TR's Croquis V 1.4 (Dwarf Horde Collaboration)
TechnoRobbo
TechnoRobbo's Croquis
​Quick Sketch Filter
3.5 compatible
v1.2 Slider and angle control by Red Ochre
v1.3 RetainColor and Invert Controls by BoltBait
v1.4 Pastel Effect by BoltBait
Menu: Effects->Artistic
CodeLab Source Code (it's a divide algorithm)
Hidden Content:
// Submenu: Artistic
// Name: TRs Croquis
// Title: TRs Croquis - v1.4
// Author: TechnoRobbo & Red Ochre & BoltBait
// URL: http://www.technorobbo.com
#region UICode
int Amount1 = 210; // [0,225] Contrast
int Amount2 = 0; // [0,255] Clip Lo
int Amount3 = 222; // [129,255] Clip Hi
double Amount4 = 0.5; // [0.1,10] Distance
double Amount5 = 45; // [-180,180] Angle
bool Amount6 = false; // [0,1] Retain Color
bool Amount7 = false; // [0,1] Invert
byte Amount8 = 0; // [1] Pastel Action|None|Invert|Rail
#endregion
private UnaryPixelOps.Invert invertOp = new UnaryPixelOps.Invert();
//private BinaryPixelOp multiplyOp = LayerBlendModeUtil.CreateCompositionOp(LayerBlendMode.Multiply); //for PDN 4
private UserBlendOp multiplyOp = new UserBlendOps.MultiplyBlendOp(); // Multiply for CodeLab 1.8 and Paint.NET 3.5x
    ColorBgra CP;
    Color rgb;
    double k;
    double l;
    float offX = (float)(Amount4 * Math.Cos(Amount5 * Math.PI / 180));
    float offY = (float)(Amount4 * Math.Sin(Amount5 * Math.PI / 180));
            CP = src.GetBilinearSampleWrapped((float)x + offX,(float)y + offY);
            rgb = CP.ToColor();
            l = rgb.GetBrightness();
            CP = src[x,y];
            rgb = CP.ToColor();
            k = rgb.GetBrightness();
            k = (k==0)? 0: l/k;
            k *=k;
            k *=255;
            k = (k>255)?255:k;
            double inverse = 255 - Amount1;
            k -= Amount1;
            k = (k<0) ? 0:k;
            k= k * 255 / inverse;
            k =(k < Amount2) ? 0: (k > Amount3) ? 255:k;
            dst[x,y] = ColorBgra.FromBgra((byte)k , (byte)k ,(byte)k, CP.A);
            if (Amount7)
                dst[x,y] = invertOp.Apply(dst[x,y]);
            if (Amount6)
                dst[x,y] = multiplyOp.Apply(dst[x,y],src[x,y]);
            if (Amount8!=0)
                ColorBgra CurrentPixel = dst[x,y];
                PaintDotNet.HsvColor hsv = PaintDotNet.HsvColor.FromColor(CurrentPixel.ToColor());
                int H = hsv.Hue;
                int S = hsv.Saturation;
                int V = hsv.Value;
                byte A = CurrentPixel.A;
                switch (Amount8)
                    case 1: V = 100-V;
                        break;
                    case 2: V = 100;
                        break;
                CurrentPixel = ColorBgra.FromColor(new PaintDotNet.HsvColor(H,S,V).ToColor());
                CurrentPixel.A = A;
                dst[x,y] = CurrentPixel;
TRsCroquis.zip
  • Upvote 8
TRsSig.png?raw=1
Hello TR and thank you.
I just tried the filter and somehow I can not get my charcoal to draw like yours. My sketch is very pixelated even when I use the same setting of your video. I guess I need to sharpen the tip of my pencil. :)
I just did it but it did not change much.
EDIT: I adjusted the levels (more black and white) of the picture before applying the filter and this is what I obtained:croquis01-4b80893.png
Edited by Eli
lfmdh6l7.png  Techno Robbo! Very nice plugin. Thank you for your effort.
I have 2 version, with or without color. I hope have done right.   xblf4ioa.gif
Edited by Seerose
  • Upvote 2
Gandhi
So go to one of BoltBaits Post and give him a +1
Haha! Thanks!
Here's something to try:
After running the plugin with both check boxes checked, you should get something that looks like colored chalk on an old blackboard. Then run this CodeLab script:
// Name: HSV Invert
// Submenu: Color
// Author: BoltBait
// URL: http://www.BoltBait.com
// Keywords: hsv|invert|color
// Title: BoltBait's HSV Quick Invert - v1.0
// Desc: Quickly invert H, S, or V in the HSV color space.
#region UICode
byte Amount1 = 0; // HSV Editing|Invert V|Invert S|Invert H|Maximize S|Maximize V
#endregion
            ColorBgra CurrentPixel = src[x,y];
            HsvColor hsv = HsvColor.FromColor(CurrentPixel.ToColor());
            int H = hsv.Hue;
            int V = hsv.Value;
            switch (Amount1)
                case 0: V = 100-V;
                    break;
                case 1: S = 100-S;
                    break;
                case 2: H += 180;
                    if (H>360) H -= 360;
                    break;
                case 3: S = 100;
                    break;
                case 4: V = 100;
                    break;
            CurrentPixel = ColorBgra.FromColor(new HsvColor(H,S,V).ToColor());
            CurrentPixel.A = A;
  • Upvote 2
...Will there be a dll for the script? (I do not understand code)   :roll: .
Today is not 1'st April, but still fun good.gif.
...So go to one of BoltBaits Post and give him a +1
Thanks BoltBait,
It really made me sweat the idea of using CodeLAb but I was so curious about the outcome of the script that I decided to try it . So this is the outcome :
I added a little gray on another layer.
Postedit:
I am sorry TR, I just realized that charcoal is... BLACK.
Edited by Eli
  • Upvote 3
At it's base this plugin has a charcoal sketch like result. But that was the outcome not the intent. I changed the description since it's obviously a tool like any other with no real rules on how you eventually use it.
TRsSig.png?raw=1
I've found it to be quite convenient for producing line art of basic 3D models, like below http://smiles.kolobok.us/standart/derisive.gif
reaper_base_and_line_art_side_to_side.jp
http://smiles.kolobok.us/artists/just_cuz/JC_you_rock.gifhttp://smiles.kolobok.us/artists/just_cuz/JC_ThankYou.gif
Edited by Maximilian
  • Upvote 4
Gandhi
