Posts
4,239 -
Joined
Last visited
Days Won
Posts posted by Mike Ryan
As long as the computer is running full Windows 8 (as in, not Windows RT) you won't experience any issues running paint.net.
Currently, Paint.NET handles the forward and back buttons on a mouse as just that: forward and back buttons. This means they currently have some level of functionality in Paint.NET (such as filling the canvas with the secondary color when using the Paint Bucket), but they mostly go unused.
What I would like is for them to be mapped to something a bit more useful, to potentially benefit those who have mice with these buttons on them. For instance, Notepad++ and other applications let you switch between open tabs in the application. If this were the model, the buttons on the mouse would let you cycle through the open images in Paint.NET.
Web browsers use these buttons to move forwards and backwards in history for a tab. Using this model, the two buttons would be mapped to undo and redo.
Either of these would be really great.
Great writeup! Definitely a lot of issues to consider when thinking about implementing some kind of advertising plugin in the installer.
I've always kind of wondered why Paint.NET never employed something like OpenCandy in the installer instead of advertisements on the homepage. It seems like Rick could make some steady income off of it. Plus, it would monetize the users who are already Paint.NET users through updates.
Try pasting the transparent letter onto a new layer. You can create a new layer by clicking on the :AddNewLayer: button.
Its not really a problem, what's happening is that when I resize an image, the pixels scale after I resize it, and I just need a way to disable this.
It sounds like you want to be able to change the image's dimensions but not actually distort the image in any way, is that correct? Perhaps you are wanting to Crop the image or adjust the image's Canvas Size?
It seems like the window you drag over (after moving the selection being drawn) takes focus. This is letting me change tools, undo, move layers, etc before finalizing the drawing of the selection. This also causes the Rectangle Select Tool's cursor to not revert to the 'ready to create a selection' state.
Currently, if your canvas is larger than the viewing area and the Tools / Colors / History / Layers boxes are above it (like this: bit.ly/HRlzsg), it is possible to use the Rectangle Select tool to create a selection that extends beneath those windows (like this: bit.ly/I1Dz5U)
However, if I change the selections position by holding down both Left Click and Right Click simulatenously, I can't actually extend the selection beneath the floating windows. If I try to, then I can't release the selection without changing tools.
Sorry for the poor articulation of the problem. Hopefully it made some sense as this problem can cause some bumps in my work flow.
If there is just a white background, I recommend checking out this tutorial:
For anything more complicated, check this tutorial out: http://www.isimonbrown.co.uk/cutting-out-images/
Hope this helps! If you need any more help in the future, I recommend trying out the Search functionality as many members have posted excellent advice on many common operations performed in Paint.NET.
Hello. I am using Paint.NET v3.5.10. This was an odd crash, because before it crashed Paint.NET seemed to have 'lost' half of its effects and adjustments. I say half because while a good many of my installed plugins were still available, an equal number simply disappeared from the context menus. I tried to click on Help after this happened and Paint.NET finally locked up and closed.
Crash log:
Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem.
Application version: Paint.NET v3.5.10 (Final Release build 3.510.4297.28964)
Time of crash: 10/30/2011 9:00:55 PM
Application uptime: 13.12:05:03.4737605
Install directory: C:\Program Files\Paint.NET
OS Version: 6.1.7601.65536 Service Pack 1 Workstation x64
.NET version: CLR 2.0.50727.5446 x64, FX 2.0 (rtm sp1 sp2) 3.0 (rtm sp1 sp2) 3.5 (rtm sp1 sp1_CP) 4.0 (rtm rtmEx)
Processor: 6x "AMD Phenom II X6 1090T Processor" @ ~3214MHz (DEP, SSE, SSE2, SSE3), fps=0x0
Physical memory: 4093 MB
UI Theme: Other/Aero + DWM (Elune 1 (Bottom).msstyles)
Updates: true, 10/10/2011
Locale: pdnr.c: en-US, hklm: en-US, hkcu: n/a, cc: en-US, cuic: en-US
Managed assemblies:
mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorlib.dll
PaintDotNet, Version=3.510.4297.28970, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
PaintDotNet.Base, Version=3.510.4297.28957, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\assembly\GAC_MSIL\WindowsBase\3.0.0.0__31bf3856ad364e35\WindowsBase.dll
System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Core\3.5.0.0__b77a5c561934e089\System.Core.dll
PaintDotNet.Core, Version=3.510.4297.28965, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
PaintDotNet.SystemLayer, Version=3.510.4297.28964, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
PaintDotNet.Resources, Version=3.510.4297.28964, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
PaintDotNet.Data, Version=3.510.4297.28969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
PaintDotNet.Effects, Version=3.510.4297.28970, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll
PaintDotNet.SystemLayer.Native.x64, Version=3.510.4297.28963, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll
msvcm90, Version=9.0.30729.6161, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcm90.dll
AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlignPlugin.dll
AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMask.dll
AlphaMaskBrush, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMaskBrush.dll
Bars, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bars.dll
"Borders N' Shapes", Version=1.8.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll
Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll
Bullet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bullet.dll
Burninate, Version=1.1.3182.28956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll
Channels, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channels.dll
CodeLab, Version=1.5.3727.29997, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CodeLab.dll
Color Match, Version=1.1.3627.29847, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll
Color2alpha, Version=1.0.3683.30667, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color2alpha.dll
ColorBalance, Version=1.1.3182.30196, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll
