TR's Smudger V2.2 Dec 17, 2013
TechnoRobbo
TechnoRobbo's Smudger V2.2
A full screen plugin that lets you smudge,smear and blend colors in your image.
Left Click to smudge image.
Right Click to Pan image.
Version2.2 - Zoom in Feature Added
Version2.1 - Code Accelerated
Version2.0 - Full Screen Interface
Version1.3 - Updated for Paint.net 4.0
Version1.2 - added edge clipping
Version1.1 works with Alpha Transparency
Maximum control Width increases to 200
Menu : Effects->Distort
TRsSmudgeMenu.png?raw=1
Demo best viewed 1080P
Music by TechnoRobbo
Facial Retouching
Techno
TRsSmudge.png?raw=1
Calor
TRsSmudge2.png?raw=1
How It Works
The plugin is a photographic realization of a digital lowpass audio filter.
In Laymen's terms - its a buffer that resists change.  As you move the buffer over the image it collects a certain percentage of the image from the buffer's location and blends it into the buffer.Then the program deposits the content of the buffer. Elements of the background are therefore,dragged along into other areas of the background.
The VS Source Code
https://www.dropbox.com/s/0ulxkel6no41r89/TRsSmudgeSrcr.zip?dl=0
The Plug In
TRsSmudger.zip
Edited by TechnoRobbo
  • Upvote 3
TRsSig.png?raw=1
That's cheating! - I rely on 'lucky' words. :)
I find maths far more interesting if I can see what it's doing - I'm actually starting to understand some of the maths I was supposed to have learnt 30 odd years ago.
It's also good to see how much can be achieved with so few lines of code.
Maybe I'm misunderstanding this plugin but this seems like a very awkward way to smudge compared to mine. It's also painfully slow and doesn't work well with transparency.
edit: I do see one advantage to this control scheme in that you can see the fully layered image while you work, but that's irrelevant as long as it doesn't work correctly with alpha.
ambigram signature by Kemaru
[i write plugins and stuff]
... but that's irrelevant as long as it doesn't work correctly with alpha.
I guess it's relevant now
Version 1.1 Uploaded - works correctly with Alpha Cahnnel
It's also painfully slow ...
This image took 20 minutes
I guess at this point it's best to explain:
How It Works
TRsSig.png?raw=1
  • 3 weeks later...
Version 2.1 Uploaded. Code is much Faster - I didn't think I'd get it done so quickly.
Thanks Red, I just accelerated the code 10 fold using Lockbits
Checkout the Source Code - Intend on accelerating edge fader also.
TRsSig.png?raw=1
Version 2.2 uploaded  added zoom feature
Here's a Video Tutorial called
"TR's Smudger Photo Retouching with Version 2.2"
or
"Taking Years off of Angela Merkel"
best viewed full screen 1080p
TRsSig.png?raw=1
  • 5 years later...
This tool is exactly what I needed! But I am having a little problem with it.  A second window opens to work on the smudging but the second window does not show the entire image.  Not even in "Zoom 1x". There does not seem to be able way to move the image around in the window to look at all parts of the image.  The window also does not seem to be resizable.  Does this still work in Paint 4.2?  And/or is there some way that I can see my entire image to work on it.
Thank for all your work.
  • 2 years later...
You have to download the Zip File, found at the bottom of the first post - then unzip it and move the contents to the Effects Folder of paint.net :)
