Zoom Blur Deluxe for 4.0
null54
This is Zoom Blur Deluxe recompiled to be compatible with Paint.NET 4.0, no other changes have been made.
The following description is copied from the original thread.
It is faster than the built-in zoom effect and you can move the center. Enjoy !
License : Same as Paint Dot Net license. (MIT)
ZoomBlurDeluxe_4.0.zip
ZoomBlurDeluxeSrc_4.0.zip
  • Upvote 6
If I convert this to IndirectUI, will you add it to the first post?
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
For some reason, after I copied the DLL to my PDN effects directory, it still didn't show up in my Effects>Blur menu. I built the plugin, myself, and it worked fine. Quite a nice effect, too.
In case anyone else has the same problem, here is my build: ZoomBlurDeluxe.zip
If no one else has the problem, I'll delete the attachment later.
For some reason, after I copied the DLL to my PDN effects directory, it still didn't show up in my Effects>Blur menu....
Hmm, I had no issue with it.
It is faster than the built-in zoom effect...
In my unscientific testing (both effects at comparable settings) of several 5,000px x 5,000px photos, I found the built-in effect to be faster.
Still, this effect produces slightly different results compared to the built-in effect, so I think I'll keep it.
Edited by toe_head2001
I have an old dll that crashed PDN and I also download the dll that didn't show up. I tested the one you just posted, it isn't quit the same, but that can be due to so many other things I understand that.
I'm about to try a tutorial to see what happens. Thank you so much for just seemingly just throwing one together. :D
Here's source for a CodeLab version, in case anyone is interested:
Hidden Content:
// Name: Zoom Blur Deluxe CL
// Submenu: Blurs
// Author: Kevin Drapel (and MJW)
// Title: Zoom Blur Deluxe CL
// Desc: CodeLab version of Zoom Blur Deluxe
// Keywords:
// URL:
// Help:
#region UICode
int Amount1 = 20; // [0,256] Amount
Pair<double, double> Amount2 = Pair.Create( 0.0 , 0.0 ); // Center
byte Amount3 = 0; // [1] Quality|Low|Medium|High
#endregion
    long w = dst.Width;
    long h = dst.Height;
    int amount = Amount1;
    int quality = Amount3;
    long cx = (long)((0.5 * src.Width) * (Amount2.First + 1.0)) << 8;
    long cy = (long)((0.5 * src.Height) * (Amount2.Second + 1.0)) << 8;
    long fx, fy;
    long fdx, fdy;
    long tx, ty;
    long rx, ry;
    int sa, sg, sb, sr;
    byte shiftFactor = 2;
    byte shiftFactor2 = 8;
    byte steps = 4;
    switch (quality)
        case 0:
            shiftFactor = 3;
            steps = 8;
            break;
        case 1:
            shiftFactor = 5;
            steps = 32;
            break;
        case 2:
            shiftFactor = 6;
            steps = 64;
            break;
    shiftFactor2 += shiftFactor;
    unsafe
        for (int y = rect.Top; y < rect.Bottom; ++y)
            fy = y << 8;
            fdy = (amount * (cy - fy)) >> shiftFactor2;
            ColorBgra* dstPtr = dst.GetPointAddressUnchecked(rect.Left, y);
            ColorBgra* srcPtr = src.GetPointAddressUnchecked(rect.Left, y);
            for (int x = rect.Left; x < rect.Right; ++x)
                fx = x << 8;
                fdx = (amount * (cx - fx)) >> shiftFactor2;
                tx = fx;
                ty = fy;
                sr = sg = sb = sa = 0;
                for (int n = 0; n < steps; n++)
                    rx = tx >> 8;
                    ry = ty >> 8;
                    if (rx < 0) rx = 0;
                    if (ry < 0) ry = 0;
                    if (rx >= src.Width) rx = src.Width - 1;
                    if (ry >= src.Height) ry = src.Height - 1;
                    ColorBgra* srcPtr2 = src.GetPointAddress((int)rx, (int)ry);
                    sr += srcPtr2->R * srcPtr2->A;
                    sg += srcPtr2->G * srcPtr2->A;
                    sb += srcPtr2->B * srcPtr2->A;
                    sa += srcPtr2->A;
                    tx += fdx;
                    ty += fdy;
                sr >>= shiftFactor2;
                sg >>= shiftFactor2;
                sb >>= shiftFactor2;
                sa >>= shiftFactor;
                *dstPtr++ = ColorBgra.FromBgra((byte)sb, (byte)sg, (byte)sr, (byte)sa);
Here's the icon: post-53337-0-10626800-1440045896.png
EDIT: At toe_head2001's suggestion, I changed the blur range to 0-255. (toe_head2001 points out that in the original version it's 1-256, but I like the no-blur option, and somehow 255 seems to me to be more sensible as the top of the range. It's easy to change if someone insists it match the original.)
EDIT2: At toe_head2001's suggestion, I changed the blur default to 20. I missed that in my first edit. I also changed the top of the range to 256, because my reason for not doing so was silly. I left 0 as the lower range, because I do like the idea of being able to see the image with no blur. (I could make it a do so more efficiently by handling that as a special case.)
Edited by MJW
  • Upvote 3
Yes.
That was copied from the original thread, it may have been faster when the effect was first posted in 2007.
Here's source for a CodeLab version, in case anyone is interested...
I was just about to post that... you beat me to it.
Hey, look at this line:
int Amount1 = 10; // [0,100] Amount
The original source allowed for a zoom range of 1 - 256, and had a default of 20
Edit:
Here's the IndirectUI dll for those that want it.
ZoomBlurDeluxe.zip
  • Upvote 3
Sorry, toe_head2001. I didn't post the CodeLab version so much so that someone could use it (since they can use the original), but just because I thought someone might use it as the basis for some other variation.
Good job Pixey, I was trying to do Yellowman's Wall Light a few days ago.
Thank you all for doing your bit at bringing this back.
  • 3 months later...
attachicon.gifZoomBlurDeluxe_4.0.zip
attachicon.gifZoomBlurDeluxeSrc_4.0.zip
So do I need everything in both these zips to have the Zoom blur deluxe? And does it all go in Effects? Still learning this stuff....
  • 4 years later...