ColorModulo, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll
coltoalphaadv, Version=2.0.3683.22872, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\coltoalphaadv.dll
ConditionalPen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ConditionalPen.dll
CreateImageMap, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CreateImageMap.dll
CurtisBlack.Common, Version=1.0.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll
CurtisBlack.Effects, Version=11.1.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll
CurtisBlack.Resources, Version=1.0.3490.22409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll
Curves+, Version=3.0.3627.29849, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll
CustomBrushesMini, Version=1.9.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll
DesktopBackgroundPreview, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DesktopBackgroundPreview.dll
Displacement, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Displacement.dll
EdHarvey.Edfects.Common, Version=3.36.3160.38013, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Edfects.Common.dll
EdHarvey.Effects, Version=3.36.3160.38013, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll
EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EditableText.dll
EOEffects, Version=1.7.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EOEffects.dll
Feather, Version=3.0.3723.26349, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Feather.dll
Film, Version=2.0.3612.21577, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll
FilmNoir, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FilmNoir.dll
FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll
Fire, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fire.dll
Flags, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flags.dll
Flip, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flip.dll
Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frame.dll
GaussianBlurPlus, Version=1.1.3182.30307, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll
GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GenTree.dll
Gradient Bars, Version=3.0.3627.29850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll
GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blur.dll
Gradient Mapping, Version=3.0.3627.29847, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll
Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll
GridMaker, Version=3.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll
HexaGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll
ImageShackUpload, Version=2.6.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll
IsolateWhiteBlack, Version=1.3.3676.24989, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IsolateWhiteBlack.dll
Jitter, Version=3.0.3612.21576, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll
JPEGEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JPEGEffect.dll
KaleidoGen, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KaleidoGen.dll
Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll
Landscape, Version=1.1.3593.25344, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll
LensFlare, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LensFlare.dll
LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll
Lomography, Version=1.1.3182.31441, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lomography.dll
Majority, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Majority.dll
Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll
MotionSharpen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll
Nebulous, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Nebulous.dll
NewtonFractal, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll
Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll
Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll
Outline Object, Version=2.6.3612.21574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll
OutlineObject, Version=1.1.3160.31739, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline.dll
PageCurl, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll
Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Panelling.dll
NewPastel, Version=1.2.3182.29587, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll
PDNWatermark, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PDNWatermark.dll
Pixelate+, Version=1.0.3612.21574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll
PixelatedFrame, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PixelatedFrame.dll
Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll
Polygon, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon.dll
Polygones, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygones.dll
PrinterPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PrinterPlus.dll
pyrochild.effects.REQUIRED, Version=3.6.3710.33689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pyrochild.effects.REQUIRED.dll
Radialcolors, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll
RainbowTwist, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll
Random Effect, Version=1.3.3627.29846, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Effect.dll
RandLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random lines.dll
RandMaze1, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze1.dll
RandMaze2, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze2.dll
Random Shape Fill, Version=1.5.3621.26292, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll
Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rosaces.dll
SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll
ScriptLab, Version=2.6.3627.29850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScriptLab.dll
SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll
SelectionTools, Version=1.1.3182.28742, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll
Shape3D, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape3D.dll
silhouetteplugs, Version=1.1.3748.12146, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\silhouetteplugs.dll
SinWaves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SinWaves.dll
Smudge, Version=2.4.3710.33790, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll
Sparkles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkles.dll
Spiral, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Spiral.dll
SpiroGraph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroGraph.dll
SpiroShapes, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroShapes.dll
Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll
Splatter, Version=1.6.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll
