Posts
5,013 -
Joined
Last visited
Days Won
153
Posts posted by toe_head2001
could i add any other packs too?
You can use as many plugins (or plugin packs) as you want.
Did not.
I also tried compiling the source only to find the errors MJW reported. I did get it working with selection.Right -1 that Red used but I missed the continuation && CurrentPixel.A==0&&src[x,y-p].A==255) which simply didn't appear in the code I copied & pasted from the forum. The formatting was awry so it may have been a forum software issue.
It worked when I made my comment about using CodeLab. You must have copied it after you started your edit.
While I there's no archive from yesterday, you can see the script in the post was fine until it was edited.
https://web.archive.org/web/20160320182657/http://forums.getpaint.net/index.php?showtopic=7644
Yeah, the code worked fine yesterday. It got mangled somehow when @Ego Eram Reputo edited the post to add the attachment.
I want to, but is the downloadlink still valid? Where can I get it?
You have two options.
@pyjo provided the source code on that page. You can Copy & Paste it into CodeLab.
or you can download it from archive.org https://web.archive.org/web/20130309145847/http://pgciarlo.interfree.it/Plugins/BasicAntialias11.zip
The Basic Antialias plugin won't solve your issue though.
Hey @Darty,
Here's what I did:
1) Ran Median ( ) at default values
2) Ran the AA's_Assistant plugin at default values
Here you go. The new code I added is at the bottom of the script.
Spoiler// Name: AC Phasor Diagram // Submenu: Render // Author: // Title: // Version: 1.0 // Desc: // Keywords: // URL: // Help: #region UICode DoubleSliderControl Amount1 = 0.8; // [0.1,0.8] Voltage circle diameter DoubleSliderControl Amount2 = 0.7; // [0.1,0.8] Current circle diameter IntSliderControl Amount3 = 3; // [1,10] Circle thickness IntSliderControl Amount4 = 3; // [1,10] Voltage phasor thickness IntSliderControl Amount5 = 3; // [1,10] Current phasor thickness IntSliderControl Amount6 = -30; // [-360,360] Rotating voltage phasor IntSliderControl Amount7 = -5; // [-360,360] Rotating current phasor CheckboxControl Amount8 = false; // [0,1] Change the sequence #endregion void Render(Surface dst, Surface src, Rectangle rect) { Rectangle selection = EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt(); float centerX = ((selection.Right - selection.Left) / 2f) + selection.Left; float centerY = ((selection.Bottom - selection.Top) / 2f) + selection.Top; float diameterU = (float)Amount1 * Math.Min(selection.Width - 4, selection.Height - 4); float diameterI = (float)Amount2 * Math.Min(selection.Width - 4, selection.Height - 4); float radiusU = diameterU / 2f; float offsetXU = centerX - radiusU; float offsetYU = centerY - radiusU; float radiusI = diameterI / 2f; float offsetXI = centerX - radiusI; float offsetYI = centerY - radiusI; float startU = (float)(Amount6)-90; // 0 grade = 90 - 90 Ufazor 'R' float startI = (float)(Amount7)-90; // 0 grade = 90 - 90 Ifazor 'R' float sweep = 360f / 3; // 120 de grade bool sequence = Amount8; dst.CopySurface(src, rect.Location, rect); using (RenderArgs ra = new RenderArgs(dst)) { Graphics cerc = ra.Graphics; cerc.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.AntiAlias; cerc.Clip = new Region(rect); using (Pen cercPen = new Pen(ColorBgra.Black)) { // Desenează Cerc Fazori Curenti cercPen.Color = ColorBgra.AntiqueWhite; // Culoare cerc curenti cercPen.Width = Amount3; // Grosime Cerc cercPen.DashStyle = DashStyle.Solid; // Linie Cerc cerc.DrawEllipse(cercPen, offsetXI, offsetYI, diameterI, diameterI); // ******* // Fazor curent 'S' cercPen.Width = Amount5; // Grosime Fazori Curenti cercPen.DashStyle = DashStyle.Dash; // Linie fazor curent cercPen.Color = (ColorBgra.Orange); // Culoare Fazor 'S' { if (!sequence) { startI = startI + 120; } float angleI = startI + sweep; double radianI = Math.PI / 180 * angleI; float endX = (float)(radiusI * Math.Sin(radianI)); float helperAngleI = 90 - angleI; double helperRadianI = Math.PI / 180 * helperAngleI; float endY = (float)(radiusI * Math.Sin(helperRadianI)); cerc.DrawLine(cercPen, centerX, centerY, centerX - endX, centerY - endY); } // ******* // Fazor curent 'T' cercPen.DashStyle = DashStyle.Dash; // Linie fazor curent cercPen.Color = (ColorBgra.Blue); // Culoare Fazor 'T' { if (!sequence) { startI = startI + 120; } float angleI = startI + sweep * 2; double radianI = Math.PI / 180 * angleI; float endX = (float)(radiusI * Math.Sin(radianI)); float helperAngleI = 90 - angleI; double helperRadianI = Math.PI / 180 * helperAngleI; float endY = (float)(radiusI * Math.Sin(helperRadianI)); cerc.DrawLine(cercPen, centerX, centerY, centerX - endX, centerY - endY); } // ******* // Fazor curent 'R' cercPen.DashStyle = DashStyle.Dash; // Linie fazor curent cercPen.Color = (ColorBgra.Red); // Culoare Fazor 'R' { if (!sequence) { startI = startI + 120; } float angleI = startI + sweep * 3; double radianI = Math.PI / 180 * angleI; float endX = (float)(radiusI * Math.Sin(radianI)); float helperAngleI = 90 - angleI; double helperRadianI = Math.PI / 180 * helperAngleI; float endY = (float)(radiusI * Math.Sin(helperRadianI)); cerc.DrawLine(cercPen, centerX, centerY, centerX - endX, centerY - endY); } // Desenează Cerc Fazori Tensiuni cercPen.Color = ColorBgra.LightGray; // Culoare cerc tensiuni cercPen.Width = Amount3; // Grosime Cerc cercPen.DashStyle = DashStyle.Solid; // Linie Cerc cerc.DrawEllipse(cercPen, offsetXU, offsetYU, diameterU, diameterU); // Desenează Fazori // ******* // Fazor tensiune 'S' cercPen.Width = Amount4; // Grosime Fazori Tensiune cercPen.DashStyle = DashStyle.Solid; // Linie fazor tensiune cercPen.Color = (ColorBgra.Orange); // Culoare Fazor 'S' { if (!sequence) { startU = startU + 120; } float angleU = startU + sweep; double radianU = Math.PI / 180 * angleU; float endX = (float)(radiusU * Math.Sin(radianU)); float helperAngleU = 90 - angleU; double helperRadianU = Math.PI / 180 * helperAngleU; float endY = (float)(radiusU * Math.Sin(helperRadianU)); cerc.DrawLine(cercPen, centerX, centerY, centerX - endX, centerY - endY); } // ******* // Fazor tensiune 'T' cercPen.DashStyle = DashStyle.Solid; // Linie fazor tensiune cercPen.Color = (ColorBgra.Blue); // Culoare Fazor 'T' { if (!sequence) { startU = startU + 120; } float angleU = startU + sweep * 2; double radianU = Math.PI / 180 * angleU; float endX = (float)(radiusU * Math.Sin(radianU)); float helperAngleU = 90 - angleU; double helperRadianU = Math.PI / 180 * helperAngleU; float endY = (float)(radiusU * Math.Sin(helperRadianU)); cerc.DrawLine(cercPen, centerX, centerY, centerX - endX, centerY - endY); } // ******* // Fazor tensiune 'R' cercPen.DashStyle = DashStyle.Solid; // Linie fazor tensiune cercPen.Color = (ColorBgra.Red); // Culoare Fazor 'R' { if (!sequence) { startU = startU + 120; } float angleU = startU + sweep * 3; double radianU = Math.PI / 180 * angleU; float endX = (float)(radiusU * Math.Sin(radianU)); float helperAngleU = 90 - angleU; double helperRadianU = Math.PI / 180 * helperAngleU; float endY = (float)(radiusU * Math.Sin(helperRadianU)); cerc.DrawLine(cercPen, centerX, centerY, centerX - endX, centerY - endY); } } StringFormat format = new StringFormat(); format.Alignment = StringAlignment.Center; format.LineAlignment = StringAlignment.Center; using (SolidBrush textBrush = new SolidBrush(Color.Black)) using (Font textFont = new Font("Arial", 16, FontStyle.Bold)) { for (int fazor = 1; fazor < 4; fazor++) { float angle = startU + sweep * fazor; double radian = Math.PI / 180 * angle; float endX = (float)((radiusU + 20) * Math.Sin(radian)); float helperAngle = 90 - angle; double helperRadian = Math.PI / 180 * helperAngle; float endY = (float)((radiusU + 20) * Math.Sin(helperRadian)); switch (fazor) { case 1: textBrush.Color = Color.Blue; break; case 2: textBrush.Color = Color.Orange; break; case 3: textBrush.Color = Color.Red; break; } cerc.DrawString(fazor.ToString() + "V", textFont, textBrush, centerX - endX, centerY - endY, format); } } } }
- 2
Ok, that is not too difficult. I'll post some example code for you a little later.
I'm not sure I understand. Do you want the text to look like this?
First, go back to v4.0.9. There's no reason to be on that old version.
Please copy the full text of the crash message, and post it here.
