kidding.
Is the noise white? If so...
1.Select the magic wand tool
2.Set selection mode to global
3.Select the white background
4.Edit menu > Erase selection
This is a problem with ABRmate, not paint.net.
I think you are looking for ScriptLab (by pyrochild), not CodeLab...
Just open up scriptlab and start adding filters to the list. Once you have everything you want, click ok and ctrl+f to your heart's content!
Wait, so you open scriptlab then start writing effect names? Or?
@Odd, As EER said, "The appealing download buttons are intended to be targeted by people who don't read the fine print first. In your screenshot it is stated in plain text what the button will download - you just didn't read it."
Not without cutting the corners of the book off **as far as I know**.
Here's what I did..
1. Put picture that needs to rotate on it's own layer.
2. Rotate.
3. Run AA's_Assistant , Soften edges checked, Sharpness at 3.00, Gamma at 2.00, Offset at 1.00
4. Repeat using AA's_Assistant at those levels until edges are smooth.
This worked for me.
That's really cool, Pwnedu.
I see that you play ROBOX.
Wow great tut. Going on my favorites list. ;D
Competition Ideas
in Discussion
Posted
Paranormal contest? Make the best photo edit you can to make it look... spooky?