Stars, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stars.dll
Steganography, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Steganography.dll
Stitch, Version=1.0.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll
StockLibrary, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StockLibrary.dll
SubtleEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SubtleEffect.dll
Texture, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texture.dll
ThatOtherApp, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll
ThreadsMarker, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll
Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll
Transitional Brush, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transitional Brush.dll
Transparency, Version=1.1.3182.29244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll
TreeGen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TreeGen.dll
TubeOblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll
TwistZ, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistZ.dll
Vibrato, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibrato.dll
Volutes, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Volutes.dll
WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll
Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll
WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll
XYCoords, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\XYCoords.dll
System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll
ICSharpCode.SharpZipLib, Version=0.86.0.518, Culture=neutral, PublicKeyToken=1b03e6acf1164f73 @ C:\Program Files\Paint.NET\ICSharpCode.SharpZipLib.dll
System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll
PhotoShop, Version=1.6.0.510, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll
System.Security, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Security\2.0.0.0__b03f5f7f11d50a3a\System.Security.dll
Accessibility, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\Accessibility\2.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll
spsekflv, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
soashkmx, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
hdsouuxa, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
sa4jl5ob, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
aib1xopb, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
Native modules:
C:\Program Files\Paint.NET\PaintDotNet.exe, version='3.510.4297.28970'
C:\Windows\SYSTEM32\ntdll.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\SYSTEM32\MSCOREE.DLL, version='4.0.40305.0 (Main.040305-0000)'
C:\Windows\system32\KERNEL32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\KERNELBASE.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\ADVAPI32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\msvcrt.dll, version='7.0.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\SYSTEM32\sechost.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\RPCRT4.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version='4.0.30319.1 (RTMRel.030319-0100)'
C:\Windows\system32\SHLWAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\GDI32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\USER32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\LPK.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\USP10.dll, version='1.0626.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\IMM32.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\MSCTF.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorwks.dll, version='2.0.50727.5446 (Win7SP1GDR.050727-5400)'
C:\Windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_88e41e092fab0294\MSVCR80.dll, version='8.00.50727.6195'
C:\Windows\system32\shell32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\ole32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\profapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\mscorlib\8f7abb6f7384aad8fc43659820726eab\mscorlib.ni.dll, version='2.0.50727.5446 (Win7SP1GDR.050727-5400)'
C:\Windows\system32\CRYPTBASE.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\uxtheme.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\System\3e6eefab37b44e147db80a3c34f0ac05\System.ni.dll, version='2.0.50727.5447 (Win7SP1GDR.050727-5400)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Core\5f7c48b31971fee1af48dd20c7dd7033\System.Core.ni.dll, version='3.5.30729.5420 built by: Win7SP1'
C:\Windows\assembly\NativeImages_v2.0.50727_64\WindowsBase\64fc9675d94bda9f45731097f140c4f6\WindowsBase.ni.dll, version='3.0.6920.5011 built by: Win7SP1'
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Drawing\ad884485b63f08acfaf791d2dfaadd32\System.Drawing.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Windows.Forms\0737590c91350bf9ce7416cbbf789bc7\System.Windows.Forms.ni.dll, version='2.0.50727.5446 (Win7SP1GDR.050727-5400)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Base\2a13005ffd54cbcbf8233b10bf9f70fc\PaintDotNet.Base.ni.dll, version='3.510.4297.28957'
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\4a0f198216991e0c4f2dd095e3e6ec28\PaintDotNet.SystemLayer.ni.dll, version='3.510.4297.28964'
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Resourc#\114736b7903225ec60bc824c61e7ca69\PaintDotNet.Resources.ni.dll, version='3.510.4297.28964'
C:\Windows\system32\CRYPTSP.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\rsaenh.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Core\e6d10ffe3f919f1ddc34799bcd19f81c\PaintDotNet.Core.ni.dll, version='3.510.4297.28965'
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Data\30c9e5a11db052c5ee4ea5f0c0375dd0\PaintDotNet.Data.ni.dll, version='3.510.4297.28969'
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet\4c9b791043b1e8c05fe6fe0175489d49\PaintDotNet.ni.exe, version='3.510.4297.28970'
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\f2367ab717373b0b37ac1d7f62c8d87e\PaintDotNet.SystemLayer.Native.x64.ni.dll, version='3.510.0.0'
C:\Windows\assembly\NativeImages_v2.0.50727_64\Interop.WIA\f459eef4b2aef09c5151871a26775373\Interop.WIA.ni.dll, version='1.0.0.0'
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Effects\5cda83e4836f25adf467f1888ea09088\PaintDotNet.Effects.ni.dll, version='3.510.4297.28970'
C:\Program Files\Paint.NET\Native.x64\PaintDotNet.Native.x64.dll, version='3.510.0.0'
C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCR90.dll, version='9.00.30729.6161'
C:\Windows\WinSxS\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9\VCOMP90.DLL, version='9.00.30729.6161 built by: QFE'
