Simon Brown Posted June 22, 2009 Share Posted June 22, 2009 Several ways: Authors Category >FileTypes >Adjustments >Plugin use & Creation >Distortion >Colour >Photo >Stylize >Canvas plugin >Misc >Plugin packs Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 22, 2009 Author Share Posted June 22, 2009 I have one or two difficulties with this approach. Here's one: Illnab1024's plugin Channel Mixer Greyscale (aka Advanced Greyscale) Photo or Color? Both?? Like I said previously, its not going to be easy to separate some plugins to a distinct category or field. We may have to duplicate where crossovers appear to exist. Other than that, I love your list Simon. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 22, 2009 Author Share Posted June 22, 2009 Slightly different presentation: 3D Heightmap v1.0 by Spikehead777. Takes current image as a height map & shines a light on it, returning the intensity of reflected rays as another image (similar to Emboss) Add Noise by MadJik. Adds “noise” to a selection Add/Remove/Recover Watermark by Evan Wallace (Removed). Removed by author due to possible copyright abuses Advanced Color Replacement by silverhammer. Recolors every pixel a different amount based on how similar it is to the secondary color. Advanced Tools by LFC4EVER. The most awesome collection of tools ever produced for PDN. Note original post date! Alias Plugin (Feather's New Best Friend!) by Mike Ryan. Removes antialiasing. Useful prior to feathering Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Aethec Posted June 22, 2009 Share Posted June 22, 2009 I think including old plugins that do not work anymore/are included in PDN/have been removed in a separate category would be better ; Normal users don't want those. A presentation suggestion : 3d Heightmap (Spikehead777) Takes current image as a height map & shines a light on it, returning the intensity of reflected rays as another image (similar to Emboss) Add Noise (MadJik) Adds “noise” to a selection. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 22, 2009 Author Share Posted June 22, 2009 I think including old plugins that do not work anymore/are included in PDN/have been removed in a separate category would be better ; Normal users don't want those. I think keeping them is worth while - if just for reference as to what has become of them. This way a reference to an old plugin can be looked up and the inbuilt effect or updated plugin can be found. 3d Heightmap (Spikehead777)Takes current image as a height map & shines a light on it, returning the intensity of reflected rays as another image (similar to Emboss) Add Noise (MadJik) Adds “noise” to a selection. I like the splitting into separate lines for the Name & Auther vs the description/function. Can anyone tell me what codes I need to send to the forum to create a carriage return & linefeed? My memory tells me it was hex 0D0A or something similar. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Simon Brown Posted June 22, 2009 Share Posted June 22, 2009 \r\n Probably. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 23, 2009 Author Share Posted June 23, 2009 \r\nProbably. Couldn't get that to work, but did find that adding CHR(10) to a text string worked fine. Thanks Simon. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 24, 2009 Author Share Posted June 24, 2009 I've come up with this layout, after a fair bit of fiddling with the BBcodes, and throwing in instances of CHAR(13) as a linefeed character: Sample Layout - Alphabetical List of Plugins Hidden Content: 3D Heightmap v1.0 - Spikehead777 Takes current image as a height map & shines a light on it, returning the intensity of reflected rays as another image (similar to Emboss) Add Noise - MadJik Adds “noise” to a selection Add/Remove/Recover Watermark - Evan Wallace (Removed). Removed by author due to possible copyright abuses Advanced Color Replacement - silverhammer Recolors every pixel a different amount based on how similar it is to the secondary color. Advanced Tools - LFC4EVER The most awesome collection of tools ever produced for PDN. Note original post date! Alias Plugin (Feather's New Best Friend!) - Mike Ryan Removes antialiasing. Useful prior to feathering Sample Layout - Plugin List by Author Hidden Content: Enormator - invert around primary color Invert colors around other colors. Enormator - Primary Color Difference to Alpha Calculates the difference between the pixel and primary color. The more they are equal, the more transparency will result Evan Wallace - Add/Remove/Recover Watermark (Removed). Removed by author due to possible copyright abuses Evan Wallace - BLP Converter Plugin (Filetype). File type plugin for loading Blizzard Picture files (*.blp). Requires Microsoft Visual C++ 2008 SP1 Redistributable Package. Click here to download.(link) evanolds - Conditional Hue/Saturation Effect (Evan's Effects 1.1(link)). Adjust hue and saturation by setting range and conditions. evanolds - Evan's Effects v1.1 (Plugin pack). Effects: Mirror over line, Conditional Hue/Saturation, Octagonal/Quadrilateral reshape/matte, 3D Object (BETA) evanolds - Icon, Cursor, and Animated Cursor Format (Filetype). Support for Icon & cursor filetypes, including animated cursors I plan to post these lists over the weekend (see *.pdf files in original post for full lists). I'll use the show/hide, as above, so that users don't have to scroll through the first list if they wish to view the second list. Further lists (plugin by category) can be added at a later stage. Anyone have further recommendations? Corrections?? Now is your chance...., Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
jxp Posted June 26, 2009 Share Posted June 26, 2009 Funnily enough I was also working on something along these lines. I was taking the approach of listing each plugin by its menu name (categorised by the main Paint.net Effects types). I was also running each plugin on a sample image (or blank image for render plugins). Effects are such visual things I thought it was worth seeing what they are like. e.g Parrot is orginal image, then apply each effect to it. So far I've done about 100 images. I was thinking that it would help to have both the DLL filename (some effects are in combined dlls) and the menu name as well as a link to the relevant Plugin forum topic. My ultimate intention was to have some web pages that would show the images and you could click on the link to see the thread about that plugin. (view the attached image to see what I mean) Quote Don't know what plugin to use? Try looking in the plugin gallery Link to comment Share on other sites More sharing options...
