Mike Ryan
Members
  • Posts
    4,239
  • Joined
  • Last visited
  • Days Won
Posts posted by Mike Ryan
  1. This happens every once in a while (rather infrequently, actually). I'm clearly getting an out of memory error, but in this case and cases like it I have around 45-60% of my total system memory available (12gb, 2x4 in one channel, 2x2 in another). Every time it occurs, I run a memtest and find no issues. For what it's worth, I have disabled the Windows Pagefile (running on limited space with two 64gb SSDs in a raid0 array). This issue occurred on Windows 7 and now Windows 8, both were clean installs (as in, Windows 8 did not upgrade Windows 7)
    For this particular crash, Paint.NET was using a reported 914.6 MB of memory, with 46% of my total memory free.
    Here's a link to the crashlog: https://dl.dropbox.com/u/2987/pdncrash.log
  2. Currently, Paint.NET handles the forward and back buttons on a mouse as just that: forward and back buttons. This means they currently have some level of functionality in Paint.NET (such as filling the canvas with the secondary color when using the Paint Bucket), but they mostly go unused.
    What I would like is for them to be mapped to something a bit more useful, to potentially benefit those who have mice with these buttons on them. For instance, Notepad++ and other applications let you switch between open tabs in the application. If this were the model, the buttons on the mouse would let you cycle through the open images in Paint.NET.
    Web browsers use these buttons to move forwards and backwards in history for a tab. Using this model, the two buttons would be mapped to undo and redo.
    Either of these would be really great.
  3. Its not really a problem, what's happening is that when I resize an image, the pixels scale after I resize it, and I just need a way to disable this. :/
    It sounds like you want to be able to change the image's dimensions but not actually distort the image in any way, is that correct? Perhaps you are wanting to Crop the image or adjust the image's Canvas Size?
  4. Currently, if your canvas is larger than the viewing area and the Tools / Colors / History / Layers boxes are above it (like this: bit.ly/HRlzsg), it is possible to use the Rectangle Select tool to create a selection that extends beneath those windows (like this: bit.ly/I1Dz5U)
    However, if I change the selections position by holding down both Left Click and Right Click simulatenously, I can't actually extend the selection beneath the floating windows. If I try to, then I can't release the selection without changing tools.
    Sorry for the poor articulation of the problem. Hopefully it made some sense as this problem can cause some bumps in my work flow.
  5. Hello. I am using Paint.NET v3.5.10. This was an odd crash, because before it crashed Paint.NET seemed to have 'lost' half of its effects and adjustments. I say half because while a good many of my installed plugins were still available, an equal number simply disappeared from the context menus. I tried to click on Help after this happened and Paint.NET finally locked up and closed.
    Crash log:
    Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem.
    Application version: Paint.NET v3.5.10 (Final Release build 3.510.4297.28964)
    Time of crash: 10/30/2011 9:00:55 PM
    Application uptime: 13.12:05:03.4737605
    Install directory: C:\Program Files\Paint.NET
    OS Version: 6.1.7601.65536 Service Pack 1 Workstation x64
    .NET version: CLR 2.0.50727.5446 x64, FX 2.0 (rtm sp1 sp2) 3.0 (rtm sp1 sp2) 3.5 (rtm sp1 sp1_CP) 4.0 (rtm rtmEx)
    Processor: 6x "AMD Phenom II X6 1090T Processor" @ ~3214MHz (DEP, SSE, SSE2, SSE3), fps=0x0
    Physical memory: 4093 MB
    UI Theme: Other/Aero + DWM (Elune 1 (Bottom).msstyles)
    Updates: true, 10/10/2011
    Locale: pdnr.c: en-US, hklm: en-US, hkcu: n/a, cc: en-US, cuic: en-US
    Managed assemblies:
    mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorlib.dll
    PaintDotNet, Version=3.510.4297.28970, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
    PaintDotNet.Base, Version=3.510.4297.28957, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
    System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
    WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\assembly\GAC_MSIL\WindowsBase\3.0.0.0__31bf3856ad364e35\WindowsBase.dll
    System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
    System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
    System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Core\3.5.0.0__b77a5c561934e089\System.Core.dll
    PaintDotNet.Core, Version=3.510.4297.28965, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
    PaintDotNet.SystemLayer, Version=3.510.4297.28964, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
    PaintDotNet.Resources, Version=3.510.4297.28964, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
    PaintDotNet.Data, Version=3.510.4297.28969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
    PaintDotNet.Effects, Version=3.510.4297.28970, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll
    PaintDotNet.SystemLayer.Native.x64, Version=3.510.4297.28963, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll
    msvcm90, Version=9.0.30729.6161, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcm90.dll
    AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlignPlugin.dll
    AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMask.dll
    AlphaMaskBrush, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMaskBrush.dll
    Bars, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bars.dll
    "Borders N' Shapes", Version=1.8.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll
    Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll
    Bullet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bullet.dll
    Burninate, Version=1.1.3182.28956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll
    Channels, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channels.dll
    CodeLab, Version=1.5.3727.29997, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CodeLab.dll
    Color Match, Version=1.1.3627.29847, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll
    Color2alpha, Version=1.0.3683.30667, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color2alpha.dll
    ColorBalance, Version=1.1.3182.30196, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll
    ColorModulo, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll
    coltoalphaadv, Version=2.0.3683.22872, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\coltoalphaadv.dll
    ConditionalPen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ConditionalPen.dll
    CreateImageMap, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CreateImageMap.dll
    CurtisBlack.Common, Version=1.0.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll
    CurtisBlack.Effects, Version=11.1.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll
    CurtisBlack.Resources, Version=1.0.3490.22409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll
    Curves+, Version=3.0.3627.29849, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll
    CustomBrushesMini, Version=1.9.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll
    DesktopBackgroundPreview, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DesktopBackgroundPreview.dll
    Displacement, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Displacement.dll
    EdHarvey.Edfects.Common, Version=3.36.3160.38013, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Edfects.Common.dll
    EdHarvey.Effects, Version=3.36.3160.38013, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll
    EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EditableText.dll
    EOEffects, Version=1.7.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EOEffects.dll
    Feather, Version=3.0.3723.26349, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Feather.dll
    Film, Version=2.0.3612.21577, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll
    FilmNoir, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FilmNoir.dll
    FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll
    Fire, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fire.dll
    Flags, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flags.dll
    Flip, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flip.dll
    Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frame.dll
    GaussianBlurPlus, Version=1.1.3182.30307, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll
    GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GenTree.dll
    Gradient Bars, Version=3.0.3627.29850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll
    GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blur.dll
    Gradient Mapping, Version=3.0.3627.29847, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll
    Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll
    GridMaker, Version=3.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll
    HexaGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll
    ImageShackUpload, Version=2.6.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll
    IsolateWhiteBlack, Version=1.3.3676.24989, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IsolateWhiteBlack.dll
    Jitter, Version=3.0.3612.21576, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll
    JPEGEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JPEGEffect.dll
    KaleidoGen, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KaleidoGen.dll
    Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll
    Landscape, Version=1.1.3593.25344, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll
    LensFlare, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LensFlare.dll
    LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll
    Lomography, Version=1.1.3182.31441, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lomography.dll
    Majority, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Majority.dll
    Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll
    MotionSharpen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll
    Nebulous, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Nebulous.dll
    NewtonFractal, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll
    Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll
    Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll
    Outline Object, Version=2.6.3612.21574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll
    OutlineObject, Version=1.1.3160.31739, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline.dll
    PageCurl, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll
    Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Panelling.dll
    NewPastel, Version=1.2.3182.29587, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll
    PDNWatermark, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PDNWatermark.dll
    Pixelate+, Version=1.0.3612.21574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll
    PixelatedFrame, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PixelatedFrame.dll
    Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll
    Polygon, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon.dll
    Polygones, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygones.dll
    PrinterPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PrinterPlus.dll
    pyrochild.effects.REQUIRED, Version=3.6.3710.33689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pyrochild.effects.REQUIRED.dll
    Radialcolors, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll
    RainbowTwist, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll
    Random Effect, Version=1.3.3627.29846, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Effect.dll
    RandLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random lines.dll
    RandMaze1, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze1.dll
    RandMaze2, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze2.dll
    Random Shape Fill, Version=1.5.3621.26292, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll
    Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rosaces.dll
    SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll
    ScriptLab, Version=2.6.3627.29850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScriptLab.dll
    SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll
    SelectionTools, Version=1.1.3182.28742, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll
    Shape3D, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape3D.dll
    silhouetteplugs, Version=1.1.3748.12146, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\silhouetteplugs.dll
    SinWaves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SinWaves.dll
    Smudge, Version=2.4.3710.33790, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll
    Sparkles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkles.dll
    Spiral, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Spiral.dll
    SpiroGraph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroGraph.dll
    SpiroShapes, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroShapes.dll
    Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll
    Splatter, Version=1.6.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll
    Stars, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stars.dll
    Steganography, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Steganography.dll
    Stitch, Version=1.0.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll
    StockLibrary, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StockLibrary.dll
    SubtleEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SubtleEffect.dll
    Texture, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texture.dll
    ThatOtherApp, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll
    ThreadsMarker, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll
    Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll
    Transitional Brush, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transitional Brush.dll
    Transparency, Version=1.1.3182.29244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll
    TreeGen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TreeGen.dll
    TubeOblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll
    TwistZ, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistZ.dll
    Vibrato, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibrato.dll
    Volutes, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Volutes.dll
    WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll
    Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll
    WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll
    XYCoords, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\XYCoords.dll
    System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll
    ICSharpCode.SharpZipLib, Version=0.86.0.518, Culture=neutral, PublicKeyToken=1b03e6acf1164f73 @ C:\Program Files\Paint.NET\ICSharpCode.SharpZipLib.dll
    System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll
    PhotoShop, Version=1.6.0.510, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll
    System.Security, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Security\2.0.0.0__b03f5f7f11d50a3a\System.Security.dll
    Accessibility, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\Accessibility\2.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
    System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll
    spsekflv, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
    soashkmx, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
    hdsouuxa, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
    sa4jl5ob, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
    aib1xopb, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
    Native modules:
    C:\Program Files\Paint.NET\PaintDotNet.exe, version='3.510.4297.28970'
    C:\Windows\SYSTEM32\ntdll.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\SYSTEM32\MSCOREE.DLL, version='4.0.40305.0 (Main.040305-0000)'
    C:\Windows\system32\KERNEL32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\KERNELBASE.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\ADVAPI32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\msvcrt.dll, version='7.0.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\SYSTEM32\sechost.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\RPCRT4.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version='4.0.30319.1 (RTMRel.030319-0100)'
    C:\Windows\system32\SHLWAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\GDI32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\USER32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\LPK.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\USP10.dll, version='1.0626.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\IMM32.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\MSCTF.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorwks.dll, version='2.0.50727.5446 (Win7SP1GDR.050727-5400)'
    C:\Windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_88e41e092fab0294\MSVCR80.dll, version='8.00.50727.6195'
    C:\Windows\system32\shell32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\ole32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\profapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\mscorlib\8f7abb6f7384aad8fc43659820726eab\mscorlib.ni.dll, version='2.0.50727.5446 (Win7SP1GDR.050727-5400)'
    C:\Windows\system32\CRYPTBASE.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\uxtheme.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System\3e6eefab37b44e147db80a3c34f0ac05\System.ni.dll, version='2.0.50727.5447 (Win7SP1GDR.050727-5400)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Core\5f7c48b31971fee1af48dd20c7dd7033\System.Core.ni.dll, version='3.5.30729.5420 built by: Win7SP1'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\WindowsBase\64fc9675d94bda9f45731097f140c4f6\WindowsBase.ni.dll, version='3.0.6920.5011 built by: Win7SP1'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Drawing\ad884485b63f08acfaf791d2dfaadd32\System.Drawing.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Windows.Forms\0737590c91350bf9ce7416cbbf789bc7\System.Windows.Forms.ni.dll, version='2.0.50727.5446 (Win7SP1GDR.050727-5400)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Base\2a13005ffd54cbcbf8233b10bf9f70fc\PaintDotNet.Base.ni.dll, version='3.510.4297.28957'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\4a0f198216991e0c4f2dd095e3e6ec28\PaintDotNet.SystemLayer.ni.dll, version='3.510.4297.28964'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Resourc#\114736b7903225ec60bc824c61e7ca69\PaintDotNet.Resources.ni.dll, version='3.510.4297.28964'
    C:\Windows\system32\CRYPTSP.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\rsaenh.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Core\e6d10ffe3f919f1ddc34799bcd19f81c\PaintDotNet.Core.ni.dll, version='3.510.4297.28965'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Data\30c9e5a11db052c5ee4ea5f0c0375dd0\PaintDotNet.Data.ni.dll, version='3.510.4297.28969'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet\4c9b791043b1e8c05fe6fe0175489d49\PaintDotNet.ni.exe, version='3.510.4297.28970'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\f2367ab717373b0b37ac1d7f62c8d87e\PaintDotNet.SystemLayer.Native.x64.ni.dll, version='3.510.0.0'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\Interop.WIA\f459eef4b2aef09c5151871a26775373\Interop.WIA.ni.dll, version='1.0.0.0'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Effects\5cda83e4836f25adf467f1888ea09088\PaintDotNet.Effects.ni.dll, version='3.510.4297.28970'