C:\Windows\system32\dwmapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.17514_none_2b24536c71ed437a\gdiplus.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorjit.dll, version='2.0.50727.5446 (Win7SP1GDR.050727-5400)'
C:\Windows\system32\WindowsCodecs.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\comctl32.dll, version='6.10 (win7_rtm.090713-1255)'
C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll, version='3.510.0.0'
C:\Windows\system32\OLEAUT32.dll, version='6.1.7601.17567'
C:\Windows\WinSxS\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895\ATL90.DLL, version='9.00.30729.6161'
C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcm90.dll, version='9.00.30729.6161'
C:\Windows\system32\d2d1.dll, version='6.1.7601.17563 (win7sp1_gdr.110218-1555)'
C:\Windows\system32\dwrite.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\RpcRtRemote.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\wtsapi32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\WINSTA.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\version.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\SetupApi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\CFGMGR32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\DEVOBJ.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\WINTRUST.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\CRYPT32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\MSASN1.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\CLBCatQ.DLL, version='2001.12.8530.16385 (win7_rtm.090713-1255)'
C:\Program Files\Paint.NET\Effects\AlignPlugin.dll, version='1.5.1.0'
C:\Program Files\Paint.NET\Effects\AlphaMask.dll, version='2.0.3574.41943'
C:\Program Files\Paint.NET\Effects\AlphaMaskBrush.dll, version='1.5.0.0'
C:\Program Files\Paint.NET\Effects\Bars.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll, version='1.8.3627.29848'
C:\Program Files\Paint.NET\Effects\Boutons.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Bullet.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Burninate.dll, version='1.1.3182.28956'
C:\Program Files\Paint.NET\Effects\Channels.dll, version='2.0.0.0'
C:\Program Files\Paint.NET\Effects\CodeLab.dll, version='1.5.3727.29997'
C:\Program Files\Paint.NET\Effects\Color Match.dll, version='1.1.3627.29847'
C:\Program Files\Paint.NET\Effects\Color2alpha.dll, version='1.0.3683.30667'
C:\Program Files\Paint.NET\Effects\ColorBalance.dll, version='1.1.3182.30196'
C:\Program Files\Paint.NET\Effects\ColorModulo.dll, version='0.0.0.0'
C:\Program Files\Paint.NET\Effects\coltoalphaadv.dll, version='2.0.3683.22872'
C:\Program Files\Paint.NET\Effects\ConditionalPen.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\CreateImageMap.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll, version='11.1.3736.39220'
C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Curves+.dll, version='3.0.3627.29849'
C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll, version='1.9.0.0'
C:\Program Files\Paint.NET\Effects\DesktopBackgroundPreview.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Displacement.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\EdHarvey.Edfects.Common.dll, version='3.36.3160.38013'
C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll, version='3.36.3160.38013'
C:\Program Files\Paint.NET\Effects\EditableText.dll, version='1.0.1.0'
C:\Program Files\Paint.NET\Effects\EOEffects.dll, version='1.7.0.0'
C:\Program Files\Paint.NET\Effects\Feather.dll, version='3.0.3723.26349'
C:\Program Files\Paint.NET\Effects\Film.dll, version='2.0.3612.21577'
C:\Program Files\Paint.NET\Effects\FilmNoir.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\FindEdges.dll, version='1.2.0.0'
C:\Program Files\Paint.NET\Effects\Fire.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Flags.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Flip.dll, version='2.0.0.0'
C:\Program Files\Paint.NET\Effects\Frame.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll, version='1.1.3182.30307'
C:\Program Files\Paint.NET\Effects\GenTree.dll, version='0.1.0.0'
C:\Program Files\Paint.NET\Effects\Gradient Bars.dll, version='3.0.3627.29850'
C:\Program Files\Paint.NET\Effects\Gradient Blur.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll, version='3.0.3627.29847'
C:\Program Files\Paint.NET\Effects\Gravity.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\GridMaker.dll, version='3.2.0.0'
C:\Program Files\Paint.NET\Effects\HexaGrid.dll, version='1.2.0.0'
C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll, version='2.6.2.0'
C:\Program Files\Paint.NET\Effects\IsolateWhiteBlack.dll, version='1.3.3676.24989'
C:\Program Files\Paint.NET\Effects\Jitter.dll, version='3.0.3612.21576'
C:\Program Files\Paint.NET\Effects\JPEGEffect.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\KaleidoGen.dll, version='1.2.0.0'
C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll, version='1.3.0.0'
C:\Program Files\Paint.NET\Effects\Landscape.dll, version='1.1.3593.25344'
C:\Program Files\Paint.NET\Effects\LensFlare.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\LightRays.dll, version='1.3.0.0'
C:\Program Files\Paint.NET\Effects\Lomography.dll, version='1.1.3182.31441'
C:\Program Files\Paint.NET\Effects\Majority.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Moire.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\MotionSharpen.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Nebulous.dll, version='0.0.0.0'
C:\Program Files\Paint.NET\Effects\NewtonFractal.dll, version='0.0.0.0'
C:\Program Files\Paint.NET\Effects\Oblique.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Olden.dll, version='1.5.0.0'
C:\Program Files\Paint.NET\Effects\Outline Object.dll, version='2.6.3612.21574'
C:\Program Files\Paint.NET\Effects\Outline.dll, version='1.1.3160.31739'
C:\Program Files\Paint.NET\Effects\PageCurl.dll, version='1.3.0.0'
C:\Program Files\Paint.NET\Effects\Panelling.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Pastel.dll, version='1.2.3182.29587'
C:\Program Files\Paint.NET\Effects\PDNWatermark.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Pixelate+.dll, version='1.0.3612.21574'
C:\Program Files\Paint.NET\Effects\PixelatedFrame.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Polar.dll, version='1.1.1.0'
C:\Program Files\Paint.NET\Effects\Polygon.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Polygones.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\PrinterPlus.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\pyrochild.effects.REQUIRED.dll, version='3.6.3710.33689'
