Mike Ryan's Plugins
Mike Ryan
Mike Ryan's Plugins
An Oversized dose of mediocre plugins ftw! :P
About
Yeah, yeah, yeah. I decided to go ahead and jump on the bandwagon
with this one and publish all of my plugins, including any future updates,
in one big package of plugins. These plugins are mainly Alpha Level Utilites
for removing particular levels of color for color correction. Many of these
are inspired by case to case circumstances in which I needed the particular
effect during my own photography editing times. I hope these plugins are of
some use to you and if not then I guess it wouldn't be too bad to have them
lying around in your submenus :lol:
Alias
Submenu: Effects -> Object
Alias is a multipurpose tool originally created to remove any transparent
pixels from an object before applying BoltBait's very powerful 'Feather'
plugin as Feather was causing distorted results when applied to already
existing antialiasing
Color Trimming
Submenu: Effects -> Color
Color Trimming is used for color correction in photographs when too much
of a particular color is present on the applied image. It will remove a
defined range of that particular color allowing for more vibrant colors to
be displayed with in the image.
Input to Output
Submenu: Adjustments
Input to Output allows you to adjust the value of one color channel (The
input) by the value of another channel (the output). Very useful for making
alpha masks, removing color, etc.
Brightness/ Darkness to Alpha
This is an old plugin of mine whose functionality is useless compared to a
Tanel plugin however its simple user interface can still make this plugin
useful. It allows you to remove dark or bright parts of an image and turn
them into Alpha.
Invert Alpha
Similar to Invert Colors, this plugin inverts the Alpha channel.
About Silhouette Plus
Silhouette converts the entire canvas into your selected color while
preserving the alpha levels of each pixel. As well, you can also specify an
alpha range in which to silhouette. This is usefull for object manipulation
and for testing the transparency of the canvas is particular areas.
Please read the included License Agreement found in the included Readme.txt file
Some visual icons (Alias, Color Trimming, and Input to Output) are credited to Max Power
Mike Ryan's Plugins.zip
Yay!
I love plugin packs because it means I can find more and more plugins in just 1 place.
Thanks for the pack Mike :D
"Confusion is the welcome mat at the door of creativity." -Michaul Gelb
My Gallery Check it out!
Mike I found the Silhouette Plus at Submenu: Effects -> Object instead of Color
Thanks for the plugins.
Is it me --or do buffalo wings taste like chicken?
  • 3 weeks later...
I have been recieving some PMs lately regarding some issues with some plugins. As previously stated I will no longer support plugins. If time allows it, I will try to iron out those bugs but until then please do not contact me for support about these plugins. Instead, post them in this thread and I will try to keep up to date. Thanks!
  • 2 years later...
Will someone - Mike Ryan or Admin or whoever is responsible for these things - please make the necessary
spelling correction to the Effects > Color submenu.
It's Color Trimming not Color Timming.
Thank you.
What - you've never applied Color Timming? :lol:
I'll flag them as such in the next release of the Plugin Index.
I take it that 'not supported' means they might not work in a later release of Paint.Net and you don't intend to fix them if they break?
None of these should break in future releases unless there were major revisions to the plugin system. These are pretty fault=tolerant plugins made in CodeLab.
