HiPhiSch Posted January 20, 2009 Share Posted January 20, 2009 Ok, my third plugin is something I always wanted to have. Something to fill parts deleted from an image based on the surroundings: Fill Gaps v1.0 (found in the "Render" submenu) Demo 0 -- The extreme case (Done with default parameters): Demo 1 -- The simple case (Similar colors at the border, done with default parameters): Demo 2 -- Combination with plugin "Selective Toning" (Overlap: 20, Precision: 20) User Interface: Hints on usage: * The plugin will try to fill everything transparent in the selected region. Since layers are often transparent in the outer part, make sure to additionally select only the part you want to have filled! (For instance, use the wand on the outside and press + i to invert the selection) * The calculations of the algorithm take some time. The first to sliders control quality and calculation time. Left: fast, right: slow, but better looking * The two sliders tell the plugin what it treats as transparent. The third slider is the threshold value used for what pixels should be filled. The last one is the threshold for what pixels should be considered during reconstruction. How it works: * From each transparent pixel some circles are expanded. For some points on the circle the color values are considered. The precision value is equal to two times the pixel colors used. * If colored pixeled are found the circle may still be expanded a little more, to get some more averaging over colors. The min overlap slider controls how many steps the circle will be increased, after the first pixel colors are found. * The final color value of each pixel will be the average of all relevant pixel colors. Download: > > Fill_Gaps_v1.0.zip < < Source code (for programmers): https://www.dropbox.com/s/jzko9aelxlgg9el/Fill_gaps_v1.0_source.zip?dl=0 The source code is for BoltBait's great plugin "Code Lab"! I hope you like it, Philipp 1 Quote Link to comment Share on other sites More sharing options...
someone93 Posted January 20, 2009 Share Posted January 20, 2009 Reminds me of inpaint, and that program is really helpful sometimes. Quote Link to comment Share on other sites More sharing options...
pipp92 Posted January 20, 2009 Share Posted January 20, 2009 thanks, could be useful Quote Personal Gallery Link to comment Share on other sites More sharing options...
LFC4EVER Posted January 20, 2009 Share Posted January 20, 2009 Interesting plugin.. Works great on faces, not so good on the flower pic. Nice job though, it'll come in handy. Thanks. Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
sharpy Posted January 22, 2009 Share Posted January 22, 2009 hey this is really cool for minor skin blemishes when used with a little motion blur. thank for the plug! Quote Link to comment Share on other sites More sharing options...
Axle Posted September 22, 2009 Share Posted September 22, 2009 looks tricky to make but fun and great to use Quote My Deviant Art | My Gallery Link to comment Share on other sites More sharing options...
impossible9 Posted September 22, 2009 Share Posted September 22, 2009 Ha ha! Very useful plugin indeed. That example picture with the woman gave me the idea of using this for a horror picture... Quote Link to comment Share on other sites More sharing options...
Onemorelevel Posted September 23, 2009 Share Posted September 23, 2009 :shock: Amazing! I love it! Quote "Being calm can work wonders" ~My gallery~D: Iceberg Tutorial! Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 17, 2017 Share Posted September 17, 2017 Rehosted images - Thanks to ReMake Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
zak21 Posted May 24, 2020 Share Posted May 24, 2020 Any chance for reupload? Quote Link to comment Share on other sites More sharing options...
Djisves Posted May 25, 2020 Share Posted May 25, 2020 Have you seen Content Aware Fill? In any case, I attach this DLL. > >snip << Which is now hosted in the first post .. Thank you @Djisves Quote Link to comment Share on other sites More sharing options...
Pixey Posted May 25, 2020 Share Posted May 25, 2020 16 hours ago, zak21 said: Any chance for reupload? Re-hosted the Zip on the first post. Thank you @Djisves for the file Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
zak21 Posted May 27, 2020 Share Posted May 27, 2020 Thanks a lot, works great! Quote Link to comment Share on other sites More sharing options...