C:\Program Files\Paint.NET\Effects\Radialcolors.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\RainbowTwist.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Random Effect.dll, version='1.3.3627.29846'
C:\Program Files\Paint.NET\Effects\Random lines.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Random Maze1.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Random Maze2.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll, version='1.5.3621.26292'
C:\Program Files\Paint.NET\Effects\Rosaces.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\SBCommon.dll, version='3.0.0.0'
C:\Program Files\Paint.NET\Effects\ScriptLab.dll, version='2.6.3627.29850'
C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\SelectionTools.dll, version='1.1.3182.28742'
C:\Program Files\Paint.NET\Effects\Shape3D.dll, version='1.2.6.0'
C:\Program Files\Paint.NET\Effects\silhouetteplugs.dll, version='1.1.3748.12146'
C:\Program Files\Paint.NET\Effects\SinWaves.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Smudge.dll, version='2.4.3710.33790'
C:\Program Files\Paint.NET\Effects\Sparkles.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Spiral.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\SpiroGraph.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\SpiroShapes.dll, version='1.4.0.0'
C:\Program Files\Paint.NET\Effects\Splashes.dll, version='1.1.1.0'
C:\Program Files\Paint.NET\Effects\Splatter.dll, version='1.6.3627.29848'
C:\Program Files\Paint.NET\Effects\Stars.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Steganography.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Stitch.dll, version='1.0.3627.29848'
C:\Program Files\Paint.NET\Effects\StockLibrary.dll, version='1.5.0.0'
C:\Program Files\Paint.NET\Effects\SubtleEffect.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Texture.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll, version='2.1.0.0'
C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll, version='0.0.0.0'
C:\Program Files\Paint.NET\Effects\Tiles.dll, version='1.1.1.0'
C:\Program Files\Paint.NET\Effects\Transitional Brush.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\Transparency.dll, version='1.1.3182.29244'
C:\Program Files\Paint.NET\Effects\TreeGen.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\TubeOblique.dll, version='1.0.0.0'
C:\Program Files\Paint.NET\Effects\TwistZ.dll, version='1.1.2.0'
C:\Program Files\Paint.NET\Effects\Vibrato.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Volutes.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\WaterReflection.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\Waves.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\WetFloor.dll, version='1.1.0.0'
C:\Program Files\Paint.NET\Effects\XYCoords.dll, version='1.0.0.0'
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Design\9f162ee8ce0ec6b2a539b68041421911\System.Design.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
C:\Windows\system32\RichEd20.DLL, version='5.31.23.1230'
C:\Windows\assembly\NativeImages_v2.0.50727_64\ICSharpCode.SharpZi#\4782a84cfd77863a6eea670f101faf27\ICSharpCode.SharpZipLib.ni.dll, version='0.86.0.518'
C:\Windows\system32\explorerframe.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\DUser.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\DUI70.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Xml\318b11a6b944c9ef2998d374c9d5bda8\System.Xml.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll, version='1.6.0.0'
C:\Windows\System32\comdlg32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\propsys.dll, version='7.00.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\ntmarta.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\WLDAP32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\apphelp.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Users\Mike Ryan\AppData\Roaming\Dropbox\bin\DropboxExt64.14.dll, version='1.0.0.14'
C:\Windows\system32\dbghelp.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\msvcp60.dll, version='7.0.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\EhStorShell.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\PROGRA~1\MICROS~4\Office14\GROOVEEX.DLL, version='14.0.4734.1000'
C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCP90.dll, version='9.00.30729.6161'
C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE14\Cultures\office.odf, version='14.0.4730.1010'
C:\PROGRA~1\MICROS~4\Office14\1033\GrooveIntlResource.dll, version='14.0.4734.1000'
C:\Windows\System32\cscui.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\System32\CSCDLL.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\CSCAPI.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\msls31.dll, version='3.10.349.0'
C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\xmllite.dll, version='1.3.1000.0'
C:\Windows\system32\OLEACC.dll, version='7.0.0.0 (win7_rtm.090713-1255)'
C:\Windows\system32\UIAutomationCore.dll, version='7.0.0.0 (win7_rtm.090713-1255)'
C:\Windows\system32\PSAPI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\SXS.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\System32\StructuredQuery.dll, version='7.00.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\System32\Secur32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\System32\SSPICLI.DLL, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\actxprxy.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Program Files\Internet Explorer\ieproxy.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
C:\Windows\system32\thumbcache.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\SearchFolder.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\SHDOCVW.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\ieframe.DLL, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
C:\Windows\system32\iertutil.dll, version='9.00.8112.16434 (WIN7_IE9_GDR.110721-1800)'
