Hello. I hate this to be my first post on this forum, but the Layer Saver is not working for me. It is returning an error and is not saving properly. Instead of the many layers that I am trying to save, I get one named "0" that is empty. It is also, I dunno, distorted? Save Configuration comes up when I choose either jpg or gif format, maybe others, but when it shows it is cut off as in the pic.
What I am attempting to do is transform a 61 layer .pdn to 61 individual .gif images for use in UnFreez.
I think I have entered everything correctly, but may well not have. I expanded the LS to show my paths and such.
This is the newer DL you have. I had the same issues with the one from the first post, read the whole thread and thought it was just something buggy in the first DL.
Specs on the images:
Currently in .pdn form.
61 layers starting with layer name 1, ending at 61.
not sure on file size, but all are small, 200x150'ish.
Layer Saver was DL'd to my desktop and extracted there.
Here is a screenshot of the Layer Saver error and how/what I have configured:
And error message:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at PaintDotNet.GifSaveConfigWidget.InitTokenFromWidget()
at PaintDotNet.SaveConfigWidget.OnLoad(EventArgs e)
at System.Windows.Forms.UserControl.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at ILikePi.FileTypes.LayerSaver.LayerSaver.format_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Layer Saver
Assembly Version: 8.5.29.0
Win32 Version: 8.5.29.0
CodeBase: file:///C:/Documents%20and%20Settings/Sean/Desktop/Layer%20Saver.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PaintDotNet.Core
Assembly Version: 3.22.2933.24442
Win32 Version: 3.22.2933.24442
CodeBase: file:///C:/Program%20Files/Paint.NET/PaintDotNet.Core.dll
PaintDotNet.Data
CodeBase: file:///C:/Program%20Files/Paint.NET/PaintDotNet.Data.dll
PaintDotNet.SystemLayer
Assembly Version: 3.22.2933.24441
Win32 Version: 3.22.2933.24441
CodeBase: file:///C:/Program%20Files/Paint.NET/PaintDotNet.SystemLayer.DLL
DdsFileType
Assembly Version: 1.11.2933.24444
Win32 Version: 1.11.2933.24444
CodeBase: file:///C:/Program%20Files/Paint.NET/FileTypes/DdsFileType.dll
PaintDotNet.Resources
CodeBase: file:///C:/Program%20Files/Paint.NET/PaintDotNet.Resources.DLL
wmdggq6c
Assembly Version: 0.0.0.0
6x41wwj_
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
PaintDotNet.Base
Assembly Version: 3.22.2933.24440
Win32 Version: 3.22.2933.24440
CodeBase: file:///C:/Program%20Files/Paint.NET/PaintDotNet.Base.DLL
System.Runtime.Serialization.Formatters.Soap
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I really hope it is only something I am doing wrong as this program additive is just the ticket for what I need.