    C:\Program Files\Paint.NET\Native.x64\PaintDotNet.Native.x64.dll, version='3.510.0.0'
    C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCR90.dll, version='9.00.30729.6161'
    C:\Windows\WinSxS\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9\VCOMP90.DLL, version='9.00.30729.6161 built by: QFE'
    C:\Windows\system32\dwmapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.17514_none_2b24536c71ed437a\gdiplus.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorjit.dll, version='2.0.50727.5446 (Win7SP1GDR.050727-5400)'
    C:\Windows\system32\WindowsCodecs.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\comctl32.dll, version='6.10 (win7_rtm.090713-1255)'
    C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll, version='3.510.0.0'
    C:\Windows\system32\OLEAUT32.dll, version='6.1.7601.17567'
    C:\Windows\WinSxS\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895\ATL90.DLL, version='9.00.30729.6161'
    C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcm90.dll, version='9.00.30729.6161'
    C:\Windows\system32\d2d1.dll, version='6.1.7601.17563 (win7sp1_gdr.110218-1555)'
    C:\Windows\system32\dwrite.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\RpcRtRemote.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\wtsapi32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\WINSTA.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\version.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\SetupApi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\CFGMGR32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\DEVOBJ.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\WINTRUST.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\CRYPT32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\MSASN1.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\CLBCatQ.DLL, version='2001.12.8530.16385 (win7_rtm.090713-1255)'
    C:\Program Files\Paint.NET\Effects\AlignPlugin.dll, version='1.5.1.0'
    C:\Program Files\Paint.NET\Effects\AlphaMask.dll, version='2.0.3574.41943'
    C:\Program Files\Paint.NET\Effects\AlphaMaskBrush.dll, version='1.5.0.0'
    C:\Program Files\Paint.NET\Effects\Bars.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll, version='1.8.3627.29848'
    C:\Program Files\Paint.NET\Effects\Boutons.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Bullet.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Burninate.dll, version='1.1.3182.28956'
    C:\Program Files\Paint.NET\Effects\Channels.dll, version='2.0.0.0'
    C:\Program Files\Paint.NET\Effects\CodeLab.dll, version='1.5.3727.29997'
    C:\Program Files\Paint.NET\Effects\Color Match.dll, version='1.1.3627.29847'
    C:\Program Files\Paint.NET\Effects\Color2alpha.dll, version='1.0.3683.30667'
    C:\Program Files\Paint.NET\Effects\ColorBalance.dll, version='1.1.3182.30196'
    C:\Program Files\Paint.NET\Effects\ColorModulo.dll, version='0.0.0.0'
    C:\Program Files\Paint.NET\Effects\coltoalphaadv.dll, version='2.0.3683.22872'
    C:\Program Files\Paint.NET\Effects\ConditionalPen.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\CreateImageMap.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll, version='11.1.3736.39220'
    C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Curves+.dll, version='3.0.3627.29849'
    C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll, version='1.9.0.0'
    C:\Program Files\Paint.NET\Effects\DesktopBackgroundPreview.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Displacement.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\EdHarvey.Edfects.Common.dll, version='3.36.3160.38013'
    C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll, version='3.36.3160.38013'
    C:\Program Files\Paint.NET\Effects\EditableText.dll, version='1.0.1.0'
    C:\Program Files\Paint.NET\Effects\EOEffects.dll, version='1.7.0.0'
    C:\Program Files\Paint.NET\Effects\Feather.dll, version='3.0.3723.26349'
    C:\Program Files\Paint.NET\Effects\Film.dll, version='2.0.3612.21577'
    C:\Program Files\Paint.NET\Effects\FilmNoir.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\FindEdges.dll, version='1.2.0.0'
    C:\Program Files\Paint.NET\Effects\Fire.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Flags.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Flip.dll, version='2.0.0.0'
    C:\Program Files\Paint.NET\Effects\Frame.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll, version='1.1.3182.30307'
    C:\Program Files\Paint.NET\Effects\GenTree.dll, version='0.1.0.0'
    C:\Program Files\Paint.NET\Effects\Gradient Bars.dll, version='3.0.3627.29850'
    C:\Program Files\Paint.NET\Effects\Gradient Blur.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll, version='3.0.3627.29847'
    C:\Program Files\Paint.NET\Effects\Gravity.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\GridMaker.dll, version='3.2.0.0'
    C:\Program Files\Paint.NET\Effects\HexaGrid.dll, version='1.2.0.0'
    C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll, version='2.6.2.0'
    C:\Program Files\Paint.NET\Effects\IsolateWhiteBlack.dll, version='1.3.3676.24989'
    C:\Program Files\Paint.NET\Effects\Jitter.dll, version='3.0.3612.21576'
    C:\Program Files\Paint.NET\Effects\JPEGEffect.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\KaleidoGen.dll, version='1.2.0.0'
    C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll, version='1.3.0.0'
    C:\Program Files\Paint.NET\Effects\Landscape.dll, version='1.1.3593.25344'
    C:\Program Files\Paint.NET\Effects\LensFlare.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\LightRays.dll, version='1.3.0.0'
    C:\Program Files\Paint.NET\Effects\Lomography.dll, version='1.1.3182.31441'
    C:\Program Files\Paint.NET\Effects\Majority.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Moire.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\MotionSharpen.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Nebulous.dll, version='0.0.0.0'
    C:\Program Files\Paint.NET\Effects\NewtonFractal.dll, version='0.0.0.0'