C:\Windows\system32\samcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\SAMLIB.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\netutils.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\slc.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\NetworkExplorer.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\LINKINFO.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\MPR.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\wkscli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\WINMM.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\PortableDeviceApi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\ntshrui.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\srvcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\EhStorAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\IconCodecService.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\NetworkItemFactory.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\dtsh.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\FirewallAPI.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\wbem\wbemprox.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\wbemcomn.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\WS2_32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\NSI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\wbem\wbemsvc.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\wbem\fastprox.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\NTDSAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\System32\npmproxy.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\FunDisc.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\ATL.DLL, version='3.05.2284'
C:\Windows\System32\msxml6.dll, version='6.30.7601.17514'
C:\Windows\system32\fdproxy.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\System32\fdwcn.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\System32\wcnapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\fdWNet.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\IPHLPAPI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\WINNSI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\dfscli.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\browcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\mswsock.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\DNSAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\rasadhlp.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\dhcpcsvc6.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\dhcpcsvc.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Program Files\Common Files\Adobe\Adobe Drive CS4\ADFSMenu.dll, version='4.0.0.0client1'
C:\Program Files\Windows Sidebar\sbdrop.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\atiacm64.dll, version='6.14.10.2001'
C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\atiamenu.dll, version='6.14.10.2001'
C:\Windows\system32\mssprxy.dll, version='7.00.7600.16385 (win7_rtm.090713-1255)'
C:\Program Files (x86)\FileZilla FTP Client\fzshellext_64.dll, version='3, 2, 7, 0'
C:\Windows\system32\urlmon.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
C:\Windows\system32\WININET.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
C:\Windows\system32\Normaliz.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\ktmw32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\d3d10_1.dll, version='6.1.7601.17544 (win7sp1_gdr.110116-1505)'
C:\Windows\system32\d3d10_1core.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\dxgi.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\diasymreader.dll, version='8.0.50727.5420 (Win7SP1.050727-5400)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Security\f330ec3533f2f0cb4c6dacd3a3e48044\System.Security.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\Accessibility\23ea8465ac746c69a6ed7fdf628d3e9c\Accessibility.ni.dll, version='2.0.50727.4927 (NetFXspW7.050727-4900)'
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Configuration\df2bfb30ffdbfbb49d2c5ef6fc763578\System.Configuration.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
C:\Windows\system32\mscms.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\USERENV.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\PhotoMetadataHandler.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\zipfldr.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Program Files\7-Zip\7-zip.dll, version='4.65'
C:\Windows\System32\drprov.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\System32\ntlanman.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\System32\davclnt.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\System32\DAVHLPR.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\PortableDeviceTypes.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\syncui.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\SYNCENG.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\twext.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\System32\cscobj.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Program Files (x86)\MagicISO\misosh64.dll, version='5, 3, 0, 198'
c:\PROGRA~1\MI8079~1\shellext.dll, version='2.1.1116.0'
C:\Windows\system32\msi.dll, version='5.0.7601.17514'
C:\Windows\system32\imagehlp.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\ncrypt.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\bcrypt.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\system32\bcryptprimitives.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
C:\Windows\system32\GPAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
C:\Windows\System32\msxml3.dll, version='8.110.7601.17514'
Exception details:
System.ArgumentException: Parameter is not valid.
at System.Drawing.Image.FromStream(Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData)
at PaintDotNet.PdnResources.LoadImage(Stream input) in D:\src\pdn\pdn_35x\src\Resources\PdnResources.cs:line 495
at PaintDotNet.PdnResources.GetImage(String fileName) in D:\src\pdn\pdn_35x\src\Resources\PdnResources.cs:line 332
at PaintDotNet.Resource`1.get_Reference() in D:\src\pdn\pdn_35x\src\Base\Resource`1.cs:line 28
at PaintDotNet.Menus.PdnMenuItem.SetIcon(String imageName) in D:\src\pdn\pdn_35x\src\PaintDotNet\Menus\PdnMenuItem.cs:line 245
at PaintDotNet.Menus.PdnMenuItem.LoadIcons() in D:\src\pdn\pdn_35x\src\PaintDotNet\Menus\PdnMenuItem.cs:line 271
at System.Windows.Forms.ToolStripDropDownItem.OnDropDownShow(EventArgs e)
at System.Windows.Forms.ToolStripDropDownItem.ShowDropDownInternal()
at System.Windows.Forms.ToolStripDropDownItem.ShowDropDown(Boolean mousePush)
at System.Windows.Forms.ToolStripItem.HandleMouseDown(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseDown(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.MenuStrip.WndProc(Message& m)
at PaintDotNet.SystemLayer.MenuStripEx.WndProc(Message& m) in D:\src\pdn\pdn_35x\src\SystemLayer\MenuStripEx.cs:line 60
How often would one want to make a selection of (n x 5) vs (n x 5) + 1? I can't claim to have done any research on the matter, but I know from personal experience that I am targeting a multiple of five way more often than I am targeting anything in between. This certainly isn't a suggestion made off of a whimsy, but one made after quite some time with the software. I think I would prefer even sets over odd sets if you don't like skipping a digit, going from 2,4,6,8,10,... instead of 1,3,5,7,9,...
