Posts
5,016 -
Joined
Last visited
Days Won
155
Posts posted by toe_head2001
Please check your keyboard to ensure the F8 key is not stuck.
- 1
The Project Type is now in the tab's tooltip.
- 1
- 1
2 hours ago, BoltBait said:
Make sure the file name does not have a space in it.
I thought that issue was solved a very long time ago.
Edit: Fixed in CodeLab. Must have been lost during the GPU refactoring.
19 minutes ago, Marvin321 said:
because https://bugzilla.mozilla.org/show_bug.cgi?id=1866655 says paint.net is faulty on that one
That is not the conclusion in the bug report.
22 minutes ago, Marvin321 said:The bug is 2 months old and we got no fix yet
I think it's safe to say a niche clipboard bug is not a top priority, so it may take some time for them to address it.
This usually happens when some accidentally saves a PNG file with a .PDN file extension.
Please try to rename the file.
If that doesn't fix the issue, feel free to post the file so we can inspect it.
I doubt you'll get much traction from those support tickets.
There's a Mozilla bug filed. Just give them time to address it.
Did you really need to post this (and to Reddit also)?
Seems like you can just send a private message to @Welsh Yellow Cheddar.
Otherwise, you're just going to have people playing the guessing game.
1) Set the Blending Mode to Overwrite
2) Set the Opacity to 0
35 minutes ago, Otto04 said:
Now I need these filters again... but it looks like that they arent available for free to download anymore?
These are the old google NIK Collection Filters and all i can find now is a free 30 day trail but not the ones I had there anymore.
https://dl.google.com/edgedl/photos/nikcollection-full-1.2.11.exe
- 1
I like your padding suggestion. I'll look into more this weekend.
- 1
Image backgrounds are always forced to white in the Polls.
21 hours ago, Red ochre said:I suggest the competition should become 'Image of the fortnight' as default, perhaps with occasional 'object' themes and rules?
I don't know about becoming the new default, but it could be good to do from time to time.
10 hours ago, Xxmike_5595 said:
Application uptime: 00:00:01.6212606
Looks like the program crashed upon starting.
Please post the diagnostic information found within paint.net.
Settings -> Diagnostics -> Copy to clipboard.
If the Quantize effect is not present in the Color submenu, then it sounds like you're using an old version of Paint.NET.
Settings -> Updates -> Check Now
40 minutes ago, HenryH said:
i have some suggestions about (moderator(s) and Old-timers) making requests and sending "polite" PM's.
If you have suggestions, feel free to share them.
@ayuditaaa, please ensure that you are using the most recent version of Paint.NET.
- 1
Try pressing
Ctrl
+Shift
+F8
, which can restore the Colors window to the proper size and location. -
2 hours ago, DLCooper52 said:
Shouldn't PaintNet apply a vigorous fix, one that is reliable and easy to use
Can you elaborate on this "magic bullet" solution?
You can add your own custom crosshair with Microsoft PowerToys, which will appear even using the paint brush.
- 4
34 minutes ago, Jimi said:
... hourglass shows for a second, then nothing else.
Nothing else?
So the PaintDotNet.exe process never starts?
Or does the the PaintDotNet.exe process start then immediately exit?
1 minute ago, ghost2023 said:
... even if i right click and choose PDN i just get a little blue circle and it doesnt open ...
Just the image doesn't open, or the entire Paint.NET program doesn't open?
Error in Plugin Browser plugin installed from TechnoRobo plugin pack
in Troubleshooting & Bug Reports
Posted
The latest version of the Plugin Browser plugin can be found here:
https://forums.getpaint.net/topic/110458-the-plugin-browser/