    C:\Program Files\Paint.NET\Effects\Oblique.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Olden.dll, version='1.5.0.0'
    C:\Program Files\Paint.NET\Effects\Outline Object.dll, version='2.6.3612.21574'
    C:\Program Files\Paint.NET\Effects\Outline.dll, version='1.1.3160.31739'
    C:\Program Files\Paint.NET\Effects\PageCurl.dll, version='1.3.0.0'
    C:\Program Files\Paint.NET\Effects\Panelling.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Pastel.dll, version='1.2.3182.29587'
    C:\Program Files\Paint.NET\Effects\PDNWatermark.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Pixelate+.dll, version='1.0.3612.21574'
    C:\Program Files\Paint.NET\Effects\PixelatedFrame.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Polar.dll, version='1.1.1.0'
    C:\Program Files\Paint.NET\Effects\Polygon.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Polygones.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\PrinterPlus.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\pyrochild.effects.REQUIRED.dll, version='3.6.3710.33689'
    C:\Program Files\Paint.NET\Effects\Radialcolors.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\RainbowTwist.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Random Effect.dll, version='1.3.3627.29846'
    C:\Program Files\Paint.NET\Effects\Random lines.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Random Maze1.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Random Maze2.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll, version='1.5.3621.26292'
    C:\Program Files\Paint.NET\Effects\Rosaces.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\SBCommon.dll, version='3.0.0.0'
    C:\Program Files\Paint.NET\Effects\ScriptLab.dll, version='2.6.3627.29850'
    C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\SelectionTools.dll, version='1.1.3182.28742'
    C:\Program Files\Paint.NET\Effects\Shape3D.dll, version='1.2.6.0'
    C:\Program Files\Paint.NET\Effects\silhouetteplugs.dll, version='1.1.3748.12146'
    C:\Program Files\Paint.NET\Effects\SinWaves.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Smudge.dll, version='2.4.3710.33790'
    C:\Program Files\Paint.NET\Effects\Sparkles.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Spiral.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\SpiroGraph.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\SpiroShapes.dll, version='1.4.0.0'
    C:\Program Files\Paint.NET\Effects\Splashes.dll, version='1.1.1.0'
    C:\Program Files\Paint.NET\Effects\Splatter.dll, version='1.6.3627.29848'
    C:\Program Files\Paint.NET\Effects\Stars.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Steganography.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Stitch.dll, version='1.0.3627.29848'
    C:\Program Files\Paint.NET\Effects\StockLibrary.dll, version='1.5.0.0'
    C:\Program Files\Paint.NET\Effects\SubtleEffect.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Texture.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll, version='2.1.0.0'
    C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll, version='0.0.0.0'
    C:\Program Files\Paint.NET\Effects\Tiles.dll, version='1.1.1.0'
    C:\Program Files\Paint.NET\Effects\Transitional Brush.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\Transparency.dll, version='1.1.3182.29244'
    C:\Program Files\Paint.NET\Effects\TreeGen.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\TubeOblique.dll, version='1.0.0.0'
    C:\Program Files\Paint.NET\Effects\TwistZ.dll, version='1.1.2.0'
    C:\Program Files\Paint.NET\Effects\Vibrato.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Volutes.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\WaterReflection.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\Waves.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\WetFloor.dll, version='1.1.0.0'
    C:\Program Files\Paint.NET\Effects\XYCoords.dll, version='1.0.0.0'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Design\9f162ee8ce0ec6b2a539b68041421911\System.Design.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
    C:\Windows\system32\RichEd20.DLL, version='5.31.23.1230'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\ICSharpCode.SharpZi#\4782a84cfd77863a6eea670f101faf27\ICSharpCode.SharpZipLib.ni.dll, version='0.86.0.518'
    C:\Windows\system32\explorerframe.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\DUser.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\DUI70.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Xml\318b11a6b944c9ef2998d374c9d5bda8\System.Xml.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
    C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll, version='1.6.0.0'
    C:\Windows\System32\comdlg32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\propsys.dll, version='7.00.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\ntmarta.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\WLDAP32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\apphelp.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Users\Mike Ryan\AppData\Roaming\Dropbox\bin\DropboxExt64.14.dll, version='1.0.0.14'
    C:\Windows\system32\dbghelp.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\msvcp60.dll, version='7.0.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\EhStorShell.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\PROGRA~1\MICROS~4\Office14\GROOVEEX.DLL, version='14.0.4734.1000'
    C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCP90.dll, version='9.00.30729.6161'
    C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE14\Cultures\office.odf, version='14.0.4730.1010'
    C:\PROGRA~1\MICROS~4\Office14\1033\GrooveIntlResource.dll, version='14.0.4734.1000'
    C:\Windows\System32\cscui.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\System32\CSCDLL.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\CSCAPI.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\msls31.dll, version='3.10.349.0'
    C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\xmllite.dll, version='1.3.1000.0'
    C:\Windows\system32\OLEACC.dll, version='7.0.0.0 (win7_rtm.090713-1255)'
    C:\Windows\system32\UIAutomationCore.dll, version='7.0.0.0 (win7_rtm.090713-1255)'