Now obviously you can't tailor the software to my personal preference, but I just don't think I am the only one finding myself targeting multiples of five over odd digits. This also seems like a problem that most people wouldn't know they had, one way or another.
This is just a suggestion to increase productivity and usability with the selection tool. When a large image is zoomed out and you create a selection, obviously not every mouse increment can correspond to increasing or decreasing the width or height by a single pixel.
But this can cause some problems. For example, if I am viewing an image at just 50%, the selection will increment or decrement by 2px starting at 1px, leading each increment to be an odd number. For those working in design, this can be somewhat frustrating especially when trying to create selections 300x200, or some other even number. To remedy this, I suggest snapping these selections to increments of five. So instead of the with going 235,237,239,241 it would go 235,237,240,241. That way you hit every single multiple of five and ten.
I know my explanation of this problem is pretty poor, but it really is hard to describe this little problem.
Thanks,
Mike
This bug has occurred for me every time I cut an image from a layer, create a new layer, change its name, and then paste the image. It says that I don't have an image on the clipboard. I haven't tried to confirm this under other conditions. v3.5.8
Yeah, all of these were a study into shape and color. All of them have a carefully crafted balance and color harmony that I attempted to achieve. I am happy they are well received! Two more since you guys like them:
AP Art is a highschool course that - should you score high enough - allows for college credit at most major universities in the United States. Want more? Here is another one:
Here is another AP Art piece that is one hundred percent Paint.NET. This is actually part of my concentration, so I have a ton of similar pieces. Hope you guys like it!
None of these should break in future releases unless there were major revisions to the plugin system. These are pretty fault=tolerant plugins made in CodeLab.
No. I no longer support these plugins. Sorry!
I was just drawing a transparent gradient. Perhaps I drew it too quickly? I do not know. Let me know if this could be in anyway related to memory issues.
This text file was created because Paint.NET crashed.Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem.
Application version: Paint.NET v3.5.6 (Final Release build 3.56.3972.42619)
Time of crash: 1/26/2011 9:28:04 AM
Application uptime: 00:01:50.1495274
OS Version: 6.1.7600.0 Workstation x64
.NET version: CLR 2.0.50727.4952 x64, FX 2.0 (rtm sp1 sp2) 3.0 (rtm sp1 sp2) 3.5 (rtm sp1 sp1_CP) 4.0 (rtm rtmEx)
Processor: 6x "AMD Phenom II X6 1090T Processor" @ ~3680MHz (DEP, SSE, SSE2, SSE3), fps=0x1
UI Theme: Aero/Aero + DWM (Aero.msstyles)
Updates: true, 1/16/2011
Managed assemblies:
PaintDotNet, Version=3.56.3972.42626, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
PaintDotNet.Base, Version=3.56.3972.42612, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
PaintDotNet.Core, Version=3.56.3972.42620, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
PaintDotNet.SystemLayer, Version=3.56.3972.42618, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
PaintDotNet.Resources, Version=3.56.3972.42619, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
PaintDotNet.Data, Version=3.56.3972.42623, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
PaintDotNet.Effects, Version=3.56.3972.42625, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll
PaintDotNet.SystemLayer.Native.x64, Version=3.56.3972.42618, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll
msvcm90, Version=9.0.30729.4926, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554\msvcm90.dll
Native modules:
C:\Windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_88dce9872fb18caf\MSVCR80.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\mscorlib\2e16a238456fbe4a41233d7a732d086b\mscorlib.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\System\65f46521e7fca2cd2d216162175f2fd6\System.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Core\6ef98a068f45cbf57702eab0f623d007\System.Core.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\WindowsBase\bdb953c9c0fcd5c281b1bcbcfb527bd2\WindowsBase.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Drawing\e48f514a13b9d9ddd60c82b64e68dc11\System.Drawing.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Windows.Forms\d6fb1e55b2ba3ab8b2815181133130e3\System.Windows.Forms.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Base\b266e4fb2dd5b3c7357c792d43a63e24\PaintDotNet.Base.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\dbcb983da631434fc9d4f852c4093c51\PaintDotNet.SystemLayer.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Resourc#\7136cce5af3f4c50c1db29b1b6b98a7b\PaintDotNet.Resources.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Core\7ebf129d3cae6835e28f5066bf500893\PaintDotNet.Core.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Data\4b51d7747d1e9787ec67c1323e9ddb47\PaintDotNet.Data.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet\28655887b4f95e0d3196914f9aa414fe\PaintDotNet.ni.exe
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\d7a77e9e761c87205fd3ebc6b8b0dd98\PaintDotNet.SystemLayer.Native.x64.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\Interop.WIA\cbceebd16fd592cab8f636a09590c40a\Interop.WIA.ni.dll
C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Effects\8530f84a1411d66c26289af226ba8255\PaintDotNet.Effects.ni.dll
C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554\MSVCR90.dll
C:\Windows\WinSxS\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.4148_none_390a91d20a21a864\VCOMP90.DLL
C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_2b4f45e87195fcc4\gdiplus.dll
C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_fa62ad231704eab7\comctl32.dll
C:\Windows\WinSxS\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4148_none_0a1d2fcba76b3f00\ATL90.DLL
C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Design\a78ec0117a85a48e1c7c816946c64915\System.Design.ni.dll
C:\Windows\system32\psapi.dll
Exception details:
PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.Runtime.InteropServices.SEHException: External component has thrown an exception.