(click on "Show Details" to see the full text)
Do you have the selection method set to Subtract?
see Selection Modes:
- 1
What's stopping you from downloading it?
@CTR640, Please run this diagnostics tool. It will tell us the root cause of the issue.
http://forums.getpaint.net/index.php?/topic/107908-1603-error-diagnostic-tool/
Some important plugins are still not showing up for me despite unblocking them. Curves+, Vibrance and Random Shape Fill are still not showing up and if I unblock them, their DLLs somehow need to be re-unblocked over and over as if unblocking them cannot be persistent. Any help with this? These are very important effects to me.
Make sure the both Effects folder and the dll file are not set to Read-only.
Since this plugin breaks/crashes in the upcoming paint.net v4.0.10 release, I've converted it to a standard IndirectUI plugin. (DataDink appears to be on a hiatus). No other changes were made.
See details here: http://forums.getpaint.net/index.php?/topic/107032-tile/#comment-511100
EDIT: This has been added to first post at the top of the page.
- 1
- 1
Running the Clouds effect on the text should do it.
The rest of the gun doesn't look battle worn; it's nice and shiny.
Ripping off another person's profile pic by slapping your own name on it is pretty lame though.
Ok, It is working. But I need more help again. I made first the blue grid 3x6 and now I need to fraction each cell into smaller grids (3x6 grids again) as the green one. However, when I select a cell and use the script I get the red ones. Could you make it work with selections as well? I hope I'm not asking too much and over-complicate the script. THANKS.
It was supposed to work on selections, but I forget to test that.
I've fixed it; it was a simple change. The updated script is in the original post.
... disable hardware accelerator only before you try anything else.
Disabling should be the last thing you do (the last resort). Try updating the drivers for your video card first.
I think Rick has a blacklist of problematic video cards. You should post which model your card is, so it can be added to the list if necessary.
Legal? Not here in the USA, as our copyright law includes provisions in EULAs. (Yes, copyright law can be extended just by adding provision in a EULA. How disgusting is that?)
If you purchased a CS2 product and are having activation issues, you can download replacement media from this page.
Only customers who legitimately purchased CS2 or Acrobat 7 and need to maintain their current use of these products may use the serial numbers provided during the download.
... and yes Adobe gave away a free version of PhotoShop (9) CS2.
That "free version" is meant for people who cannot activate their legitimate CS2 license, due to Adobe shutting off an old DRM server.
So technically, Adobe didn't give away Photoshop CS2, since you're supposed to already have a license from them.
- 1
On 6/24/2016 at 3:45 AM, sophie said:
Thank you, but how do I place it in the effects folder?
If you want it permanently in the Effects menu, CodeLab can create a dll file for you. Once you've created the dll file, place it in the effects folder just like any other plugin.
http://boltbait.com/pdn/codelab/help/buildingdll.php
If a script is short and simple, I like to keep it as script. Keeps the Effects menu tidy. But maybe that's just me. Create a dll if you like.
I like my scripts folders with my nice collection.
- 1
Here's the CodeLab script.
Hidden Content: CodeLab// Name: Hor x Ver Cells // Submenu: Render // Author: toe_head2001 // Title: // Version: 0.9 // Desc: // Keywords: // URL: // Help: #region UICode IntSliderControl Amount1 = 5; // [2,100] Line Thickness IntSliderControl Amount2 = 8; // [1,100] Horizontal Cells IntSliderControl Amount3 = 3; // [1,100] Vertical Cells #endregion void Render(Surface dst, Surface src, Rectangle rect) { Rectangle selection = EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt(); float horLoops = Amount2; float verLoops = Amount3; float horCellSize = (selection.Width - Amount1) / horLoops; float verCellSize = (selection.Height - Amount1) / verLoops; dst.CopySurface(src, rect.Location, rect); using (RenderArgs ra = new RenderArgs(dst)) { Graphics plane = ra.Graphics; plane.Clip = new Region(rect); using (Pen planePen = new Pen(EnvironmentParameters.PrimaryColor, Amount1)) { for (int i = 1; i < horLoops; i++) { plane.DrawLine(planePen, selection.Left + horCellSize * i + Amount1 / 2f, selection.Top, selection.Left + horCellSize * i + Amount1 / 2f, selection.Bottom); } for (int i = 1; i < verLoops; i++) { plane.DrawLine(planePen, selection.Left, selection.Top + verCellSize * i + Amount1 / 2f, selection.Right, selection.Top + verCellSize * i + Amount1 / 2f); } planePen.Alignment = PenAlignment.Inset; plane.DrawRectangle(planePen, selection); } } }
It works as you've described.
- 8
Looks like the outlining line is centered on the canvas edge; meaning half of it is hanging off the canvas. That should be pretty easy to solve. If I have time later tonight, I'll write a simple script for you.
uploading images here
Posted
That's fine; the forum software doesn't discriminate.
