Point Warp / Engorged Smudge (Aug 20, 2015)
toe_head2001
Point Warp
This is simply a rebuild of @Illnab1024's original plugin to make it compatible with paint.net v4. All credit goes to him. I've also reduced the source code from a Visual Studio project to a CodeLab script.
Effects -> Distort -> Point Warp
Features
  • Applies a 'point warp' at a given location on the image. It's basically bulge but in the horizontal plane instead of the vertical.
Changelog
v1.2 by toe_head2001 (Aug 20, 2015)
  • Changed: Minor Changes to the source code to make it CodeLab compatible.
v1.1 by Illnab1024 (2008?)
  • Small modifications to the UI and code that should look and work more intuitive.
v1.0 by Illnab1024 (Jan 10, 2008)
  • Initial release
Download
PointWarpEffect.zip
Source
Spoiler
post-46943-0-69647600-1440051463.png <-- Icon
// Name: Point Warp
// Submenu: Distort
// Author: Illnab1024
// Title:
// Version:
// Desc:
// Keywords:
// URL:
// Help:
#region UICode
int Amount1 = 10; // [0,150] Point Width
int Amount2 = 10; // [0,500] Distance
Pair<double, double> Amount3 = Pair.Create(0.0, 0.0); // Center
double Amount4 = 45; // [-180,180] Direction
int Amount5 = 10; // [0,200] Radial Influence
#endregion
    double newRad = Amount5 * 1000;
    newRad = Math.Log(newRad, 2);
    double radius = (newRad);
    long CenterX = (long)(((selection.Right - selection.Left) / 2) + selection.Left);
    long CenterY = (long)(((selection.Bottom - selection.Top) / 2) + selection.Top);
    double offx, offy, trux, truy, xd, yd, Amnt, influence, fox, foy, angle;
    float d;
    Amnt = Math.Log(Math.Pow(System.Math.E * radius, Amount1)); // Better for getting an actual width of the cap.
    angle = Amount4 * Math.PI / 180d;
    angle += Math.PI;
    offx = Math.Cos(angle) * Amount2;
    offy = Math.Sin(angle) * Amount2;
    d = (float)Amnt;
    fox = (Amount3.First) * (rect.Width / 2);
    foy = (Amount3.Second) * (rect.Width / 2) * -1;
            xd = (double)(x - fox);
            yd = (double)(y + foy);
            influence = (System.Math.Pow((radius * System.Math.E), ((0d - (System.Math.Pow(((xd - CenterX) / (d)), 2) + System.Math.Pow(((yd - CenterY) / (d)), 2))))));
            //influence = 0d - influence; --I honestly don't understand why I put that there 9 months ago.
            trux = (offx * influence);
            truy = (offy * influence);
            trux += (double)x;
            truy += (double)y;
            ColorBgra pt = src.GetBilinearSample((float)(trux), (float)(truy));
            // This now should not call out of the boundaries with the influence line gone,
            // apart from amounts that create a great influence atop the cap of the function.
            //pt.R = (byte)(((pt.A / 255) * (pt.R)) + ((1 - (pt.A / 255)) * (src[x, y].R)));
            //pt.G = (byte)(((pt.A / 255) * (pt.G)) + ((1 - (pt.A / 255)) * (src[x, y].G)));
            //pt.B = (byte)(((pt.A / 255) * (pt.) + ((1 - (pt.A / 255)) * (src[x, y].));
            //pt.A = (byte)(255);
            dst[x, y] = pt;
Edited by toe_head2001
  • Thanks 1
  • Upvote 5
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
Thanks toe-y! How about releasing this in it's own thread to differentiate the two versions?
Edit: New plugin split into it's own thread.
UI and effect screenshot.
Feel free to add this into the first post toe-y.
