TR's Tilt-Shift Plugin
TechnoRobbo
TechnoRobbo's Tilt-Shift
Another Classic photographic simulation.
https://en.wikipedia.org/wiki/Tilt%E2%80%93shift_photography
Tilt Shift Photography is created by misaligning the lens with the film or image sensor.
This misalignment actually shifts the depth of field.
TR's Tilt-Shift is a directional gradient blur tool designed to easily achieve the effect.
TiltShift.png?raw=1
Menu: Effects - > Blurs
TiltShiftMenu.png?raw=1
Video Tutorial for image plane image
music by TechnoRobbo
Vanishing Point
VP.png?raw=1
The Code
Hidden Content:
// Submenu: Blurs
// Name: TR's TiltShift
// Title: TR's TiltShift - v1.0
// Author: TechnoRobbo
// URL: http://www.technorobbo
#region UICode
int Amount1 = 15; // [1,100] Blur Amount
double Amount2 = 45; // [-180,180] Tilt
double Amount3 = .5; // [0,1] Length
#endregion
public struct PointD
public double x, y;
public PointD(double p1, double p2)
x = p1;
y = p2;
Rectangle sel = EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt();
int CenterX = ((sel .Right - sel .Left) / 2)+sel .Left;
int CenterY = ((sel .Bottom - sel .Top) / 2)+sel .Top;
double rad = Amount2 * Math.PI/180;
double diag = Math.Sqrt(sel.Width * sel.Width + sel.Height + sel.Height);
ColorBgra CP = new ColorBgra();
//Test varaibles
//Amount1 = 20;
//Amount2 = -90;
//Amount3 = .85;
PointD position = new PointD(x-CenterX,y-CenterY);
double oldx = position.x ;
position.x =(float)Math.Cos(rad) * (float)position.x - Math.Sin(rad) * position.y + CenterX;
double length =diag * Amount3 + 1;
double val =1 - Math.Min(1,position.x /length);
//quadratics
val *=val;
int Amount =(int)((double)Amount1 * val);
if (Amount>0){
int y1= y - Amount;
int y2 = y + Amount;
int x1= x - Amount;
int x2 = x + Amount;
int A=0,R=0,G=0,B=0,D=0;
for (int j=y1;j<y2;j++){
for (int i=x1;i<x2;i++){
CP = src.GetBilinearSampleClamped(i,j);
A += CP.A;
R += CP.R;
G += CP.G;
B += CP.B;
D++;
if (D==0){D=1;}
CP.A = Int32Util.ClampToByte(A/D);
CP.R = Int32Util.ClampToByte(R/D);
CP.G = Int32Util.ClampToByte(G/D);
CP.B = Int32Util.ClampToByte(B/D);
}else{
CP=src[x,y];
dst[x,y] = CP;
TRsTiltShift.zip
Edited by TechnoRobbo
  • Upvote 5
TRsSig.png?raw=1
  • 3 weeks later...
  • 4 months later...
   dude,,, you're a madman,,, i mostly make wallpapers for phones, pc & tablets & this stuff you're doing is awesome!!! i've downloaded 6 or 7 of yours already & still lookin',,, great work,,, if i wasn't broke i'd send you a hundy,,, tyvm!!!  B)