    C:\Windows\system32\PSAPI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\SXS.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\System32\StructuredQuery.dll, version='7.00.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\System32\Secur32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\System32\SSPICLI.DLL, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\actxprxy.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Program Files\Internet Explorer\ieproxy.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
    C:\Windows\system32\thumbcache.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\SearchFolder.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\SHDOCVW.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\ieframe.DLL, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
    C:\Windows\system32\iertutil.dll, version='9.00.8112.16434 (WIN7_IE9_GDR.110721-1800)'
    C:\Windows\system32\samcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\SAMLIB.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\netutils.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\slc.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\NetworkExplorer.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\LINKINFO.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\MPR.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\wkscli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\WINMM.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\PortableDeviceApi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\ntshrui.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\srvcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\EhStorAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\IconCodecService.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\NetworkItemFactory.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\dtsh.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\FirewallAPI.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\wbem\wbemprox.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\wbemcomn.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\WS2_32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\NSI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\wbem\wbemsvc.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\wbem\fastprox.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\NTDSAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\System32\npmproxy.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\FunDisc.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\ATL.DLL, version='3.05.2284'
    C:\Windows\System32\msxml6.dll, version='6.30.7601.17514'
    C:\Windows\system32\fdproxy.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\System32\fdwcn.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\System32\wcnapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\fdWNet.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\IPHLPAPI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\WINNSI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\dfscli.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\browcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\mswsock.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\DNSAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\rasadhlp.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\dhcpcsvc6.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\dhcpcsvc.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Program Files\Common Files\Adobe\Adobe Drive CS4\ADFSMenu.dll, version='4.0.0.0client1'
    C:\Program Files\Windows Sidebar\sbdrop.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\atiacm64.dll, version='6.14.10.2001'
    C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\atiamenu.dll, version='6.14.10.2001'
    C:\Windows\system32\mssprxy.dll, version='7.00.7600.16385 (win7_rtm.090713-1255)'
    C:\Program Files (x86)\FileZilla FTP Client\fzshellext_64.dll, version='3, 2, 7, 0'
    C:\Windows\system32\urlmon.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
    C:\Windows\system32\WININET.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
    C:\Windows\system32\Normaliz.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\ktmw32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\d3d10_1.dll, version='6.1.7601.17544 (win7sp1_gdr.110116-1505)'
    C:\Windows\system32\d3d10_1core.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\dxgi.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\Microsoft.NET\Framework64\v2.0.50727\diasymreader.dll, version='8.0.50727.5420 (Win7SP1.050727-5400)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Security\f330ec3533f2f0cb4c6dacd3a3e48044\System.Security.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\Accessibility\23ea8465ac746c69a6ed7fdf628d3e9c\Accessibility.ni.dll, version='2.0.50727.4927 (NetFXspW7.050727-4900)'
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Configuration\df2bfb30ffdbfbb49d2c5ef6fc763578\System.Configuration.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
    C:\Windows\system32\mscms.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\USERENV.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\PhotoMetadataHandler.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\zipfldr.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Program Files\7-Zip\7-zip.dll, version='4.65'
    C:\Windows\System32\drprov.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\System32\ntlanman.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\System32\davclnt.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\System32\DAVHLPR.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\PortableDeviceTypes.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\syncui.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\SYNCENG.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\twext.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\System32\cscobj.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Program Files (x86)\MagicISO\misosh64.dll, version='5, 3, 0, 198'
    c:\PROGRA~1\MI8079~1\shellext.dll, version='2.1.1116.0'
    C:\Windows\system32\msi.dll, version='5.0.7601.17514'
    C:\Windows\system32\imagehlp.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\ncrypt.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\bcrypt.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\system32\bcryptprimitives.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
    C:\Windows\system32\GPAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
    C:\Windows\System32\msxml3.dll, version='8.110.7601.17514'
    Exception details:
    System.ArgumentException: Parameter is not valid.
