This effect will attempt to detect "rough" edges and soften them, similar to the feather plugin, or the basic anti-alias effect.
The left side is the original (no anti-aliasing), the right side has had this effect applied to it.
Here are some other random variations of the effect:
Settings:
Phase: A slider that effects how edges are detected based on how dark or light a pixel is.
Amount: A slider that decides how "soft" to make the edges.
In/Out of phase: Choose to use the inside or outside of detected edges for applying the effect.
Edges Only: Choose to show only the detected edges (uses primary and secondary colors).
This version is VERY powerful. Take some time to play around with it with various images and settings... very versitile.
Enjoy,
Jesse Chunn