at PaintDotNet.Rendering.GradientRenderer.Render(Surface surface, Int32Rect[] rois, Int32 startIndex, Int32 length) in D:\src\pdn\pdn_35x\src\PaintDotNet\Rendering\GradientRenderer.cs:line 224
at PaintDotNet.Tools.GradientTool.RenderContext.Render(Object cpuIndexObj) in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\GradientTool.cs:line 229
at PaintDotNet.Threading.PrivateThreadPool.ThreadWrapperContext.ThreadWrapper() in D:\src\pdn\pdn_35x\src\Core\Threading\PrivateThreadPool.cs:line 179
at PaintDotNet.Threading.PrivateThreadPool.DrainExceptions() in D:\src\pdn\pdn_35x\src\Core\Threading\PrivateThreadPool.cs:line 74
at PaintDotNet.Tools.GradientTool.RenderGradient(Surface surface, GeometryList clipGeometry, CompositingMode compositingMode, Point startPointF, ColorBgra startColor, Point endPointF, ColorBgra endColor) in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\GradientTool.cs:line 248
at PaintDotNet.Tools.GradientTool.RenderGradient() in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\GradientTool.cs:line 325
at PaintDotNet.Tools.GradientTool.OnMouseMove(MouseEventArgsF e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\GradientTool.cs:line 568
at PaintDotNet.Tools.Tool.MouseMove(MouseEventArgsF e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\Tool.cs:line 790
at PaintDotNet.Controls.AppWorkspace.DocumentMouseMoveHandler(Object sender, MouseEventArgsF e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Controls\AppWorkspace.cs:line 1777
at PaintDotNet.Controls.DocumentView.OnDocumentMouseMove(MouseEventArgsF e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Controls\DocumentView.cs:line 1093
at PaintDotNet.Controls.DocumentView.MouseMoveHandler(Object sender, MouseEventArgs e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Controls\DocumentView.cs:line 1507
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at PaintDotNet.SystemLayer.GdiPaintControl.WndProc(Message& m) in D:\src\pdn\pdn_35x\src\SystemLayer\GdiPaintControl.cs:line 151
Well, after trying it out this plugin is much better then the one both of us released two years back.
Yes! One of my most requested plugins. Thanks a ton, Pyro!
WEEKLY TUTORIAL COMPETITION
The Discussion Thread
The WTC Rules [Required Reading]
There is no maximum image size but if any of the images are larger than 800x800, please LINK to it instead!
No crude / offensive language, pics, et cetera.
Submissions will be disqualified if it does not match the theme of the tutorial!
Only one entry per person and no modifications to your image are allowed after submitting your entry.
Unless the tutorial SPECIFICALLY calls for a stock image, no stock images are allowed!
You are allowed one post in this topic. That post should include your entry, links to your source images.
Beyond these rules, if the competition host finds that the entry is clearly inappropriate for one reason or another, he or she may disqualify that entry without warning
Note: Unlike other competitions, the winner does NOT get to choose the theme for next week's competition, but he or she is welcome to make suggestions
How to Make a Sliced 3D Orange by csm725
Link: | Deadline: Midnight, September 4th, 2010
Welcome to the Brand New WTC!
Welcome to the brand new Weekly Tutorial Competition. In this competition, the theme is determined by a tutorial. Your task? To take what you learn from the tutorial and create something even better. Since this is the first time this competition has ever run, here are my suggestions for the selected tutorial: think about ways to make the orange more realistic. A bland, white background might not be the most suitable choice to present your orange. Think about shadows and the overall texture of the orange. May the best orange win!
Deadline: Midnight on September 4th, 2010
The deadline is at midnight on September 4th, 2010. Late entries are accepted until I close the thread. The competition will not end if there are less than five entries. Voting will begin within one to two days after the competition has ended. My timezone is Central (US and Canada). Good luck, everybody!
Out of Memory Exemption with Plenty of Memory to Spare
in Troubleshooting & Bug Reports
Posted
This happens every once in a while (rather infrequently, actually). I'm clearly getting an out of memory error, but in this case and cases like it I have around 45-60% of my total system memory available (12gb, 2x4 in one channel, 2x2 in another). Every time it occurs, I run a memtest and find no issues. For what it's worth, I have disabled the Windows Pagefile (running on limited space with two 64gb SSDs in a raid0 array). This issue occurred on Windows 7 and now Windows 8, both were clean installs (as in, Windows 8 did not upgrade Windows 7)
For this particular crash, Paint.NET was using a reported 914.6 MB of memory, with 46% of my total memory free.
Here's a link to the crashlog: https://dl.dropbox.com/u/2987/pdncrash.log
