TR's Tesla Coil Plugin
TechnoRobbo
TechnoRobbo's Tesla Coil Plugin
A Simulation of an electrical arc and the arc breaking down.
Lots of adjustments so you can go from Realistic to Comic Book style.
Menu: Effects->Render
TeslaMenu.PNG?raw=1
Instructions on Youtube: https://youtu.be/ucSD7olugi0
A Lady's Wrath
Tesla.png?raw=1
The Code
Spoiler
// Submenu: Render
// Name: TR's Tesla Coil
// Title: TR's Tesla Coil PlugIn - v1.0
// Author: TechnoRobbo
// URL: http://www.technorobbo.com
#region UICode
Pair<double, double> Amount1 = Pair.Create( 0.0 , 0.0 ); // From
Pair<double, double> Amount2 = Pair.Create( 0.0 , 0.0 ); // To
double Amount3 = 25; // [10,75] Flux size
int Amount4 = 2; // [1,10] Thickness
int Amount5 = 192; // [30,255] Intensity
byte Amount6 = 0; // [255] Next Shape
byte Amount7 = 0; // [255] Next Sub-Shape
int Amount8 = 4; // [0,20] Spawn
int Amount9 = 500; // [100,1000] Resolution
byte Amount10 = 0; // Arc Color|Blue Lightning|Red Lightning|Green Lightning|White Lightning
#endregion
void spark(ref Surface dst,Rectangle rect, ref Random rndm, RectangleF field ,double thickness,
    double flux , int intensity , int spawn,int rez,int arc){
    PointF[] pt = new PointF[(int)(rez)];
    double fx = field.Left;
    double fy =field.Top;
    double tx = field.Width;
    double ty = field.Height;
    double width=thickness;
    double glow=thickness * 1.75 ;
    double glow2=thickness * 2.25;
    Color[] arcColor ={Color.FromArgb(intensity,255,255,255),Color.FromArgb(intensity,255,255,255),
        Color.FromArgb(intensity,255,255,255),Color.FromArgb(intensity,255,255,255)};
    Color[] glowColor ={Color.FromArgb((int)(intensity * .5) ,0,0,255) , Color.FromArgb((int)(intensity * .5) ,255,0,0) ,
        Color.FromArgb((int)(intensity * .5) ,0,255,0) , Color.FromArgb((int)(intensity * .5) ,255,255,255)};
    Color[] glowColor2 ={Color.FromArgb((int)(intensity * .25) ,0,0,255) , Color.FromArgb((int)(intensity * .25) ,255,0,0) ,
        Color.FromArgb((int)(intensity * .25) ,0,255,0) , Color.FromArgb((int)(intensity * .25) ,255,255,255)};
    Pen DotPen = new Pen(arcColor[arc]);
    DotPen.Width = (float)width;
    Pen GlowPen = new Pen(glowColor[arc]);
    GlowPen.Width = (float)glow;
    Pen GlowPen2 = new Pen(glowColor2[arc]);
    GlowPen.Width = (float)glow2;
    Graphics g = new RenderArgs(dst).Graphics;
    g.Clip = new Region(rect);
    g.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.AntiAlias;
    double rad = Math.Atan2(tx - fx,ty - fy);
    double tang=0;
    double i = 0;
    double span = Math.Sqrt((fx-tx)*(fx-tx)+(fy-ty)*(fy-ty));//actual length
    for (int count=0; count<( pt.Length); count++){
        //interpolate location
        double Z = Math.Pow(i, 10);
        double Y2 = fy * (1 - i) + i * ty;
        double X2 = fx * (1 - i) + i * tx;
        //semi random misdirection
        tang = tang + Math.Truncate(rndm.NextDouble()  * (flux + 1)) - flux / 2;
        double X = X2 + Math.Cos(rad) * tang;
        double Y = Y2 + Math.Sin(-rad) * tang;
        //interpolate direct course
        pt[count].X  =(float)(X * (1 - Z) + X2 * Z);
        pt[count].Y = (float)(Y * (1 - Z) + Y2 * Z);
        if (spawn !=0){
            int subdiv =(pt.Length/spawn);
            //spawn a sput at sub division
            if ((count % subdiv) ==0){
                if ((count > 0) && ((pt.Length-count) > subdiv/2)){
                    //random spur rotation
                    double spur= rndm.NextDouble() *  Math.PI/2 + Math.PI/4 - rad ;
                    //random spur length (0-1)
                    double span2 =span * (rndm.NextDouble() * .15  + .05);
                    RectangleF field2= new RectangleF(pt[count].X,pt[count].Y,(float)(pt[count].X + Math.Cos(spur) * span2),
                        (float)( pt[count].Y + Math.Sin(spur) * span2));
                    //respawn params
                    double thick2 = Math.Max(thickness * 1/2,1);
                    int rez2 = Math.Max(rez/3,50);
                    spark(ref dst,rect, ref rndm, field2, thick2 , flux ,intensity ,0,rez2, arc);
        i+= 1/(float) (pt.Length); //increment interpolation
    g.DrawLines(GlowPen2 , pt);
    g.DrawLines(GlowPen , pt);
    g.DrawLines(DotPen , pt);
    Random rndm = new Random(Amount6*256+Amount7);
    float CenterX = ((selection.Right - selection.Left) / 2)+selection.Left;
    float CenterY= ((selection.Bottom - selection.Top) / 2)+selection.Top;
    RectangleF field= new RectangleF(CenterX * (float)Amount1.First + CenterX,
        CenterY * (float)Amount1.Second + CenterY,
        CenterX * (float)Amount2.First + CenterX,
        CenterY * (float)Amount2.Second + CenterY);
    double thickness = Amount4;
    double flux = CenterX/(100-Amount3);
    int intensity=Amount5;
    int spawn = Amount8+1;
    if (Amount8==0){spawn=0;}
    int rez=Amount9;
    int arc = Amount10;
    //test variables
    //field.X=0;
    //field.Y=0;
    //field.Width=CenterX;//selection.Right;
    //field.Height=CenterY;//selection.Bottom;
    //spawn=5;
    //rez=500;
    //thickness=4;
    //arc=0;
    //end test
    dst.CopySurface( src,rect.Location,rect);
   spark(ref dst,rect, ref rndm, field, thickness, flux, intensity, spawn, rez,arc);
TRsTeslaCoil.zip
  • Upvote 2
TRsSig.png?raw=1
Oh man I have been waiting for someone to make a plugin like this. I am definitely going to play with this after i eat something,maybe for the rest of the night,lol. You da Man!!
That's a pretty cool effect.  +1 for the source code which should be an inspiration to aspiring plugin coders out there.
You could have used this: Lightning.