    at System.Drawing.Image.FromStream(Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData)
    at PaintDotNet.PdnResources.LoadImage(Stream input) in D:\src\pdn\pdn_35x\src\Resources\PdnResources.cs:line 495
    at PaintDotNet.PdnResources.GetImage(String fileName) in D:\src\pdn\pdn_35x\src\Resources\PdnResources.cs:line 332
    at PaintDotNet.Resource`1.get_Reference() in D:\src\pdn\pdn_35x\src\Base\Resource`1.cs:line 28
    at PaintDotNet.Menus.PdnMenuItem.SetIcon(String imageName) in D:\src\pdn\pdn_35x\src\PaintDotNet\Menus\PdnMenuItem.cs:line 245
    at PaintDotNet.Menus.PdnMenuItem.LoadIcons() in D:\src\pdn\pdn_35x\src\PaintDotNet\Menus\PdnMenuItem.cs:line 271
    at System.Windows.Forms.ToolStripDropDownItem.OnDropDownShow(EventArgs e)
    at System.Windows.Forms.ToolStripDropDownItem.ShowDropDownInternal()
    at System.Windows.Forms.ToolStripDropDownItem.ShowDropDown(Boolean mousePush)
    at System.Windows.Forms.ToolStripItem.HandleMouseDown(MouseEventArgs e)
    at System.Windows.Forms.ToolStrip.OnMouseDown(MouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.MenuStrip.WndProc(Message& m)
    at PaintDotNet.SystemLayer.MenuStripEx.WndProc(Message& m) in D:\src\pdn\pdn_35x\src\SystemLayer\MenuStripEx.cs:line 60
  6. How often would one want to make a selection of (n x 5) vs (n x 5) + 1? I can't claim to have done any research on the matter, but I know from personal experience that I am targeting a multiple of five way more often than I am targeting anything in between. This certainly isn't a suggestion made off of a whimsy, but one made after quite some time with the software. I think I would prefer even sets over odd sets if you don't like skipping a digit, going from 2,4,6,8,10,... instead of 1,3,5,7,9,...
    Now obviously you can't tailor the software to my personal preference, but I just don't think I am the only one finding myself targeting multiples of five over odd digits. This also seems like a problem that most people wouldn't know they had, one way or another.
  7. This is just a suggestion to increase productivity and usability with the selection tool. When a large image is zoomed out and you create a selection, obviously not every mouse increment can correspond to increasing or decreasing the width or height by a single pixel.
    But this can cause some problems. For example, if I am viewing an image at just 50%, the selection will increment or decrement by 2px starting at 1px, leading each increment to be an odd number. For those working in design, this can be somewhat frustrating especially when trying to create selections 300x200, or some other even number. To remedy this, I suggest snapping these selections to increments of five. So instead of the with going 235,237,239,241 it would go 235,237,240,241. That way you hit every single multiple of five and ten.
    I know my explanation of this problem is pretty poor, but it really is hard to describe this little problem.
    Thanks,
    Mike
  8. I was just drawing a transparent gradient. Perhaps I drew it too quickly? I do not know. Let me know if this could be in anyway related to memory issues.
    Application version: Paint.NET v3.5.6 (Final Release build 3.56.3972.42619)
    Time of crash: 1/26/2011 9:28:04 AM
    Application uptime: 00:01:50.1495274
    OS Version: 6.1.7600.0 Workstation x64
    .NET version: CLR 2.0.50727.4952 x64, FX 2.0 (rtm sp1 sp2) 3.0 (rtm sp1 sp2) 3.5 (rtm sp1 sp1_CP) 4.0 (rtm rtmEx)
    Processor: 6x "AMD Phenom II X6 1090T Processor" @ ~3680MHz (DEP, SSE, SSE2, SSE3), fps=0x1
    UI Theme: Aero/Aero + DWM (Aero.msstyles)
    Updates: true, 1/16/2011
    Managed assemblies:
    PaintDotNet, Version=3.56.3972.42626, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
    PaintDotNet.Base, Version=3.56.3972.42612, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
    PaintDotNet.Core, Version=3.56.3972.42620, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
    PaintDotNet.SystemLayer, Version=3.56.3972.42618, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
    PaintDotNet.Resources, Version=3.56.3972.42619, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
    PaintDotNet.Data, Version=3.56.3972.42623, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
    PaintDotNet.Effects, Version=3.56.3972.42625, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll
    PaintDotNet.SystemLayer.Native.x64, Version=3.56.3972.42618, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll
    msvcm90, Version=9.0.30729.4926, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554\msvcm90.dll
    Native modules:
    C:\Windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_88dce9872fb18caf\MSVCR80.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\mscorlib\2e16a238456fbe4a41233d7a732d086b\mscorlib.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System\65f46521e7fca2cd2d216162175f2fd6\System.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Core\6ef98a068f45cbf57702eab0f623d007\System.Core.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\WindowsBase\bdb953c9c0fcd5c281b1bcbcfb527bd2\WindowsBase.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Drawing\e48f514a13b9d9ddd60c82b64e68dc11\System.Drawing.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Windows.Forms\d6fb1e55b2ba3ab8b2815181133130e3\System.Windows.Forms.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Base\b266e4fb2dd5b3c7357c792d43a63e24\PaintDotNet.Base.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\dbcb983da631434fc9d4f852c4093c51\PaintDotNet.SystemLayer.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Resourc#\7136cce5af3f4c50c1db29b1b6b98a7b\PaintDotNet.Resources.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Core\7ebf129d3cae6835e28f5066bf500893\PaintDotNet.Core.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Data\4b51d7747d1e9787ec67c1323e9ddb47\PaintDotNet.Data.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet\28655887b4f95e0d3196914f9aa414fe\PaintDotNet.ni.exe
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\d7a77e9e761c87205fd3ebc6b8b0dd98\PaintDotNet.SystemLayer.Native.x64.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\Interop.WIA\cbceebd16fd592cab8f636a09590c40a\Interop.WIA.ni.dll
    C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Effects\8530f84a1411d66c26289af226ba8255\PaintDotNet.Effects.ni.dll
    C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554\MSVCR90.dll
    C:\Windows\WinSxS\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.4148_none_390a91d20a21a864\VCOMP90.DLL
    C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_2b4f45e87195fcc4\gdiplus.dll
    C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_fa62ad231704eab7\comctl32.dll
    C:\Windows\WinSxS\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4148_none_0a1d2fcba76b3f00\ATL90.DLL
    C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Design\a78ec0117a85a48e1c7c816946c64915\System.Design.ni.dll
    C:\Windows\system32\psapi.dll
    Exception details:
    PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.Runtime.InteropServices.SEHException: External component has thrown an exception.
