jchunn.zip 16.02K
61048 downloadsMarch 8, 2008
Fixed minor bugs with "Varicose".
Updated "Focal Point" with yet another (and I think the last) performance enhancement.
March 5, 2008
Updated "Soften Edges" to have better performance, several new settings, and MUCH better effect.
Updated "Focal Point" with new setting / performance enhancement.
March 2, 2008
Added "Soften Edges" effect.
Updated Focal Point to be much faster in most circumstances.
Feb 20, 2008
Initial post of Jesse Chunn Plugin Pack, including Focal Point, Stencil, Color Replace, Varicose, and Bricks.
This pack includes the following plugins (click to see post about specific plugin):
Effects->Blurs->Soften Edges
This effect attempts to detect edges that need anti-aliasing and "soften" them, or show hard edges only.
Effects->Blurs->Focal Point
This effect allows you to select a point on an image to remain "in focus" and blurs the rest of the image.
Effects->Artistic->Stencil
This effect will turn an image into a two color image, similar to a stencil.
Effects->Color Replace
This effect works similarly to the magic wand, but with more control.
Effects->Render->Varicose
Generates something like "veins" running down the screen.
Effects->Render->Bricks
Very powerful yet very simple plugin. Most basic use is to generate "bricks" over the image, but many other more "subtle" uses if you play around with it.
Enjoy,
Jesse Chunn
Edited by Ego Eram Reputo, 13 February 2013 - 04:44 AM.
Updated forum links.
