Posts
121 -
Joined
Last visited
Posts posted by Alph Tech / STUART
Could I have an installer for 3.0? It's telling me I need the one with MSI product code GUID: {816A0870-6EC0-4DFF-B97C-E2CF820D7D6C}.
When it installs the new version, it can't find the MSI package for the last version. The PaintDotNet_######## number it gives for the 3.0 installer is different than the number the existing one has. When I browse to that MSI, it tells me it's not a valid PDN 3.0 installation package.
Huh. Yeah, OK, not reproducible.
That's the way it's supposed to work.
Why? This isn't useful at all. If I didn't want it to copy the next time I drag, I'd let go of the Ctrl key. That's how it works in Paint. There's no sense in making me switch tools just to "refresh my control quota".
This only works once per switch to the Move tool. For instance, if you hold control, drag a selectiion, drop it, and do it again, the second time it would only move the item, rather than do a copy each time like it should. This has been around since the implementation of Ctrl+Drag.
What is the point of the Alpha gradient tool? It seems like, to me, the only thing it does is creates a "white to black-with-the-opposite-alpha-value-of-the-primary-color". Why not just make a gradient with white and a black with the desired opacity? I thought the point of Paint.NET was to remove options like these that clutter up the UI.
EDIT: If you're looking for an alpha-replace type effect I believe the thing to do would be something like a black/white gradient with one of the layer filters on. I'm a bit pressed for time so I can't check which.
Select part of the image and click one of the "rotate"s from the Image menu.
Well, that's a start (Just a feature that could create a folder of shortcuts would do fine for this), but I'm just talking about a feature that would reopen whatever images the user had open next time they started PDN.
Could you make it so keypresses to find a font in the dropdown don't only work for the first letter, eg. "A - R - I" would take me to Arial rather then Algerian -> Rockwell -> Ignacious? Do this in Windows Explorer for an example.
Can you supply the crash.log that is probably on your desktop?
Actually, it was a hang.
Perhaps some sort of way to make PDN reopen with all the files it had, a la IE7's functionality? This would be especially useful for updates.
At least I'm assuming that's what triggered it.
So what's wrong with just setting up the same color with 2 different opacities and just turning off alpha blending?
Edit: just in general what is wrong with alpha colors
Hue/Saturation/Value. Sorry, I wanted to keep the title concise. Basically, anything with a value of 50 comes up as 49 when it's accessed again.
Example: Enter hex 7F4E08 into the pallete. It alternates between 49 and 50. I dunno, there's something up with this but I'm not 100% sure how to explain it.
Now what we NEED for this is a color-to-alpha tool.
But why? Paint.net is neither an OS or a licensing agreement.
By my count we currently have 112 icons for v2.2.
:shock:
Type width number and height number into Canvas Size.
Constrain to proportions.
Use the percentages.
Or just use a calculator and multiply both numbers.
See this. See this run. Run, this, run.
I know I've had peoples e-mail me before about some basic PDN workings questions or about my tutorials, but never about technical support.
Perhaps because your username is Alph Tech / STUART... >_>
Hmm.
Not off the bat, but there's always stuff like the ol' new-layer-with-a-Gaussian-Blur and such.
Ahhhhhhhhh, that's better. Seconded.
Not sure if he's bothered you guys either:
Sent: Friday, January 20, 2006 7:12 AM
Subject: Paint.NET v2.6 Beta 1 and Alpha 2
Importance: High
Dear Stuart,
I have been using Paint.NET for some months now, upgrading the various betas along the way. All was ok with the v2.5 versions. Unfortunately I updated to v2.6 and this is when the problems with my OS started. I did follow the instructions and download and install the MS .NET framework version 2.0 first. I must admit I had been having problems with my XP Prof SP2 and had to use System Restore to go back to a previous point. I had decided I didn’t need Paint.NET any more, so I tried removing Paint.NET v2.6 Beta 1 via Add/Remove Programs in the Windows Control Panel. It crashes out. I tried to reinstall old v 2.5 but it says I still have newer version available and stops installing. I try to reinstall either version 2.6 Beta 1 or v2.6 Alpha 2 but I always get pop-up error message stating:â€
Can't upgrade 3.0 to 3.0X- Staging weirdness
in Troubleshooting & Bug Reports
Posted
It's a problem with the staging. It's asking me to find an MSI I don't have and have likely never had.
I'm not trying to upgrade from a version before 2.6. I currently have 3.0 and can't upgrade to 3.07 or anything. I can't uninstall 3.0 either.
Edit: AAAAARGH