    at PaintDotNet.Rendering.GradientRenderer.Render(Surface surface, Int32Rect[] rois, Int32 startIndex, Int32 length) in D:\src\pdn\pdn_35x\src\PaintDotNet\Rendering\GradientRenderer.cs:line 224
    at PaintDotNet.Tools.GradientTool.RenderContext.Render(Object cpuIndexObj) in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\GradientTool.cs:line 229
    at PaintDotNet.Threading.PrivateThreadPool.ThreadWrapperContext.ThreadWrapper() in D:\src\pdn\pdn_35x\src\Core\Threading\PrivateThreadPool.cs:line 179
    at PaintDotNet.Threading.PrivateThreadPool.DrainExceptions() in D:\src\pdn\pdn_35x\src\Core\Threading\PrivateThreadPool.cs:line 74
    at PaintDotNet.Tools.GradientTool.RenderGradient(Surface surface, GeometryList clipGeometry, CompositingMode compositingMode, Point startPointF, ColorBgra startColor, Point endPointF, ColorBgra endColor) in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\GradientTool.cs:line 248
    at PaintDotNet.Tools.GradientTool.RenderGradient() in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\GradientTool.cs:line 325
    at PaintDotNet.Tools.GradientTool.OnMouseMove(MouseEventArgsF e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\GradientTool.cs:line 568
    at PaintDotNet.Tools.Tool.MouseMove(MouseEventArgsF e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Tools\Tool.cs:line 790
    at PaintDotNet.Controls.AppWorkspace.DocumentMouseMoveHandler(Object sender, MouseEventArgsF e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Controls\AppWorkspace.cs:line 1777
    at PaintDotNet.Controls.DocumentView.OnDocumentMouseMove(MouseEventArgsF e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Controls\DocumentView.cs:line 1093
    at PaintDotNet.Controls.DocumentView.MouseMoveHandler(Object sender, MouseEventArgs e) in D:\src\pdn\pdn_35x\src\PaintDotNet\Controls\DocumentView.cs:line 1507
    at System.Windows.Forms.Control.WmMouseMove(Message& m)
    at PaintDotNet.SystemLayer.GdiPaintControl.WndProc(Message& m) in D:\src\pdn\pdn_35x\src\SystemLayer\GdiPaintControl.cs:line 151
  9. WEEKLY TUTORIAL COMPETITION
    The Discussion Thread
    The WTC Rules [Required Reading]
    • There is no maximum image size but if any of the images are larger than 800x800, please LINK to it instead!
    • No crude / offensive language, pics, et cetera.
    • Submissions will be disqualified if it does not match the theme of the tutorial!
    • Only one entry per person and no modifications to your image are allowed after submitting your entry.
    • Unless the tutorial SPECIFICALLY calls for a stock image, no stock images are allowed!
    • You are allowed one post in this topic. That post should include your entry, links to your source images.
    • Beyond these rules, if the competition host finds that the entry is clearly inappropriate for one reason or another, he or she may disqualify that entry without warning
    • Note: Unlike other competitions, the winner does NOT get to choose the theme for next week's competition, but he or she is welcome to make suggestions
  10. WEEKLY TUTORIAL COMPETITION
    How to Make a Sliced 3D Orange by csm725
    Link: | Deadline: Midnight, September 4th, 2010
    Welcome to the Brand New WTC!
    Welcome to the brand new Weekly Tutorial Competition. In this competition, the theme is determined by a tutorial. Your task? To take what you learn from the tutorial and create something even better. Since this is the first time this competition has ever run, here are my suggestions for the selected tutorial: think about ways to make the orange more realistic. A bland, white background might not be the most suitable choice to present your orange. Think about shadows and the overall texture of the orange. May the best orange win!
    Deadline: Midnight on September 4th, 2010
    The deadline is at midnight on September 4th, 2010. Late entries are accepted until I close the thread. The competition will not end if there are less than five entries. Voting will begin within one to two days after the competition has ended. My timezone is Central (US and Canada). Good luck, everybody!
